RIP TUNDRA? After 7 months in the body shop, now SOLD TO CARMAX
Discussion in '2.5 Gen Builds (2014-2021)' started by M3Tundra-JK, May 20, 2022.
  1. Jan 16, 2023 at 3:50 PM
    #151
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
    I'm working on the bottom brackets right now. It won't actually sit against or touch any of the trucks metal bracing.
    Fastlane47 and KNABORES[QUOTED] like this.
  2. Jan 16, 2023 at 4:17 PM
    #152
    M3Tundra-JK
    Scott
    2005 GX470
    Finished with mounting the intercooler. Made a few bends in those straight brackets for the bottom, then self tapping screws to hold it on. The top brackets are bolted into factory M8 bolt holes.
    No gotta figure out the transmission cooler again
    Fastlane47 likes this.
  3. Jan 16, 2023 at 5:49 PM
    #153
    M3Tundra-JK
    Scott
    2005 GX470
    And I'm done for the night. Had to take the Setrab trans cooler mount apart and flip it around as well as all the bolts. It's tight but both it and the intercooler are mounted in their new home!
  4. Jan 16, 2023 at 5:51 PM
    #154
    Wow. 4 stacked liquid to air cooling devices. Will be interested to see how they all work in the same space. Any fan upgrades planned?
  5. Jan 16, 2023 at 5:55 PM
    #155
    M3Tundra-JK
    Scott
    2005 GX470
    Not yet. It should be fine. 2019+ don't come with a trans cooler so don't think that one will suffer. Behind it is the AC condenser then radiator behind it. They should have enough airflow still. Will look into replacing the belt driven fan with an e-fan if becomes an issue
  6. Jan 19, 2023 at 4:46 PM
    #156
    M3Tundra-JK
    Scott
    2005 GX470
    These are.gonna look good!
    68 RS/SS, Fastlane47, Hbjeff and 2 others like this.
  7. Jan 22, 2023 at 11:25 AM
    #157
    M3Tundra-JK
    Scott
    2005 GX470
    Lowered truck problems...have to jack up the truck to slide the tank out
  8. Jan 22, 2023 at 11:27 AM
    #158
    M3Tundra-JK
    Scott
    2005 GX470
    About 11" of ground clearance at the frame rail
  9. Jan 22, 2023 at 11:32 AM
    #159
    M3Tundra-JK
    Scott
    2005 GX470
    And one 38 gallon gas tank removed. Now to clean it up, lunch break, then work on them 450lph pump swap
    KNABORES likes this.
  10. Jan 22, 2023 at 1:15 PM
    #160
    M3Tundra-JK
    Scott
    2005 GX470
    Stock vs 450lph fuel pump
    Fastlane47 and KNABORES like this.
  11. Jan 22, 2023 at 4:32 PM
    #161
    M3Tundra-JK
    Scott
    2005 GX470
    450lph fuel pump installed into housing
  12. Jan 28, 2023 at 12:50 PM
    #162
    M3Tundra-JK
    Scott
    2005 GX470
    Fuel pump install done. Now on to the fuel line upgrades. Reinstalling tank tomorrow with help from a friend
    Tip: if you don't have a special tank ring removal tool, you can use a large flathead or chisel, a rag, and large hammer. Wrap chisel end with rag and place against fin. Intermittently hit different fins to unscrew. Also take a pic before removing so you know how tight to go on reinstall
    HulkSmurf14 likes this.
  13. Feb 4, 2023 at 5:58 PM
    #163
    M3Tundra-JK
    Scott
    2005 GX470
    Placed an order for tires while I'm waiting on supercharger parts. Scheduled to be installed by a mobile installer next Saturday. Had a really good experience with this company last time.
    YOKOHAMA PARADA SPEC-X in size 285/45/22
    https://www.yokohamatire.com/tires/parada-spec-x
  14. Feb 11, 2023 at 9:10 AM
    #164
    M3Tundra-JK
    Scott
    2005 GX470
    Wheels and Tires Day!
