Missing some windshield trim
Discussion in '1st Gen Tundras (2000-2006)' started by artsr2002, Oct 22, 2022.
  1. Oct 22, 2022 at 12:15 PM
    artsr2002
    artsr2002 [OP] 2005 Tundra DC SR5
    'Yonder
    Just noticed my 05 DC is missing a small piece of trim at the bottom driver side corner of my windshield. No idea how long it's been missing The passenger side is there. Anyone have a part number? Thanks.
  2. Oct 22, 2022 at 5:45 PM
  3. Oct 22, 2022 at 6:00 PM
    They are often referred to as Cowl cover seal or Side seal. A few months ago we helped someone find them for a 2008. I don't see them in the diagram for the 05 or 06. The dealers have more in depth diagrams than what we can see.
  4. Oct 22, 2022 at 6:05 PM
    I found it for the '07+. Right side is 538660C030, Left is 538670C030. You'll see it in the parts exploded here.
    It doesn't exist in the cowl/windshield diagram for the '06 and earlier. A lot of times when you see that in the parts system, it's because it's part of a larger seal set OR because they don't sell it individually, kinda like the rubber wiper on the 1st gen cowl, that rubs against the windshield. Everyone on here's has shrunk, but Toyota makes you buy the whole cowl, they don't just sell the rubber cowl-to-windshield wiper seal.
  5. Oct 22, 2022 at 7:59 PM
    artsr2002
    'Yonder
    Thanks for the help fellers. I will have to take a look at a junk yard see if I can find one or swing by the dealer and see what they can find.
  6. Oct 24, 2022 at 1:21 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I'm missing the same piece on the passenger side. I think it is bundled with the upper windshield trim piece based on my diagram investigations. If you find a passenger side piece in your hunt, I'll buy it from you and of course cover shipping too. GL :thumbsup:
  7. Oct 24, 2022 at 1:23 PM
    artsr2002
    'Yonder
    I found another post after I posted mine with someone else missing the driver side trim. It only had two posts though. I have a couple of junk yards near me so I'll swing by sometime and see if they have any first gens. I also need a couple of other minor trim pieces inside. Nothing major.
  8. Jan 26, 2023 at 5:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Ran into this thread searching for something else....
    Last year while searching for both sides, I ran across a thread from a few years back with a @Roman post. On my next trip to Franklin Tn Cool Springs Toyota where Roman works, I was able to get those parts.
    I'll also add that the part you feel is missing, is not a separate piece but part of the left or right molding.
    Roman Post....Windshield trim / Exterior
    Without Double Cab 2000 - 2006 Base, Limited, SR5 4.0L V6 - Gas, 4.7L V8 - Gas
    Side Molding Right - (75533-0C020)
    $52
    2000-2006 Toyota Tundra Side Molding 75533-0C020 | Toyota Parts (mcgeorgetoyota.com)
    Side Molding Left - (75533-0C020) $52
    Upper Molding - (75531-0C010) $46
    2000-2006 Toyota Tundra Upper Molding 75531-0C010 | Toyota Parts (mcgeorgetoyota.com)
    W/Double Cab 04(3.4 V6/4.7 V8 - Limited, SR5) & 06(3.4 V6/4.7 V8 Limited, SR5)
    Side Molding Right - (75533-0C030)
    $150
    2001-2007 Toyota Windshield Molding (Right) 75533-0C030 | Toyota Parts (mcgeorgetoyota.com)
    Side Molding Left - (75534-0C030) $150
    2001-2007 Toyota Windshield Molding (Left) 75534-0C030 | Toyota Parts (mcgeorgetoyota.com)
    Upper Molding -(75531-0C020) $46
    2001-2007 Toyota Upper Molding 75531-0C020 | Toyota Parts (mcgeorgetoyota.com)
    G_unit3000, shifty` and artsr2002[OP] like this.
  9. Jan 26, 2023 at 6:40 AM
    artsr2002
    'Yonder
    Thanks for the part numbers Bubba. The curse of the Doublecab parts prices strikes again. Sucks.
    BubbaW likes this.
  10. Jan 26, 2023 at 6:55 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Yep....fortunate not having to worry about sticker shock but still hard swallowing some of these prices. Fixing to pull the trigger on OEM Cats and muffler to replace the Flowmaster on there now before they become NLA(no longer available)
    :spending:
    shifty` likes this.
  11. Jan 26, 2023 at 11:43 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    @artsr2002 , I meant to post this earlier. Did you take a flashlight and look in the cavity where red arrow is ?
    That tail piece you're missing is attached with double sided tape to that ~2 in piece sticking out in you above picture for you driver side. Perhaps it came loose like mine did after 20 yrs and it's in that dark dungeon place ?
    Methodical, G_unit3000 and shifty` like this.
  12. Dec 29, 2024 at 1:55 PM
    Methodical
    Methodical New Member
    Maryland
    2006 Tundra SR5 DC TRD 4x4
    Mine are missing on both sides and there was a lot of debris at the bottom of the fender. So, I suggest if you are missing these to open the door and pull back the plastic cover and inspect for debris and put some protectant in there (Woolwax, fluid film etc) to be safe from potential rust. Hell, put protectant down there regardless because it is a place for potential rust.
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-2230#post-3796577
  13. Dec 29, 2024 at 2:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    Another difference between DC and AC. My AC doesn’t have those.
  14. Dec 29, 2024 at 2:22 PM
    Methodical
    Maryland
    It looks like debris can find it's way down there. Can you inspect to see? I am curious to see what you find.
  15. Dec 29, 2024 at 2:50 PM
    bfunke
    Some leaves get down there. I open the hood and use the shop vac when I vacuum the carpets. Also couple times a year pull the rubber back at the bottom of the fender in front of the front doors and stick a crevice tool in there.
  16. Dec 29, 2024 at 5:29 PM
    I believe on the AC and RC trucks with different front fender and cowl cover the rubber piece is here, and it may be more visible with the hood popped, from the engine bay side. They also use double-sided tape to stick in there, and often get knocked out during windshield replacements from what I've seen others say on here.
  17. Dec 29, 2024 at 5:43 PM
    And that part on AC/RC trucks looks like this: https://www.tundras.com/threads/mystery-part.36391/
    Finally found the damn post explaining it. FML I tried the other day too, and came up empty.
    I dunno if DC trucks have that fender-to-cowl seal, but I suspect it should help keeping leaves out of the lower fender, behind the splash guards (mud flaps).
  18. Dec 31, 2024 at 9:57 PM
    Methodical
    Maryland
    Thanks for the info. If you live in the rust belt I suggest you put some treatment down in that fender crevice area.
