  1. Jan 21, 2023 at 9:15 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    So I jumped on the SABM bandwagon. I couldn’t get the dang new intake tube to fit to the right of the OEM ground, the hole is drilled in the box as far to the rear as it could go. I made a new ground after sanding the paint to bare metal, then sprayed with Blue Ribbon. I traced the hole onto the metal while the box was reinstalled, cut it out, painted, and mounted the new intake port.
    These pics are before I siliconed everything for airtightness, I figure that’s how to eliminate any whistles while on the throttle. There was quite a bit of trial and error to be able to get everything to fit snugly and cleanly, while being able to mount everything correctly.
    I noticed a definite deeper tone in the motor sound. I can’t say for sure, but it seems the shifts are smoother, but my butt dyno may be on the fritz.
    4E299C3E-75B0-40DF-99FC-D6A36819FC0F.jpg 2D66F661-5FC7-4452-B9B9-196E222B92E3.jpg 5B08D45B-9E21-4B4B-962F-099F515F424D.jpg ACF54C7F-293A-47DF-8CAD-59A99C4087F4.jpg
  2. Jan 21, 2023 at 10:39 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Sweet!
    1UP and reywcms[QUOTED] like this.
  3. Jan 21, 2023 at 10:40 PM
    RainMan_PNW
    Casey
    Clark County, WA
    If there was one around there I would have - bit out in the boonies for that though
    BlueRibbon4x4[QUOTED] likes this.
  4. Jan 21, 2023 at 11:09 PM
    jgutierrez89
    jgutierrez89 New Member
    Jose
    San Diego
    2021 White Crewmax TRD Sport
    Picked up a full set of Husky Mats and the Toyota bed mat from @pickupjason earlier today. From what I can tell these are so much better than the Weathertech's I have in my other truck.
    IMG_4334.jpg IMG_4333.jpg 69604645929__06BBD2BD-F28D-48E0-B81F-A40DB88797E1.fullsizerender.jpg 69604266772__275393EE-7944-4BB8-B7B1-11DCF4DB0D5C.fullsizerender.jpg
  5. Jan 22, 2023 at 6:50 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Nope. First picture = those are your rear cats and they look to be accessible.
  6. Jan 22, 2023 at 9:26 AM
    Cthulhu
    Love the upgrade, but most of all, now my entire dash is
    Before:
    After, with two different pics of my truck as the “car logo”:
  7. Jan 22, 2023 at 12:59 PM
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    + 1 on the Husky's., prefer over WT, but even those are still an upgrade over stock.
  8. Jan 22, 2023 at 1:12 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Just got my set too, love every inch of it. Much easier to clean and vacuum.
    cartage1 likes this.
  9. Jan 22, 2023 at 1:17 PM
    Odin43
    Odin43 YNWA
    Rich
    NJ
    2021 MGM Platinum, 2015 Lexus LX 570
    That’s pretty sick.
    Cthulhu[QUOTED] likes this.
  10. Jan 22, 2023 at 1:37 PM
    Mission Critical
    Mission Critical New Member
    2014 TRD
    Morimoto headlight install for the win. Can't say it was super easy. Maybe an hour and a half job. Pulling the grill off wasn't fun and it does sound like something is breaking. Just plugged everything in that needed to be plugged in. Didn't use the fuse tap or any adapters and everything seems to be working with no errors.
    GAknight, saybng, ZackRP and 12 others like this.
  11. Jan 22, 2023 at 2:44 PM
    Hogansheroes
    Hogansheroes New Member
    Josh
    Northern Wisconsin
    2019 Tundra CM TRD Sport
    Finally got around to installing the lift. Just need to get it in for an alignment now. Rear add a leafs added almost 2”, and the front 2.0s added almost 4”. Im sure they will settle a bit
    3724AEFA-BF5B-425F-99FD-1C85508D58FB.jpg 51FEE6B9-9043-4221-83C5-3656E3487A22.jpg E6779E92-523D-45FF-9F6A-4C7C6C4382CA.jpg
    GAknight, Skolberg, Jcmf52 and 11 others like this.
