Flashing warning light but no message
Discussion in '2.5 Gen Tundras (2014-2021)' started by ThatGuy246, Jan 14, 2023.
  1. Jan 14, 2023 at 3:01 PM
    ThatGuy246
    ThatGuy246 [OP] New Member
    2004 Tundra
    And yet another problem with this vehicle. Got in started ok, backed up, turned around, put in drive the warning light, the yellow triangle with the exclamation starts flashing and beeping. I stopped, looked for messages, nothing. Put it in Park, lights goes off. I got out checked around vehicle, saw nothing, put it back in drive light flashes again. Again put it in drive, goes out get out check again see nothing, put it back in by drive, this time no light. Has this happened to anyone else? Transmission or other drivetrain issue?
  2. Jan 15, 2023 at 11:20 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    When back door was not closed all the way.
  3. Jan 15, 2023 at 11:32 AM
    2mchfun
    Check to make sure your parking brake is fully released.
  4. Jan 15, 2023 at 2:13 PM
    ThatGuy246
    2004 Tundra
    Thanks for suggestions but the brake was released; the back door had not been opened on the trip.
    It is weird. There was no "break on" or "door open" or other issue accompanying the flashing warning light. I guess it was a malfunction
  5. Jan 15, 2023 at 2:26 PM
    ThatGuy246
    2004 Tundra
    In May 2022 I replaced a relay because the vehicle would not start. I have to several issues over recent weeks that make me nervous the same relay, or another one, is going bad. I'm to the point I don't like driving it very far from hone
  6. Jan 15, 2023 at 3:23 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Your hood is open.
  7. Jan 15, 2023 at 5:39 PM
    ThatGuy246
    2004 Tundra
    Not an open hood. I drove the truck earlier and did not open the hood. The light went out but I did not check anything at the hood. I think it must be a malfunction. This, along with other recent issues, makes me think a relay or other computer related component is about to stop working
  8. Jan 15, 2023 at 6:20 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    This is very possible. If the hood latch is sticky or broken it can cause this.
  9. Jan 15, 2023 at 6:34 PM
    ThatGuy246
    2004 Tundra
    The light went out but possibly something in the hood latch. If it comes back on I will check that. As I noted there was no message with the light just the yellow triangle warning light flashing along with a buzzer..but no message indicating what the issue was. That is why I'm thinking a malfunctioning light
  10. Jan 15, 2023 at 6:39 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Would be helpful to know what trim level and what options your truck has, including cab size. What aftermarket add-ons as well. Your profile only says 2019 Tundra and there’s a number of variations in the different electrical systems for that particular year based on trim and cab
    RobertD likes this.
  11. Jan 15, 2023 at 6:45 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Are you on the original battery still?
  12. Jan 15, 2023 at 6:47 PM
    Joe333x
    Joe333x Member
    Boston
    When the hood is unlatched there is no message, just the blinking triangle and beeps, it goes away when it park, only comes on while moving.
  13. Jan 15, 2023 at 9:05 PM
    ThatGuy246
    2004 Tundra
    That is what happened. I will check the hood latch but I have not opened the hood for a week or so and be the light finally went off
  14. Jan 15, 2023 at 9:06 PM
    ThatGuy246
    2004 Tundra
    I don't know. I bought the vehicle used. Probably not. The vehicle has 55k miles and is approx 4 years old
  15. Jan 15, 2023 at 9:25 PM
    ThatGuy246
    2004 Tundra
    It is a 2019 double cab. Few options. It has satellite radio, and Bluetooth, but no gps, few other options.
    I really think it is a malfunctioning warning light. I drove the truck to lunch. No issues on way there. After lunch the flashing warning light came on as I pulled out of parking lot. I pulled into a parking space put tranny in Park, light goes out. I got out, looked around vehicle but saw nothing obvious. Put in drive again, again light flashes. Put in Park get out, nothing. Get back in, once again in drive no light. Drove home with no issue. I have had problems with transmission "jumping" when shifting into drive so it may be a transmission issue but I'm thinking a malfunction.
  16. Jan 15, 2023 at 9:33 PM
    ThatGuy246
    2004 Tundra
    Thinking about it the transmission "jumping" occurs when turning around in a parking lot..just like the warning light issue. Maybe I should avoid parking lots lol
  17. Jan 16, 2023 at 4:33 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I've seen some weird things happen when batteries start to fail.
    Is the transmission "jumping" only when going from P to a drive gear? I've always noticed somewhat of a lurch when going into gear. I guess doesn't explain the light though.
  18. Jan 16, 2023 at 6:00 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Have you brought it in somewhere to pull codes? My experience is that there are rarely “malfunctioning warning lights” and more often other malfunctions (sometimes intermittent) that cause warning lights…
    Dying batteries
    Faulty grounds
    Damaged wires (rodents, or many other causes)
    Hood latch sensors
    Fuel tank caps not fully tight
    A door latch sensor not fully engaged or failing
    A transmission position switch failing
    The list goes on…
    The light is simply an output of an issue condition…The source of the issue is the challenge to find
    RobertD likes this.
  19. Jan 16, 2023 at 6:02 PM
    Joe333x
    Joe333x Member
    Boston
    Unfortunately you typically will not pull any codes without a CEL.
  20. Jan 16, 2023 at 6:05 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Possibly
    I’ve seen codes from other systems that don’t trigger CEL like the AC systems and occupant sensors in newer vehicles.
    It’s worth at least checking
  21. Jan 17, 2023 at 4:06 AM
    ThatGuy246
    2004 Tundra
    Thanks for the suggestion. It is worth checking. When I said the warning light was malfunctioning, I should have said the computer system is malfunctioning. I have already had to replace a relay that prevented the vehicle from starting. I also posted about the transmission "jumping" when going from R to D - when backing from a parking space for example. I took it to a dealer but they could find an issue with the transmission. I'm concerned both are part of a bigger computer issue
