Tire upgrade on 20” TSS wheels
Discussion in 'Wheels & Tires' started by erow1893, Jan 23, 2023.
  1. Jan 23, 2023 at 8:23 AM
    erow1893
    erow1893 [OP] New Member
    Ethan
    2020 tundra SR5 TSS off-road
    2020 tundra 4x4 TSS off-road. Recently purchased Bilstein 6112 front coilovers paired with 5160 rear shocks. Once installed, I should be nearly level.
    Question is, what is the largest tires I could run once the truck is leveled, keeping the same stock TSS 20” wheels? Prefer not to do any trimming, but open to some minor plastic trimming. Thanks!
  2. Jan 23, 2023 at 9:52 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    I had a 2016 Sport with TSS wheels running 295/60r20s leveled with Bilstiens on top setting and no spacers. Rubbed a little on the skid plate and fixed by bending the plate edges down.
  3. Jan 23, 2023 at 10:02 AM
  4. Jan 23, 2023 at 10:41 AM
    erow1893
    Ethan
    @MaxYota thanks for the info. I’ll have the bilsteins set on the 2nd highest height, 1.9” front lift I believe.
  5. Jan 23, 2023 at 10:51 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    my 6112's are there too and i'm currently on 275/65/20's. I was able to push liners and adjust flaps to make it all work without rubbing on what are a narrower tire but i suspect wider tires are going to be a tougher fit.
    Hbjeff likes this.
  6. Jan 23, 2023 at 10:56 AM
    erow1893
    Ethan
    Sounds good, thank you. I just see so many conflicting statements on what can and can’t fit based on minimal trimming.
  7. Jan 23, 2023 at 11:13 AM
    PlatinumPro
    yea despite our trucks being built with similar spec's the angles and numbers don't all work out to be the same so while it may not rub on one you could have serious scrubbing on another even with the same wheel tire packages.