  12. Jan 22, 2023 at 2:59 PM
    They may change slightly with the alignment but the height will stay the same. Did you put the ball joints in Config D? Also, take that sheet with you when you go in for the alignment. Some shops are not familiar with the adjustments on the SPC's.
    AggiePhil, the red and bulldog93 like this.
  13. Jan 22, 2023 at 3:06 PM
    Hogansheroes
    Josh
    Northern Wisconsin
    Yes I did put them in config D. Still seems quite a bit off for camber. I saved the sheet hopefully get it done early this week.
  14. Jan 22, 2023 at 3:12 PM
    Yes it will be quite a bit off. They shouldn't have to mess with the ball joint setting at all. D is the most common starting point for these trucks. I've had my Aluma setup for almost 3 years now. I have the older rear shocks though....with the remote resis.
  15. Jan 22, 2023 at 4:46 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I paid it off. I’m so excited about it!
  16. Jan 22, 2023 at 4:47 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Best feeling ever!
    hi_rawb, cartage1, RusPro21 and 4 others like this.
  17. Jan 22, 2023 at 4:50 PM
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    Man, must be nice. I was planning on finishing mine off at Christmas but then my wife thought it was a good idea to take the kids to Disney World this March. :mad:
  18. Jan 22, 2023 at 5:17 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    I hear ya. It was no easy task. Things and money will come and go, memories last a lifetime.
  19. Jan 22, 2023 at 9:02 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Here’s some footage of the beach run during Baja. Chase truck had a hard time keeping up but this was about 70-80. Definitely caught air in a few spots in this vid.
    https://vimeo.com/791766697
    saybng, ssmokedz, rocsteady and 23 others like this.
  20. Jan 22, 2023 at 9:31 PM
    SAGE63
    San Diego County
    too cool wish I could have made it work out...
    what suspension are you running
    reywcms[QUOTED] likes this.
  21. Jan 22, 2023 at 11:22 PM
    AZBoatHauler
    So.Arizona
    Saw pics of @reywcms running Baja motivated me to finally ditch my FSB. First time the truck has ever lost weight.
    :yes:
    BlueRibbon4x4, bulldog93 and reywcms like this.
  22. Jan 23, 2023 at 2:52 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hahaha
    AZBoatHauler[QUOTED] likes this.
  23. Jan 23, 2023 at 2:53 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Camburg heimed LT kit up front with 2.5” king coilovers and 2.5 king triple bypasses. Rear is a custom bedcage with King 3.0x16” triple bypass and deaver i96 spring under along with 2.0 king bump stops.
    Toe404, mgm16trdpro, SAGE63 and 2 others like this.
  24. Jan 23, 2023 at 6:32 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Congratulations! I paid mine off last year..... now if I can avoid buying something else to make payments on....
  25. Jan 23, 2023 at 7:04 AM
    Taco-Spike
    Two Trucks
    :101010:
  26. Jan 23, 2023 at 7:18 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Congrats!!
    Tyman[QUOTED] likes this.
  27. Jan 23, 2023 at 7:20 AM
    Ordered a ScanGauge 3. Once it arrives tomorrow, I'll take a look at the mount and see what it looks like. ICS can make a custom mount for it to fit on the Rago dash plate.
    texasrho83 and bulldog93 like this.
  28. Jan 23, 2023 at 7:47 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Congratulations. That’s the best mod !
    Tyman[QUOTED] and cartage1 like this.
  29. Jan 23, 2023 at 8:53 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Just mounted the 35/12.5 BFG KO2s. Yes there is slight rubbing on the driver side plastic in reverse but that can be corrected. I have a set of Falcon tow/haul shocks set at level with a 1" Coachbuilder shackle and Coachbuilder Bumper shims. Stock Upper Control Arms.
    GAknight, superdenk, 16TRD and 15 others like this.
  30. Jan 23, 2023 at 9:30 AM
    RustyShackle323
    Stewart
    NC
    Looks great!
    Side note, are those OEM fender flares? I really would like a pair of those in the Barcelona red but haven’t found any. Did they come on your truck or did you purchase them somewhere?
