General Supercharger Thread
  1. Jan 20, 2023 at 1:14 PM
    #5101
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I got the 1/4” hole mesh instead of the 3/16”. Probably should have got the 3/16” but oh well, should still help.
  2. Jan 20, 2023 at 5:52 PM
    #5102
    Silver17
    Eastern PA
    Screen is cut and mounted in the magnuson lid. Just have to figure out what I want to use to hold it permanently, either and epoxy, silicone rivets etc. It is in there tight, just taking precautions. Maybe tomorrow I can do the stock airbox and drive it around.
  3. Jan 20, 2023 at 6:20 PM
    #5103
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Nice!
    Silver17[QUOTED] likes this.
  4. Jan 20, 2023 at 6:33 PM
    #5104
    Saltyhero13
    Saltyhero13 Throbbing Member
    Looking forward to seeing your findings.
  5. Jan 21, 2023 at 2:19 PM
    #5105
    Silver17
    Eastern PA
    I got the honeycomb installed on the stock 3.5” intake and drove around. The furthest it can be mounted in the lid from the MAF is about an inch away which is not ideal. No noticeable issues or improvements were noticed. I do believe the tune should really be adjusted with the more uniform flow across the MAF though.
    I say this because I had pending codes of the P0101, and for the first time ever the P0103 code. The P0103 is the code that is from exceeding the voltage limit for greater than 3 seconds. I did 1 pull and it triggered that code as pending. I also noticed it was going into throttle enrichment with much less throttle/load than usual. All of these things tell me the MAF is actually reading more airflow with the screen (probably just because it’s more uniform across it) than it was without the screen. I’d have to do some real data logging and tune adjustments with the screen installed to see the benefits I believe, and I won’t be doing that since I’ll be changing out the intake soon. The AFR was still erratic, but I can’t say it wouldn’t possibly be improved if the MAF was retuned with the screen. For all I know it’s my gauge, or where the O2 sensor is located that is the root of the erratic AFR reading. Just wanted to share the findings! For now I’ll be removing it from the intake since the tune clearly needs adjustment to use it.
    One final thing to mention is I did 1 dragy after reviewing my video of the AFR and noticing my 0-60 rolling into the throttle in 2x4 was about equal to my 0-60 brake boosting in 4x4. I had a totally full gas tank, and it was a couple degrees warmer out than my previous best run and it did a 4.68 w/rollout, which is just behind my best run of 4.61 with less gas in the tank. It definitely didn’t hurt!
    M3Tundra-JK and Saltyhero13 like this.
  6. Jan 21, 2023 at 2:39 PM
    #5106
    Saltyhero13
    @Silver17 Thank you for driving to Mexico to test this product.
    mZiggy and Silver17 like this.
  7. Jan 21, 2023 at 2:47 PM
    #5107
    Silver17
    Eastern PA
    Lol I did make an adjustment to some details... All testing was done on private land of a family members business. :thumbsup: The dragy slip can be posted to the private dragy conversation if desired.
  8. Jan 21, 2023 at 2:49 PM
    #5108
    Saltyhero13
    :D
  9. Jan 21, 2023 at 3:01 PM
    #5109
    Silver17
    Eastern PA
    Don’t let this distract you from the fact that Hector is going to be running three Honda civics with spoon engines, and on top of that, he just went into Harry’s and bought three t66 turbos with nos, and a motec exhaust system.
  10. Jan 21, 2023 at 3:58 PM
    #5110
    Wapiti_chaser77
    Wapiti_chaser77 New Member
    Beeeowww
    2001 tundra trd o/r 4.7
    Factory TRD supercharger, full length headers, etc.
    So I haven’t read through all of the pages of this thread, but I haven’t really seen any 2uz supercharger setups being discussed. I have a little dilemma right now with my 01, as far as the wiring harness goes for the trd supercharger. Truck has 75k on it, and the previous owner put the unichip piggyback modules on it. The main truck ecu ended up being fried, and I have the trd ecu that came with the dealer-installed supercharger kit. I just installed a brand new main ecu, and I want to install the original trd piggyback. I’m assuming the stock s/c ecu was removed because the previous owner took it out when he added headers and methanol. I ripped out the methanol system, etc.. Can anyone tell me or point me to where these cut wires need to connect at? I’m assuming the black/white goes to black/white, along with the black/red to black/red. The red wires I’m not sure of, and especially the little red wire that’s by itself. I don’t have any of the original trd manuals that came with the kit, annd I’ve done a bunch of digging into this. Any feedback is greatly appreciated! Thanks guys.
