E rated tires 21 limited opinions please
Discussion in 'Wheels & Tires' started by Kentucky22, Jan 8, 2023.
  1. Jan 8, 2023 at 6:08 AM
    Kentucky22
    Kentucky22 [OP] New Member
    21 Tundra Limited 4x4
    I like E rated tires I have them on my Nissan Titan and they’re great.
    I also have a 21 tundra limited. They currently have the stock 20” rims with the dunlop street tires(racing slicks IMO).
    I want some E rated all terrain tires. Has anyone here ever put them on a tundra and if so how did they perform. I’d like to run them at a higher PSI.
  2. Jan 8, 2023 at 6:17 AM
    You may not get much of a response with a question that’s been beaten to death on here. They’ll all say “use the search function!!” To be fair, it doesn’t really work great. I search what I want on Google and add Tundras.com at the end. Works great. Here’s a link to a myriad of setups on your truck type. And yes, lots and lots of people run E rated all terrains on their Tundra, they are the most readily available type in the sizes that most are looking for. Good luck with your search.
    https://www.tundras.com/threads/off...-setups-pics-and-info.95/page-96#post-2890582
  3. Jan 8, 2023 at 6:21 AM
    17inferno
    17inferno New Member
    I have a 21 limited, but 18 inch wheels. I have michelin defenders 295/70/18 on, E rated. the tires are very good, but ride firm, even at 36 psi. I would never get an E rated tire without a good reason. Mine was...it was the only way I could get this tire in this size, which outweighs the rougher ride. gl
  4. Jan 8, 2023 at 6:23 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    My last two sets of tires have been Es and they have gone over 60k miles. That harder rubber compound seems to really last well in the Es. Plus with the harder rubber and extra plies, I haven’t had a single puncture, and I Offroad a fair amount.
    of course there are trade offs, like weight. Es are heavy, so your mileage will suffer. Plus with the harder rubber, the ride will feel a bit more harsh.
    HulkSmurf14 likes this.
  5. Jan 8, 2023 at 9:03 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    All I use are E rated. They work fine. I have no idea why you’d want to run them at high psi (assuming 40+) unless you are towing or have a lot of weight in the bed all the time.
    I keep my Duratracs at 37, and bump them to 50 when I’m pulling my camp trailer (4600 lbs).
  6. Jan 8, 2023 at 4:35 PM
    Kentucky22
  7. Jan 8, 2023 at 4:39 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I have load F on my 2021 tundra.
  8. Jan 21, 2023 at 11:18 AM
    rollin-on-dubs
    rollin-on-dubs New Member
    Chuck
    Middle TN
    2014 CrewMax Platinum
    Toytec Boss Suspension SPC Light Racing UCA's Coach Builder 3" Rear Shackles 20x9 Fuel Boost 275/60/20 Nitto Terra Grappler G2 Locker-Down Center Console Safe Morimoto XB LED Fog Lights Ellis Precision Shift Knob Ellis Precision Battery Hold Down
    How’s the ride? I’ve been looking at the falken wildpeaks and 35’s only have F load. Wasn’t sure if they would ride hard or what.
    what PSI do you run yours at?
  9. Jan 21, 2023 at 11:31 AM
    2mchfun
    Yokohama GO15's 285/75/18 E run em about 62ish PSI. Hard as a brick, heavy MF''s. Love the quiet solid ride. Coupled with a stiff suspension, it corners as if on rails. Expensive nowadays too!
  10. Jan 21, 2023 at 12:50 PM
    ScenicRoute
    Im installing wild peaks next week. The 35x11.50r20 which are load D. That said the load F hasn’t been an issue and I wouldn’t hesitate to get a load F again. I run at 50 psi. I just don’t like the coopers.
  11. Jan 21, 2023 at 1:11 PM
    Tilley’s Tundra
    Tilley’s Tundra New Member
    Jerry
    2021 Trail Edition Crewmax
    Wife has these on her 4Runner. Ride really nice, not to loud. E rated.
    WVI likes this.
  12. Jan 21, 2023 at 1:26 PM
    Kbo
    Kbo New Member
    British Columbia
    2019 Double cab
    A bit of a lift, compressor, bags
    9F97813E-A070-4247-A1E7-EA22B71A2CA1.jpg I’ve had these E rated 275/70/18 Nokian Rotiiva for 18 mos. When towing our TT I’m at 75psi. When I’m not towing I’m at 40. When I’m 4 wheeling in the rocks I’ve gone as low as 12. I’d buy them again.
    Quattroa4m and WVI like this.
