"just replace the CV axle yourself. It won't be bad" I told myself...
Discussion in '2.5 Gen Tundras (2014-2021)' started by ShelbyMedicRN, Jan 21, 2023.
  1. Jan 21, 2023 at 12:29 PM
    ShelbyMedicRN
    ShelbyMedicRN [OP] New Member
    2014 White Tundra
    6" lift, 35x12.5x20 rims and tires
    Holy. Crap. Passenger front CV axle replacement.
    The two bolts on the underside of the control arm are SOOOO hard to get out. I then found out why; they're torqued to 219 ft lbs! Then I had to rent a socket set from AutoZone for the axle nut; because who in the absolute world has a 39mm impact socket sitting around (which by the way, is torqued to 249 ft lbs?? Then I had to hammer the heck out of the CV axle to get it out.
    And then. Oh lordy. Getting the new CV axle in was an absolute beast. I bet I slid it back and forth, side to side, shaked and rattled, a hundred times and could not get it past that ring on the end of the splines. I used grease to try and center the ring but I don't feel that helped much. Finally, the angels came down from heaven and allowed the axle to slide right into place.
    Once the axle was in, it didn't take me long at all to put everything back together.
    My number one lesson from this job was, "big trucks require big tools".
    Also, this is my first post. Thanks for having me.
  2. Jan 21, 2023 at 1:29 PM
    centex
    centex New Member
    Who doesn’t have a 39mm impact socket? And that’s not even my biggest.
    Kinda surprised it was that difficult. I get breaking bolts loose but that’s what impacts are for. The ring is definitely a pain in the butt. They either fall right or fight to the death. There’s no in between.
    ColoradoTJ and ZappBrannigan like this.
  3. Jan 21, 2023 at 2:56 PM
    Chip_Tundra
    Chip_Tundra New Member
    I can't say I've had this problem. The right tools play a huge part in DIY work.
    ZappBrannigan likes this.
  4. Jan 21, 2023 at 3:33 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I tried compressing the springs on my new shocks manually and swap them out with the old ones.
    A broken control arm, no springs on my new shocks, a tow truck, and dealer visit later it worked out great :spending:
    Welcome .
    TRDGoodness and clarkritchie like this.
  5. Jan 21, 2023 at 3:43 PM
    Sunnier
    Sunny
    San Diego, CA
    Cool you were willing to try something you hadn’t done before; figured it out; didn’t give up; can rationalize buying more tools; and wrote about it to help someone else have an easier time when they need to do this job!
    Welcome!
  6. Jan 21, 2023 at 4:01 PM
    2mchfun
    Screenshot_20230121-180351.jpg Welcome from OKC! Good job! Next time lock into 4wd first, should make a little more easy.
    “J”, HulkSmurf14 and RegGex like this.
  7. Jan 21, 2023 at 4:13 PM
    2mchfun
  8. Jan 21, 2023 at 4:26 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Welcome
  9. Jan 21, 2023 at 4:29 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    To the OP I feel your pain. Sometimes the clips on the shafts get just enough gunk or corrosion to where they won't compress and left the axle come out.
  10. Jan 21, 2023 at 6:03 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    I go up to 54mm for me after that....too damn big.
    centex[QUOTED] and ZappBrannigan like this.
  11. Mar 28, 2025 at 6:56 AM
    FundraThundra
    FundraThundra New Member
    2009 Tundra SR5 4x4
    OP, I too feel your pain, as I just completed this same job in order to replace my starter. 180K miles on my 2009 and that axle did NOT want to come out, OR go back in... will do some things differently next time, in case it's helpful to someone else:
    • Use a pickle fork and/or axle puller (instead, I used a set of large handheld pry bars - the screwdriver form factor) - which eventually worked, but also chipped my cast aluminum diff housing in the process... *sigh*... fortunately no serious functional issues or leaks resulted.
    • I've heard that engaging 4WD helps because it locks in place the splines within the front diff - otherwise it just spins as your trying to line them up and push the CV axle back in.
    • In advance, I would buy a few CV axle retention springs and have them ready when I started the job. The original was chewed up and caused me a lot of problems, but my timeline wouldn't allow for me to order one and wait for it (couldn't track one down locally either). Probably would have made putting everything back together much easier. Retention spring opening goes at 12 o'clock, by the way.
    • In advance, I would buy a replacement diff seal - I didn't need one, and there are no leaks, but I definitely don't want to have to get back in there anytime soon just to replace the seal - I regret that I didn't do it.
