Help on wiring new stereo!
Discussion in 'Audio & Video' started by Red406Tundra, Dec 11, 2022.
  1. Dec 11, 2022 at 10:59 AM
    Red406Tundra
    Red406Tundra [OP] New Member
    Billings, MT
    2019 Barcelona Red SR5
    I’m in the process of installing Jensen stereo and can’t figure out pink wire. Diagram shows pink on radio side “parking brake (-)” plus has tag saying VSS. On the Crux adapter side it shows red/white (looks pink to me) reverse trigger. Would they go together? TIAimage.jpg
  2. Dec 11, 2022 at 1:23 PM
    Red406Tundra
    Billings, MT
    Still looking for answers. But it’s working.
  3. Dec 11, 2022 at 1:30 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is it your e-brake bypass?
  4. Dec 11, 2022 at 2:09 PM
    Red406Tundra
    Billings, MT
    No not sure how to bypass it
  5. Dec 11, 2022 at 2:42 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    VSS is vehicle speed sensor and is used by the head unit to lock out (or unlock) certain functions based on if you are moving or in park.
    The reverse trigger is for turning on your backup camera
    They are separate functions.
    Red406Tundra[OP] likes this.
  6. Dec 11, 2022 at 6:21 PM
    Red406Tundra
    Billings, MT
    Do you know what the vss is connected to?
  7. Dec 14, 2022 at 11:56 AM
    Red406Tundra
    Billings, MT
    I got great help from Crux. Everything is working and excellently too. So much better than stock one.
  8. Jan 21, 2023 at 12:24 PM
    schosports
    schosports New Member
    BIll
    Bel Air, MD
    2014 CM
    So where did CRUX tell you where the “VSS” gets connected to? Mine, like yours, is pink, not red/black as on the direction sheet, and mine also says “PHONE MUTE” printed on the wire.
  9. Jan 21, 2023 at 3:43 PM
    Red406Tundra
    Billings, MT
    They told me it was not needed. So I capped it off.
  10. Jan 21, 2023 at 3:58 PM
    schosports
    BIll
    Bel Air, MD
    2014 CM
    Awesome. Thank you!