  15. Feb 11, 2023 at 10:49 AM
    #165
    M3Tundra-JK
    Scott
    2005 GX470
    Oh man!!
    D4x4TRD, 68 RS/SS and KNABORES like this.
  16. Feb 11, 2023 at 10:52 AM
    #166
    M3Tundra-JK
    Scott
    2005 GX470
    Could've probably gotten a larger tire, though
  17. Feb 11, 2023 at 10:58 AM
    #167
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    These are my all time favorite wheels. Make sure the center caps are very secure, at this time they are nearly impossible to find.
  18. Feb 11, 2023 at 11:05 AM
    #168
    M3Tundra-JK
    Scott
    2005 GX470
    Thanks! They didn't even come with caps! Lol. I had to ask the seller and thankfully they had two. They are very much impossible to find and I have feeler out everywhere looking for more. Plan is to grad the dimensions off the ones I do have, and order some other TRD center caps to cut up till they work.
  19. Feb 12, 2023 at 4:06 PM
    #169
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Came in to see how you mounted the IC, went through the thread & got tons of inspiration!
    Great work & thanks!
    M3Tundra-JK[OP] likes this.
  20. Feb 12, 2023 at 4:14 PM
    #170
    M3Tundra-JK
    Scott
    2005 GX470
    Just removed the rear mud flaps and cleaned up the garage little. Better pic of truck with new wheels. Front end should come down just a little when I add the 100lbs of supercharger parts and TRD Skid plate
    MSU Tundra likes this.
  21. Feb 17, 2023 at 3:37 PM
    #171
    M3Tundra-JK
    Scott
    2005 GX470
    2.3" pulley installed!
  22. Feb 18, 2023 at 4:16 PM
    #172
    M3Tundra-JK
    Scott
    2005 GX470
    ProSpeed fuel rails and lines installed
    MGMTundra18 likes this.
  23. Feb 19, 2023 at 11:46 AM
    #173
    M3Tundra-JK
    Scott
    2005 GX470
  24. Feb 19, 2023 at 12:11 PM
    #174
    M3Tundra-JK
    Scott
    2005 GX470
    Some shots of the underside of s/c with intake manifold heat shielding added
    Tundrastruck91 likes this.
  25. Feb 19, 2023 at 12:36 PM
    #175
    e30cabrio
    Looks great! What heat shield is that?
  26. Feb 19, 2023 at 1:14 PM
    #176
    M3Tundra-JK
    Scott
    2005 GX470
    e30cabrio[QUOTED] likes this.
  27. Feb 20, 2023 at 8:11 AM
    #177
    M3Tundra-JK
    Scott
    2005 GX470
    @e30cabrio these are the fittings I settled on for the FB Intercooler. 45* fitting will be in the top intercooler outlet, straight fitting will be in the bottom. The two 90* fittings will be used to make the 180* turn the tubes need to make, going from the intercooler pump to the bottom intercooler outlet
    Pretty sure we can get away with cutting up the supplied intercooler tubes to make it work, but it not just need to hit up the automotive store for 3/4" ID hose
    e30cabrio likes this.
  28. Feb 20, 2023 at 8:25 AM
    #178
    e30cabrio
    Thanks, how many feet of hose did your kit come with?
  29. Feb 20, 2023 at 8:33 AM
    #179
    M3Tundra-JK
    Scott
    2005 GX470
    I'll have to check that and get back to you. I only have the hoses that came with the TRD Hose Kit, but some of the instructions say to cut them shorter. New fittings arrive Wed and Thursday so can update then.
  30. Feb 22, 2023 at 9:41 AM
    #180
    M3Tundra-JK
    Scott
    2005 GX470
    Mounting LED Grill Emblem. Had to drill out two small guide holes in grill for new emblem since the current ones don't line up. Then I removed the tabs around the outer edges of the LED emblem, so I didn't have to make more holes in grill for those. I'll just use some double sided emblem tap to secure it.