  12. Mar 28, 2025 at 7:50 AM
    yakeng
    yakeng 3URFE Apologist
    I don't think 4WD should be engaged when removing the CV. Also, a 5lb slide hammer is your friend to remove the CV. The CV has the perfect lip to fit a hose clamp around the CV and lock down a hook attachment.
    n0rth, atc250r and FundraThundra like this.
  13. Mar 28, 2025 at 8:39 AM
    FundraThundra
    2009 Tundra SR5 4x4
    The hose clamps look like a very good idea. I'm getting ready to complete the ECGS bushing install / needle bearing delete on the driver side, so I actually just bought a slide hammer - I think I'll try this trick - thanks!
  14. Mar 28, 2025 at 9:57 AM
    yakeng
    Wish I could take credit for the idea, but I saw a Tacoma owner use that trick for removing his.
    I pounded and pried my CV for what felt like an eternity, then went and got this slide hammer and hose clamps. Had it off in like 5 hits with the slide hammer. I was laughing hysterically after and my wife thought I lost my mind (I did, stuck CVs do that to you).
    TRDGoodness likes this.
  15. Mar 28, 2025 at 10:25 AM
    FundraThundra
    2009 Tundra SR5 4x4
    Oh yeah, I briefly reached new depths of despair with this CV job haha... again, I can very much relate to the OP. But, per usual, it seems like having the right tools really makes all the difference...
    yakeng[QUOTED] likes this.
  16. Mar 28, 2025 at 10:54 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    My local dealership charged me $300 to remove and install my driver side cv axle after I hit a root on a back road and tore a cv boot. It was $400 all in, including the part, labor and tax. The labor worked out to be around $300. Well worth it. lol
  17. Apr 1, 2025 at 10:59 AM
    Tundra Rod
    Tundra Rod New Member
    The other side will be easier. lol
  18. Apr 29, 2025 at 2:06 AM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    $400!! I need a copy of that invoice so I can shove in my dealers face. They want twice that for a boot replacement here.
  19. Apr 29, 2025 at 4:43 PM
    Danman34
    Danman34 New Member
    Danny
    I stand corrected. $450. Albeit it was 3 years ago. But that was parts and labor.
    Tundra2Yak[QUOTED] likes this.
  20. Apr 29, 2025 at 4:51 PM
    Tundra2Yak
    2016 1794 4x4 CM
    Ah, I see. I found a reman OEM axle at my dealer today and will have a local 4x4 shop install and do an alignment I need. Still about double what you paid...
  21. May 14, 2025 at 10:14 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Help me understand what I'm looking at here and how it helps. Gonna be swapping drivers side in near future passenger side was a pita. Anything to make it easier would be awesome.
    Edit: in the picture with the straps...I somehow deleted the picture from the quote.
  22. May 14, 2025 at 10:22 AM
    AZBoatHauler
    So.Arizona
    It's the attachment for the slide hammer.
    2mchfun likes this.
  23. May 14, 2025 at 10:25 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Oh! Duh. Thanks lol
  24. May 14, 2025 at 10:25 AM
    2mchfun
    Looks like a large screw type adjustable hose clamp around the CV shaft "acorn" to hold the slide hammer hook on the acorn. Then, the slide and hammering function is used to aid in pulling the male splined shaft from the female splined differential
  25. May 14, 2025 at 12:31 PM
    yakeng
    Yea pretty much. I obviously don't have the slide hammer connected to the attachment in this picture. I was mainly trying to demonstrate that the attachment can easily be banded onto the CV which helps greatly, as the slide hammer won't fall off the CV easily, which is a problem when you are wailing on the slide hammer itself.
  26. May 14, 2025 at 1:34 PM
    2mchfun
    At the tip of the arrow there is a flat machined on the acorn to hook onto.Screenshot_20250514-153140~2.png
  27. May 14, 2025 at 3:04 PM
    yakeng
    I'm well aware of the intent, but it still wants to fall off. The angle of the hook just doesn't want to keep it on the CV. The purpose of the banding is to help keep it from moving/falling off. I tried for 20 minutes hammering on it without the hose clamp just for that hook to keep sliding off and moving on me. Saw this tip with the hose clamp and it helped keep the hook in place much better, out in 3 hits after that. Much better force transfer from the slide hammer directly to the CV and it kept it concentric/parallel with the CV.
    Necessary, no, people have removed it without it. But, if you want quick work, I recommend this method.
    2mchfun and AZBoatHauler like this.
  28. May 15, 2025 at 4:00 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    When I did mine I just used a 2’ long pry bar, lined it up on the axle, hit the end with a 4lb sledge a couple times and it popped out.
  29. May 15, 2025 at 4:10 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Come on.............man. Get your tool box-----TOOLED UP.
    DeepBushCaboose likes this.
