  1. Jan 16, 2023 at 1:59 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    Flat stock extensions are probably the easiest solution.
    texasrho83[QUOTED] and RobertD like this.
  2. Jan 16, 2023 at 1:59 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    More like what @RobertD said. I did not put a spacer on the bumper side but a longer arm to push just the license plate out farther.
  3. Jan 16, 2023 at 2:02 PM
    SwitchThrottle
    I did that the 1st time I washed my truck. The next day it was hot, I was able to pop it back into place with an interior trim tool. That plastic is very thin and flexy.
  4. Jan 16, 2023 at 2:18 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I tried using a trim tool but it seems short. I was thinking about putting heat on it but the middle section it doesn't seem to overlap like the sides do?
    That's why I opened my hood, to push the mid section up to see if there was any play in it.
    Appreciate the tip. I'll put some heat on it and give it a go anyways.
  5. Jan 16, 2023 at 2:24 PM
    1UP
    1UP Truck Gang
    Yeah man. Nothing quite as frustrating as self induced compounding problems.
  6. Jan 16, 2023 at 3:10 PM
    SwitchThrottle
    My hand slid down the windshield while trying to get the center cleaned and pushed that plastic down about 1/2 - 3/4". The plastic pops back into the gap under the windshield. I used the interior tool on that (looks like a plastic bent pribar). The rubber trim has a little lip that goes over the top of the plastic trim and sits in a tiny groove, I used a pick tool to get that back in.
  7. Jan 16, 2023 at 3:59 PM
    Azblue
    The Dirty T ( ^_^)_且
    I wonder if they screw with people driving in from another state that doesn't require a front plate. You know, as an excuse to perform a stop.
    Trentimus[QUOTED] and Beach Toy like this.
  8. Jan 16, 2023 at 4:16 PM
    DPhung
    DPhung Measly Mechanic
    North AL
    2016 MGM Tundra CM
    Over the weekend, small mishap almost ripped off rear bumper so fixing to order a HC rear.
  9. Jan 16, 2023 at 4:20 PM
    APalmTree
    Brandon
    SW Washington
    This bumper flips up but same idea. I don’t have spare metal laying around but I chopped up some thin wall square tube and folded it. Then drilled holes. The square edge is pushed hard back toward the bumper so it does not rotate when I try to flip the plate. (I should probably paint it too but you can’t even tell it’s different unless you kneel down to look)05A9E0E8-FA9D-43A1-993E-A3D94A2E6362.jpg
    Ignore the fact that my plate is beat to shit it does sit flat. I bent the plate on the stock bumper somehow without damaging the bumper at all :notsure:
  10. Jan 16, 2023 at 4:31 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This is my plan. However, due to the tight clearance between the bolts and the winch, I'm thinking I'll have to drop the bumper again so I'm hesitant to bother with it anytime soon.
    bulldog93 likes this.
  11. Jan 16, 2023 at 4:45 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    You weren’t alone!
    E6ED36F7-661B-4EB6-AF42-92019D3101C5.jpg 31ACB65E-459E-459C-B620-58B8FC51A54D.jpg 0DEE8049-DD0E-4692-83DD-0F96EA3C5921.jpg
  12. Jan 16, 2023 at 4:45 PM
    RobertD
    Robert
    DFW, Texas
    :itllbuffout:
    Edit: Sorry you said it won't buff out.:sawzall:
  13. Jan 16, 2023 at 4:46 PM
    Squatting Pigeon
    Holden
    North Texas
    :rofl::rofl::rofl:
    RobertD[QUOTED] likes this.
  14. Jan 16, 2023 at 4:49 PM
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Love my Tundramatic, but damn, when I see this I remember those approach and departure angles of my Rubicons...... I don't have the courage (read money) to wheel this one yet. Hope you guys had fun., demonstrative evidence appears to indicate you did !!!! : )
    RobertD likes this.
  15. Jan 16, 2023 at 4:51 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  16. Jan 16, 2023 at 4:52 PM
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    1000000% a stop to open other charges
  17. Jan 16, 2023 at 4:55 PM
    PlaysARobin
    PlaysARobin New Member
    Thomas
    East Houston - Texas
    2021 TRD Pro Super White
    (2021 TRD Pro) AMP Steps, Ceramic Tint 5/20/70 windshield, Kilmat floor, doors and rear with Audiofrog/Arc audio/JL speaker upgrades and factory HU. AJT blackout. Ironmax4x4 Raid bumper with 10w amber work lights and 32" light bar. Rago dash setup with Bulletproof phone mounts. VLEDs interior kit with front and rear footwell lighting. X2Power AMG 27F.
    Worried. Worried is the feeling when everything goes smooth. Its that moment between looking around and finding the bolt you forgot at the halfway point.
    WILLINH, Beach Toy, Bprose and 2 others like this.
  18. Jan 16, 2023 at 4:59 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I know this feeling all too well.
    WILLINH and bulldog93 like this.
  19. Jan 16, 2023 at 5:01 PM
    centex
    centex New Member
    That’s why I have this. It doesn’t matter if it gets damaged.
  20. Jan 16, 2023 at 5:03 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    So, what new bumper are you going with?
  21. Jan 16, 2023 at 5:19 PM
    Squatting Pigeon
    Holden
    North Texas
    Tons of fun! Probably way more than I should have had :rofl:
    Departure angle is downright awful on this beast.
    cartage1[QUOTED] likes this.
  22. Jan 16, 2023 at 5:19 PM
    Squatting Pigeon
    Holden
    North Texas
    If I had the space (and dough) I’d have a dedicated wheeling rig
  23. Jan 16, 2023 at 5:20 PM
    Squatting Pigeon
    Holden
    North Texas
    I’m in talks with a local fab shop that @khooiii hooked me up with for a custom high clearance bumper that will keep all my fancy ass sensors in place :welder::sawzall:
  24. Jan 16, 2023 at 7:14 PM
    DPhung
    North AL
    2016 MGM Tundra CM
    Are you gonna go with a HC bumper as well?
    edit: just saw your above post, you gonna get a tube style or a closed in style?
  25. Jan 16, 2023 at 7:24 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    I found something bigger than my Tundra
    NzT7AhYmM45fBPNlKS6icXRvxnJDPIjQMIS1Vj-k_a4f51b3fb488da3825a538b64fbe1bd700bbde07.jpg
    GAknight, Henry1jg, kbark and 17 others like this.
  26. Jan 16, 2023 at 7:49 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Installed Vleds amber front turn signals. No need for resistors. :thumbsup:
  27. Jan 16, 2023 at 9:39 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Got this in the mail from my wife today for my birthday.
  28. Jan 16, 2023 at 10:09 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    This is a part# for a front license plate bracket for SuperDuty trucks that have the optional factory warn winch...
    Not sure if it would work for you or not, but I believe it connects to the bottom of the winch cover/frame. Anyhow, it may give you ideas.... I remember this being a big issue for SuperDuty guys that were looking to add the warn winch to their builds.
    Front License Bracket LC3Z-17A385-BA
  29. Jan 17, 2023 at 1:12 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    Success!
    Spent 15 minutes after work yesterday on it. Drilled the holes bigger and deeper (almost too deep), but it still wouldn't release. Between prying and using a punch it eventually started to separate. You can see that I actually had to break the plastic apart (light areas on the plastic). I think that in the process of heating the tabs to plastic weld them in place it also fused the plastic together in these places.
  30. Jan 17, 2023 at 3:23 AM
    Squatting Pigeon
    Holden
    North Texas
    I’m going tube, I like the looks and how high I can tuck it away
    DPhung[QUOTED] and RobertD like this.
