Been changing oil every 10k. Did this affect my car?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ealxele, Jan 24, 2023.
  1. Jan 24, 2023 at 3:31 PM
    ealxele
    ealxele [OP] New Member
    Hey all,
    After switching from going to the Dealership to a new mechanic, the mechanic recommended starting changing the oil change every 5K instead of 10K. I have been doing every 10K for 55,000 miles now. Do you guys think this affected my car in a bad way for doing it until 55,000 miles now?
    • Do you guys agree on changing it every 5K?
    • Also wondering which oil brand you guys recommend
    Thank you in advance!
  2. Jan 24, 2023 at 3:33 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
  3. Jan 24, 2023 at 3:39 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Depends on your usage, I've been changing mine at 10k and getting oil analysis. As for oil, any full synthetic oil would do, if you changing it every 5k, it doesn't matter the brand, as long as it's clean oil. Manual calls for 0W20, some swear by 5W30, I'm going to try out 5W30 when it's spring time here.
    ealxele[OP] likes this.
  4. Jan 24, 2023 at 3:44 PM
    AZBoatHauler
    So.Arizona
    5k miles OCI
    5w-30 Mobil1 but agree any brand will work.
    2mchfun and ealxele[OP] like this.
  5. Jan 24, 2023 at 3:51 PM
    Black4X2
    Black4X2 New Member
    2007 Black Tundra Limited 4X2
    My oil is pretty black by 5000 miles.
  6. Jan 24, 2023 at 4:06 PM
    Kung
    KG, VA
    I'd definitely change it every 5 to 6K.
    Funny story: I got 4 free oil changes when I got my truck in 2020. The first 4 they spaced out every 10K; I actually paid a bit extra to get it done more often.
    Once the last free one was done, I checked the 'next oil change' sticker they put in my truck.
    I flat asked the service department "Why is it I could NOT get y'all to change it before every 10K miles for the free ones...but now that I have to pay for them, they'll be every 5-6K?"
    Lots of whistling and looking around. LOL
  7. Jan 24, 2023 at 6:11 PM
    ealxele
    Interesting thought everyone was going to recommend 0W-20. How long have you been using using 0W-20 for?
  8. Jan 24, 2023 at 6:12 PM
    ealxele
    Why do you use 5W-30? So far I've been hearing everyone recommend 0W-20.
  9. Jan 24, 2023 at 6:12 PM
    ealxele
    Oh wow. Would you say you drive a lot compared to the average driver? I basically drove 50,000 miles in 2 years.
  10. Jan 24, 2023 at 6:14 PM
    ealxele
    LOL that's why I no longer want to support the Dealerships haha. Even the maintenance guide from the Tundra manual says to replace every 10K miles...that's why I thought I was doing it right.
  11. Jan 24, 2023 at 6:19 PM
    AZBoatHauler
    So.Arizona
    I live in the desert southwest so I don’t need the 0 weight cold protection. The valve train is soooooo much quieter / smoother on 5w-30.
  12. Jan 24, 2023 at 6:19 PM
    Ericsopa
    Ericsopa Old man and the sea
    Okay, I'll be the devil's advocate. 5000 miles is overkill, but it's your dime, so do as you please. And by the way, color has nothing to do with lubricity.
  13. Jan 24, 2023 at 6:29 PM
    This^^^^^^
  14. Jan 24, 2023 at 6:33 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I do 5k and the OEM filter using the cheapest full synthetic I can get. Sometimes it’s M1, sometimes it’s Warren. Once I’m out of warranty I’ll probably run it a bit longer, like 7-8k. 0w20 in the winter and 0w30 the rest of the year.
  15. Jan 24, 2023 at 6:58 PM
    mgrs
    mgrs New Member
    '20 OR
    I do it every 5k. Will stretch a little longer if all highway in a short time.
    The truck cost $43k, sticker is $48k
    Filter cartridges in bulk are $3-4 ea. Oil, even name brand synthetic, is ~$20/5qts if you shop around. Sometimes you get a roll of shop towels with that. Kirkland is even less. Total oil change cost is about 1/2 of a gas tank fill.
