Exhaust condensation excessive?
Discussion in '3rd Gen Tundras (2022+)' started by Senshi81, Jan 24, 2023.
  1. Jan 24, 2023 at 9:15 PM
    Senshi81
    Senshi81 [OP] New Member
    2022 Tundra 4x4 TSS
    My exhaust puts out a lot of condensation for a very long time. I understand that some is normal on cold or cool days, but it seems like too much. Has anyone else noticed this? Is it because of turbos or should I be concerned. Also, I have not noticed the sweet coolant smell that would generally accompany a gasket issue...
  2. Jan 24, 2023 at 9:42 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    It is the catalytic converter's job to convert unburned hydrocarbons in exhaust gases into carbon dioxide (CO2) and water (H2O).
    You're seeing the water.
    If neither coolant system level is going down over time, perhaps your catalytic converters are just really good at what they do.
  3. Jan 24, 2023 at 9:51 PM
    Senshi81
    2022 Tundra 4x4 TSS
    Thanks, I understand the mechanics of it all. I just wondered if anyone else has noticed that it seems extra steamy on these new Tundras. I have a recall that need to be done sometime soon and I can ask the dealer I suppose.
  4. Jan 25, 2023 at 5:50 AM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    I see quite a bit from my rig as well, like mentioned I check the coolant level to make sure that isn’t the case, just figured it’s normal for now
    Senshi81[OP] likes this.
  5. Jan 25, 2023 at 6:03 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    I have noticed this as well, sure does seem like alot. About 10 seconds after startup it really has a thick plume from the tailpipe and then slowly goes back to 'normal' condensation.
    I guess it's a combo of the 4 cats, the turbos and whatever cycle the D4-S engine uses at startup.
  6. Jan 25, 2023 at 6:08 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    I have trauma for blowing two engines. One in my integra GSR and then I bought a type r with a bad head gasket and can remember the white smoke on a 60 degree day and then boom. New engine.
    I bought my 23 on an 8 degree day and still 30 mins later it was pretty thick looking in the side mirror. I had instant flashbacks. I assume it’s normal as now we’re back here it ain’t so thick for too long
  7. Jan 25, 2023 at 6:25 AM
    Senshi81
    2022 Tundra 4x4 TSS
    That is what scared me as well. I had a BMW 326 back in the day that did the same thing. Not cheap to fix as you could imagine. Especially for a 19 yo kid. Still have PTSD I guess. It seems like this may be a normal thing with these trucks then. Thank you all for your input. I love this truck.
  8. Jan 25, 2023 at 6:39 AM
    DrZoidberg
    Dave
    Tesla MYP
    Yeah my gsr said bye. Found an ITR on a lot bought it and it blew in 7 days. I sued the dealer and they paid a local acura dealership to drop a fresh crate ITR engine in it.
    wish I had the receipt. Was like $9-10k
  9. Jan 25, 2023 at 7:04 AM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    I'd hope they're really good at what they do for $3K a pop for each of the four.
  10. Jan 25, 2023 at 7:05 AM
    Normal for this truck, but definitely more noticeable than my previous gen. The drain hole leaves big puddles after only a little while.
  11. Jan 25, 2023 at 10:11 AM
    Skidmarcx
    Glendale, AZ
    ‘22 SR5 CM
    You’re bringing back the good ole JDM days with a GSR and Type R those are awesome vehicles!
  12. Jan 25, 2023 at 2:30 PM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    I have noticed this too. Especially when my right foot gets heavy on a cold day. It must be the combo of turbos and the exhaust system.
  13. Jan 25, 2023 at 2:42 PM
    xc_tc
    xc_tc New Member
    I was going to say this. The muffler is huge. I only notice the cloud of white vapor when I’m in the mountains in the winter. I assume it’s just melting ice left over in the mufflers.
    ryanwgregg likes this.
  14. Jan 25, 2023 at 3:34 PM
    catalac
    catalac New Member
    It’s due to climate change.
