General Supercharger Thread
  1. Jan 23, 2023 at 11:38 AM
    #5131
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Same reason I never did it, living in CO. And I'm too lazy to do and then undo the same mod every year lol
    Silver17[QUOTED] likes this.
  2. Jan 23, 2023 at 11:49 AM
    #5132
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Could always get some extra hose, 2 Y or Tee fittings and 2 ball valves and open and close the bypass as the weather changes. Actually would be pretty easy.
    M3Tundra-JK[QUOTED] likes this.
  3. Jan 23, 2023 at 11:57 AM
    #5133
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm in Phoenix & have done it to every car I have had, it's supposed to freeze tomorrow through.
    The hose clamp is holding the pump to the basket? If so, did you make a cut for it to exit/return inside the basket?
    Silver17[QUOTED] and M3Tundra-JK like this.
  4. Jan 23, 2023 at 12:00 PM
    #5134
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  5. Jan 23, 2023 at 12:18 PM
    #5135
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    I did that as soon as I got the truck. I’ve never had any issues. Even like 2 years ago when Texas had that crazy cold weather and half the state lost power and water because it was 0 degrees or below zero degrees for two weeks straight, it didn’t have any issues.
    Silver17 and M3Tundra-JK[QUOTED] like this.
  6. Jan 23, 2023 at 12:52 PM
    #5136
    M3Tundra-JK
    Scott
    2005 GX470
    3d printed Stillen 4.5" Air intake adapter came in. The 4.5" side is pretty thin though. Could definitely make it thicker. Will probably snap if too much pressure to the hose clamp is applied. Everything else looks and feels good, though! it's something to work with.
  7. Jan 23, 2023 at 1:04 PM
    #5137
    M3Tundra-JK
    Scott
    2005 GX470
  8. Jan 23, 2023 at 1:58 PM
    #5138
    snivilous
    SW UT
    300k+ Supercharged 2008
    Yes, that's how the URD instructions say to do it, cut some slits and zip tie the pump to the side. Mine is the same way. A bit janky but no issue with two pumps now and a few years.
    e30cabrio[QUOTED] likes this.
  9. Jan 23, 2023 at 5:25 PM
    #5139
    AZTundra
    Paul
    Phoenix, AZ
  10. Jan 23, 2023 at 5:29 PM
    #5140
    e30cabrio
    AZTundra[QUOTED] likes this.
  11. Jan 23, 2023 at 5:58 PM
    #5141
    M3Tundra-JK
    Scott
    2005 GX470
    That's a solid price. I paid $3500 from a forum member for the main assembly with no miles on it and no kit parts.
    The intercooler can be had through Toyota for $750
    Edit:. Looks like you'd also have to buy the intercooler pump, hose kit, wiring kit, and a few brackets. All that is gonna run another $500ish if I remember correctly. Would also want to know how many miles, and I'd that's a scratch or crack on the bottom.
    Edit edit: and the fuel pump. Can't really tell what's wrapped up in the back left
  12. Jan 23, 2023 at 6:12 PM
    #5142
    e30cabrio
    All that plus the fear it's in need of a rebuild is why it's not in my garage (along with a ton of other parts)
    lol
  13. Jan 23, 2023 at 6:19 PM
    #5143
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    I did the TB coolant bypass when I installed my Harrop. Not sure if it helped any, but one Sat morning when it was in the teens here, I hit the interstate going to the exhaust shop for some work. About 35 minutes at 85-90 mph and when I get off the interstate and head up the mountain it starts bogging. Won't go unless I give it more than half throttle. I got over the hill and stopped, checked it out under the hood. Nothing was loose or strange looking so i limped it another 3-4 miles to the shop. Left an hour later expecting problems but it was fine. Never has done it again. I think the blade must have been sticking, but have no proof. The TB sitting up high, it probably gets cold with a lot of air moving through the engine bay. Stop and go driving it probably would never matter, but who knows? I still have the TB bypassed.
    e30cabrio and M3Tundra-JK like this.