    Why not?
  16. Jan 24, 2023 at 7:00 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Car care nut recommends 5k or 6 months because of the piston rings.
    The manual says 10k but if you read more in depth, unless you do all highway miles with no stop and go or short trips, 90% of people qualify for 5k oil changes. 10k oil changes are a marketing gimmick to make cars seem cheaper to upkeep. The vast majority of people do not qualify for this. Generally speaking the less mileage you drive, the more likely you need to change oil every 6 months rather than by mileage alone.
    Plus, I look forward to my oil changes and giving the truck a good once over and making sure everything is perfect and torqued since I offroad as well.
  17. Jan 24, 2023 at 7:20 PM
    omgboost
    East Coast
    Almost 4 years using 0W20. First oil change I did at 8k intervals and after 2 changes, analysis came back good and was recommended to try 10K. Next one was changed at 10K and oil analysis still looked good. The manual also states if you drive under the special circumstances or driving conditions to change oil at 5k. And I agree, oil color is not a good indication of lubricity.
    Taco-Spike likes this.
  18. Jan 24, 2023 at 7:21 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
  19. Jan 24, 2023 at 7:50 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    Costco has their oil on sale for the next week or so ($8 off). It's only $1 more shipped than in the store (not going to the store is worth more than $1 to me and it's only about 5 mins away).
    TheBeast, Terndrerrr and Leo's first like this.
  20. Jan 24, 2023 at 8:03 PM
    pursuit2550
    pursuit2550 New Member
    I use 5w-30, so much quiter and better oil pressure, F&$K the EPA. As for 5-10k, I stick to 5k. Oil is cheap, a 5.7 isn't. I have heard, haven't looked into it, that oil analysis form like Blackstone doesn't really tell 100% of the story. I have heard, haven't look into it, that a full oil analysis is more in depth and more $$$. I know that Toyota had put some cheap oil rings and the high mile oil changes was causing havoc on those engines. I don't know if the 5.7 had those types of oil ring or not but like I said, oil is cheap. Plenty of car nuts will also tell you 5k.
  21. Jan 24, 2023 at 8:16 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Thanks for the heads up. 30 qts for under a hundo inbound
    WILLINH and MadMaxCanon like this.
  22. Jan 25, 2023 at 4:30 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Not mine and I can go 7000 to 8000 miles without having to add any.
  23. Jan 25, 2023 at 4:32 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Do you mean piston rings? Never heard of an oil ring.
  24. Jan 25, 2023 at 5:17 AM
    Bammer
    Monroe, CT
    5,000 mile OCI, switching to 0W30 in the spring.
  25. Jan 25, 2023 at 5:17 AM
    MadMaxCanon
    the bottom piston ring is the "oil ring"
    ejes, Mike59, ZappBrannigan and 12 others like this.
  26. Jan 25, 2023 at 5:38 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Oil (5W30) and filter change every 5 - 6k miles. To echo what pursuit 2550 posted earlier, oil changes are cheap; a replacement engine is not. Shorter interval oil changes are cheap insurance, IMO.
  27. Jan 25, 2023 at 5:49 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I run 5w30, 10k changes. Currently at 251k with plenty of great UOAs. I tow and off road as well. These engines are incredibly easy on oil.
  28. Jan 25, 2023 at 7:49 AM
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    Follow what the specs are on the vehicle.
  29. Jan 25, 2023 at 8:50 AM
    Rocko9999
    Rocko9999 New Member
    Yes and no. Can the blackest of black oil be 100% functional? Yes. Can the blackest of black oil have all it's additives degraded and no longer be providing high level of lubricity. Yes.
    2mchfun and JJtruckon like this.
  30. Jan 25, 2023 at 8:58 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Damage, not likely unless you were driving in dusty conditions. I've always changed at 5,000k with my current truck and my older 08. Have always used 0w20, plenty of rv towing and zero oil useage with either truck.
    Wallygator likes this.
