stock fog lights
Discussion in '2nd Gen Tundras (2007-2013)' started by turk, Jan 24, 2023.
  1. Jan 24, 2023 at 8:39 AM
    turk
    turk [OP] New Member
    greg
    millersville pa
    2011 platinum
    what does the fog light dial 1-6 do for the fog lights? no clue it is a mechanical adjustment because i replaced one already. also it not listed in the manual.
  2. Jan 24, 2023 at 8:41 AM
    Nothing. It is only for the headlights so that you can aim them down when you are hauling a heavy load.
  3. Jan 24, 2023 at 8:42 AM
    Taco-Spike
    Two Trucks
    You mean the dash dial? It's a headlight adjustment.
    Nothing for the fogs
  4. Jan 24, 2023 at 8:46 AM
    turk
    greg
    millersville pa
    2011 platinum
    don"t get it when i redid my lenses and led lights the used the adjusters in the lenses body?
  5. Jan 24, 2023 at 8:52 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You should be able to do fog light adjustments manually with a Phillips screwdriver..
    Taco-Spike likes this.
  6. Jan 24, 2023 at 8:55 AM
    The fogs are manual adjustments.
    1lowlife likes this.
  7. Jan 24, 2023 at 9:08 AM
    turk
    greg
    millersville pa
    2011 platinum
    234 you fogs are much newer version than the 2011s. i still don"t get the manual headlight leveling dial i must be thick?
  8. Jan 24, 2023 at 9:10 AM
    Taco-Spike
    Two Trucks
    Similar dial on non led fogs
  9. Jan 24, 2023 at 9:11 AM
    That is a general fog light photo showing what the manual adjustment looks like. Your fogs are manual adjustment and in no way tied to the dial on the dash.
    NewImprovedRon likes this.
  10. Jan 24, 2023 at 9:12 AM
    Put your truck facing a wall at night and turn the dial. You will see the headlight beams move.
  11. Jan 24, 2023 at 9:13 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    At night pull up to a wall, or even your garage if you have one, about 25 feet away.
    Turn the adjustment knob and watch the beams of your headlights raise and lower..
    WILLINH, Taco-Spike and Tundra234 like this.
  12. Jan 24, 2023 at 9:14 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    :eek2::rolleyes::cool::p:thumbsup:
  13. Jan 24, 2023 at 9:17 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    This 3 minute video should have been 1 minute long..:rolleyes:
    Starts at the important part..:D
    You can even see the beam moving on the white vehicle off to the right..
    https://youtu.be/nd1C51xvvek?t=113
  14. Jan 24, 2023 at 9:18 AM
    turk
    greg
    millersville pa
    2011 platinum
    i get it
    i will but the nogin is still thick i did not have and extra wires other than the stock light harness. but i will try thank you.
    1lowlife[QUOTED] likes this.
  15. Jan 24, 2023 at 9:20 AM
    turk
    greg
    millersville pa
    2011 platinum
    thanks that is loud and clear because lat winter my headlights were much higher in the distance level . you made my day thank you.
    WILLINH and 1lowlife[QUOTED] like this.
  16. Jan 24, 2023 at 9:38 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    No problem.
    After my 2.5 front lift/level I had to turn mine down a couple of numbers, as I kept getting flashed by oncoming vehicles.
    For me, the best way to adjust these is when you're at a stop light or sign and you have say a Camry-sized vehicle in front of you.
    I adjust the top of my low beams just to where they are just below the bottom of the back window and just under their side mirrors..
    Not very technical, but it works for me..
  17. Jan 24, 2023 at 2:33 PM
    turk
    greg
    millersville pa
    2011 platinum
    i just check them out with the video and worked perfect thanks.
