Variable runner intake for 2000-2002 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by dirtydeeds, Jan 23, 2023.
  1. Jan 23, 2023 at 10:08 PM
    dirtydeeds
    dirtydeeds [OP] Exhaust Fabricator Vendor
    Keith
    USA
    more than I can list here
  2. Jan 24, 2023 at 3:54 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Cool.
    Do you have dyno results before and after?
    Jack McCarthy likes this.
  3. Jan 24, 2023 at 6:46 AM
    dirtydeeds
    Keith
    USA
    None. I don’t make the intake, Toyota did, and it made more power. I Only make the adapter. It’s too inexpensive of a part which will be sold in too low a volume to make it worth it to ‘prove’ that it makes more power. But it’s part of why the 05-06 is good for 40 more Hp. You’ll just have to go off anecdotal gains reported by literally everybody whom has ran one so far
    tvpierce[QUOTED] likes this.
  4. Jan 24, 2023 at 6:56 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    03 - 04 owners
    455h0le_dachshund and NWPirate like this.
  5. Jan 24, 2023 at 6:59 AM
    dirtydeeds
    Keith
    USA
    It’s a direct bolt on for 03-04 trucks no adapter needed. Just use the 05-06 throttle body it’s sore plug n play:)
  6. Jan 24, 2023 at 7:07 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    It would be interesting to see where it moves the torque curve without the dancing cams.
  7. Jan 24, 2023 at 7:09 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Nice video Keith! Looks like a high-quality product.
    note for people interested - If you have an all-aluminum radiator (Mishimoto, CSF, etc) that is thicker than the stock rad, the intake pipe is not going to fit. My stock intake '00 makes contact with the fan shroud simply with the additional thickness of the radiator. Add the thickness of that spacer and there is no way it will clearance.
    daveeasa and dirtydeeds[OP] like this.
  8. Jan 24, 2023 at 7:31 AM
    @Sunnier upgraaaade upgrade!
    @dirtydeeds no money shot of startup?! I feel so robbed after investing all that time watching the install :rofl:
  9. Jan 24, 2023 at 8:08 AM
    Sunnier
    Sunny
    San Diego, CA
    Hmmn. We’re planning to appear at Superstition this weekend. Maybe someone with a YouTube account can post a vid. I gotta say though, I really tied Keith’s hands. I LOVED the low key rumble Hulk had at start up after Bruce cut the tailpipe after the cats and OEM muffler and added a ~ 9” downturn. I wasn’t going for dude sound and pleaded with Keith to get it as close as possible to the original.
    *so Keith doesn’t have to
  10. Jan 24, 2023 at 8:14 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Yea, forget a startup vid, i wanna hear the transition from long to short runner at WFO under full load.
    455h0le_dachshund likes this.
  11. Jan 24, 2023 at 2:19 PM
    tvpierce
    Maine
    Not to be a hater, but there's also variable valve timing on the '05-'06.
  12. Jan 24, 2023 at 2:48 PM
    Indeed. Curious if the variable intake runners are coordinating with the VVTi (highly likely) to produce the additional power. Sounds like there is a noticeable difference, although anecdotal. This is like the 12 hole injectors that have lots of performance claims, but haven’t seen any real evidence to support it. Cool to have tinkering options, appreciate anyone from industry that is still interested in supporting the FGT platform, so for that, thank you.
  13. Jan 24, 2023 at 3:05 PM
    dirtydeeds
    Keith
    USA
    This is true. Which is a big part of the gains. But I have personally tested just the intake. So have others. It’s a great mod for the money.
  14. Jan 24, 2023 at 3:07 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Does the variable intake upgrade help in low-end torque at all, or just higher RPMs?
  15. Jan 24, 2023 at 3:08 PM
    dirtydeeds
    Keith
    USA
    Find somebody with:
    05-6 intake
    Throttle body coolant bypass
    Stock air box mod
    Dirtydeeds injectors
    Plugs n coil packs
    AND RACE THEM from a dig and a roll. You’ll make plans to do the above things as you stare at their taillights;)
  16. Jan 24, 2023 at 3:08 PM
    dirtydeeds
    Keith
    USA
    Only helps mid range to top end. Anytime there isn’t vacuum in the intake it goes short runner.
  17. Jan 24, 2023 at 3:52 PM
    tvpierce
    Maine
    Very cool!
    Hope my first post didn't come across as negative. Just asking.
    Thanks for developing new products for our older trucks.
  18. Jan 24, 2023 at 4:41 PM
    dirtydeeds
    Keith
    USA
    Ha! Not at all:) I’m happy to hash out ideas. This is what has caused things like this to be built.
  19. Jan 26, 2023 at 1:51 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    New question. Temp comparison aluminum vs plastic. Heatsoak, you know.
  20. Jan 26, 2023 at 7:16 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
  21. Jan 26, 2023 at 9:02 PM
    daveeasa
    So we with mishimoto radiators are SOL?
  22. Jan 29, 2023 at 10:33 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I did some more peeking under my hood, and I think stock intake tube might fit. aftermarket intake definitely not as it is already rubbing the fan shroud.
    daveeasa[QUOTED] likes this.
  23. Jan 29, 2023 at 11:44 AM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    If you put electric fans on like I did, you should have plenty of room.
    AP0eX8rIBxPeB0AE5mgUVXv1Iex0BzYCAe7oepPH_c402769a61c19d865aab93431d772c9a1b6a8367.jpg
  24. Feb 22, 2023 at 10:37 AM
    Ethansm00
    Ethansm00 New Member
    2002 AC Tundra SR5 4x4
    When/where is this available for purchase? Seems like the only option out there for my 2002 to swap the later intake on.
    Also to anyone running it, has this produced any notable change in milage?
    dirtydeeds[OP] likes this.
  25. Feb 22, 2023 at 10:58 AM
    Mustanley
    Hendersonville, NC
    It's there in the opening post.
  26. Feb 22, 2023 at 11:04 AM
    Ethansm00
    I saw that but figured it wasn’t an urgent enough question to call him. And given how little information I could find on this topic elsewhere it would be a nice reference for others if the answers were posted publicly for now.
  27. Feb 22, 2023 at 12:48 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Buy it from him, keep in mind Dirty Deeds is a business and Keith/ DD likely did all the R&D for this which costs money and time.
    Otherwise do your own legwork.
    FrenchToasty and SAGE63 like this.
  28. Feb 23, 2023 at 7:34 AM
    dirtydeeds
    Keith
    USA
    Ethansm00[QUOTED] likes this.
  29. Feb 23, 2023 at 8:29 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh.... my.
    :spending:
  30. Feb 23, 2023 at 2:05 PM
    bfunke
    bfunke Tundra Curmudgeon
    I wish I could unsee that blue water pump…