  14. Jan 23, 2023 at 6:39 PM
    #5144
    M3Tundra-JK
    Scott
    2005 GX470
    Screenshotting this for the front page or editing later. But at a minimum besides the main assembly, these are parts I've had to.buy from Toyota for the TRD assembly. Doesn't include any of the things I've upgraded separately.
    snivilous[OP] and e30cabrio like this.
  15. Jan 25, 2023 at 11:54 AM
    #5145
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    question... I have a 2008 Tundra with forged internals and (rebuilt)TRD SC. I'm getting ready to to add xat harmonic balancer and a fuel system. I've tried to contact Dustin @ DAP tuning in TX but the phone number is disconnected and no return email. That is who I wanted to do it. So.. I'm looking for suggestions who can tune factory ECM without a engine management system to achieve upper 800 lower 900s in hp with my set up.
  16. Jan 25, 2023 at 11:56 AM
    #5146
    M3Tundra-JK
    Scott
    2005 GX470
    Overland Tailor Tunes is who some of us use. There are a few other options as well, but I forget the names
    Saltyhero13 and Silver17 like this.
  17. Jan 25, 2023 at 11:57 AM
    #5147
    nags
    nags New Member
    Don't bother with DAP. Find anyone else.
    Saltyhero13 likes this.
  18. Jan 25, 2023 at 12:01 PM
    #5148
    Silver17
    Eastern PA
    I got a response the beginning of the month from DAP on adjusting my tune for my larger intake, but haven’t heard back again since. He does great work but the customer service is just painful. If I don’t hear back I’ll be reaching out to my local OTT tuner as well. They seem like the next best remote tuning option as long as @ViktorG is out of the game for the time being.
    M3Tundra-JK likes this.
  19. Jan 25, 2023 at 12:02 PM
    #5149
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    I tried getting him also since I live there but couldn’t ever get a hold of him. He finally responded to my email after OTT was already working with me. Is prospeed wanting you to buy their motec?
  20. Jan 25, 2023 at 12:03 PM
    #5150
    nags
    nags New Member
    Don't forget Dan Hardman.
  21. Jan 25, 2023 at 12:07 PM
    #5151
    Silver17
    Eastern PA
    I didn’t realize he was in the tuning game. He has tuned other peoples trucks?
  22. Jan 25, 2023 at 12:14 PM
    #5152
    sctomfar
    Tom
    Bluffton, SC
    I found OTT too... I'm waiting on them to get back to me.
  23. Jan 25, 2023 at 12:15 PM
    #5153
    nags
    nags New Member
    I believe he's done a few. He helped me a little with mine.
  24. Jan 25, 2023 at 3:26 PM
    #5154
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Let us know how it goes. I’m currently looking for a tuner and can’t believe how difficult it is to get someone to reply.
  25. Jan 25, 2023 at 3:31 PM
    #5155
    M3Tundra-JK
    Scott
    2005 GX470
    TBH, OTT has been a little slow to respond as well. I've been working with them for the last few weeks to get my tune started. From time I used their online form, to getting contract worked for me to sign was about three weeks. And I haven't gotten my invoice to pay them yet either, let alone start on the tune. BUUT, they now have the only tuner I've personally worked with in the past, and he is super active on the Tacomaworld forums. I have nothing but positive things to say about his tuning abilities and knowledge (Justin aka @JustDSM on tacomaworld)
  26. Jan 25, 2023 at 3:36 PM
    #5156
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    They’ve always invoiced me at the end
  27. Jan 25, 2023 at 3:42 PM
    #5157
    sctomfar
    Tom
    Bluffton, SC
    I feel honored... he emailed me within a couple hours... I found a Prospeed Automotive in NJ, but I think I am going to try working with OTT first.
  28. Jan 25, 2023 at 3:57 PM
    #5158
    Silver17
    Eastern PA
    Was it Allan Hish?
  29. Jan 25, 2023 at 4:10 PM
    #5159
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Dropping the tank and pulling the Ti 450 fuel pump out. For some reason while WOT it's not supplying enough.. afr's look good under normal driving conditions.
  30. Jan 25, 2023 at 4:37 PM
    #5160
    M3Tundra-JK
    Scott
    2005 GX470
    What other fuel upgrades do you have?
    snivilous[OP] likes this.