  11. Jan 21, 2023 at 4:20 PM
    #5111
    M3Tundra-JK
    Scott
    2005 GX470
    Also looking for wire help.
    Can any Magnuson owner get a pic of how this yellow wire runs into and out of the fuse box? Having trouble fishing it through.
  12. Jan 21, 2023 at 6:05 PM
    #5112
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Here's mine...goes under the fuse box...
    M3Tundra-JK likes this.
  13. Jan 21, 2023 at 6:21 PM
    #5113
    M3Tundra-JK
    Scott
    2005 GX470
    Thanks! Ya both sets of instructions I have show them fishing it through where those bottom two silver fuses are, like they didn't exist. Didn't see any way to get it fished through without a lot of effort taking the box apart
    HulkSmurf14[QUOTED] likes this.
  14. Jan 21, 2023 at 8:26 PM
    #5114
    snivilous
    SW UT
    300k+ Supercharged 2008
    I think you'll have better luck posting on the 1st gen sub forum, though maybe some of the 5.7 guys had a 4.7 back in the day and can advise...
  15. Jan 21, 2023 at 9:20 PM
    #5115
    Wapiti_chaser77
    Beeeowww
    Yeah, that definitely crossed my mind, but I saw the thread title and figured I’d give it a chance. Thank you for the feedback!
  16. Jan 21, 2023 at 11:31 PM
    #5116
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Wait he’s here too!? Lol Just finished our Baja run
  17. Jan 22, 2023 at 10:40 AM
    #5117
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I got the 450-2, it's tight but expands at the bottom, do I need to dremel the basket or how did people get it in?
  18. Jan 22, 2023 at 10:43 AM
    #5118
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
  19. Jan 22, 2023 at 10:57 AM
    #5119
    e30cabrio
    So simple a caveman can do it, unfortunately, I'm dumber than a cave man!
    Thanks!
  20. Jan 22, 2023 at 11:24 AM
    #5120
    M3Tundra-JK
    Scott
    2005 GX470
    Hey I'm also doing gas tank stuff today.
  21. Jan 22, 2023 at 4:31 PM
    #5121
    M3Tundra-JK
    Scott
    2005 GX470
  22. Jan 23, 2023 at 8:04 AM
    #5122
    snivilous
    SW UT
    Someone post a picture of their Harrop and @reywcms post a picture of the Whipple
    HulkSmurf14, nags and reywcms like this.
  23. Jan 23, 2023 at 8:07 AM
    #5123
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Whipple will be in soon. Dropping the truck off this week
  24. Jan 23, 2023 at 8:11 AM
    #5124
    snivilous
    SW UT
    And thank you to @V10Ace and @M3Tundra-JK for the photos and links, I've added those to the front page.
    HulkSmurf14, V10Ace and M3Tundra-JK like this.
  25. Jan 23, 2023 at 8:36 AM
    #5125
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
  26. Jan 23, 2023 at 8:49 AM
    #5126
    nags
    nags New Member
  27. Jan 23, 2023 at 10:00 AM
    #5127
    Silver17
    Eastern PA
    For the Harrop belt info, I just ordered one this weekend so hopefully this info is correct. It appears to be a 117.7” belt. I ordered the Gates HD fleet-runner and it’s a K081177HD. The standard Gates my kit came with was a K081177. I think they’re now shipping out kits with continental belts which is a 4081177 which I had trouble finding to order online.
    snivilous[OP] likes this.
  28. Jan 23, 2023 at 10:55 AM
    #5128
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  29. Jan 23, 2023 at 11:16 AM
    #5129
    M3Tundra-JK
    Scott
    2005 GX470
    Silver17 likes this.
  30. Jan 23, 2023 at 11:32 AM
    #5130
    Silver17
    Eastern PA
    I think I have to steer clear of it in my local climate. I’d be surprised if it makes a huge difference, but I’d love to hear about it if someone did some testing.
