ARH Header Install
Discussion in 'Performance and Tuning' started by HTXtundra4x4, Jan 15, 2023.
  1. Jan 15, 2023 at 5:57 PM
    HTXtundra4x4
    HTXtundra4x4 [OP] Texas
    Katy, TX
    2018 SR5 CM MGM
    I installed ARH headers with Toyota gaskets and dirtydeeds exhaust around 2 two weeks ago. After a few days I noticed that it wasn't maintaining a constant idle and was revving up and down about ~50-75rpm. Very noticeable. Was also looking at the short term fuel trims and noticed the bank 1 pretty erratic. So I started listening in the wheel well and could hear an exhaust leak. Then I noticed that the header wasn't 100% aligned with the head curvatures and the nut stud not centered in the bolt hole of the header. The pic is the number 7 cylinder. (closest to the firewall).
    So last weekend I removed the left side mid pipe, unbolted the front drive shaft and unbolted the header completely in an attempt to correct the alignment. So this time, I tried maneuvering it to align better with the head, but it just wouldn't move. Once I get it onto the 8 head studs and 2 AIP studs, it just seems to be locked in place. I was pressed for time so I just let it go back into the same position and tightened everything back up thinking maybe I just needed to get it tighter.
    Still having the same problem. Yesterday, I duct taped the outlet side of a shop vac to my tailpipe and sprayed soaping water around the header. I actually did see a few bubbles between the 1 and 3 cylinder. Tightened it up along with every other nut and don't see any more bubbles. Started it up and thought it was good until I drive it. Still having the same problem. I swapped the AFR sensors from each side and still have the same results. I can't really hear a leak like I could the first time though.
    Do ya'll think this misalignment could be the problem? Only way I can think to fix it is to take all the studs out first, but not sure how I would even get them back in tight once the header is in place.
    I am so frustrated right now and so tired of wrenching on the same thing and getting the same results I don't know what else to do but to take it to a shop and hope someone more experienced than I can fix it.
    Fernan6892 likes this.
  2. Jan 15, 2023 at 6:04 PM
    centex
    centex New Member
    You call ARH?
  3. Jan 15, 2023 at 6:08 PM
    HTXtundra4x4
    Katy, TX
    2018 SR5 CM MGM
    No, I haven't.
  4. Jan 15, 2023 at 6:10 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This.
    Nick will talk to you himself and he will pin point what's up. Call him and see what he says.
  5. Jan 15, 2023 at 6:10 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I was gonna say, when installing headers on my Tacoma it was required to remove two of the header studs in order to even do the install.
  6. Jan 15, 2023 at 6:11 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Are any of the other holes in the header offset, or is it just that one?
  7. Jan 15, 2023 at 6:23 PM
    HTXtundra4x4
    Katy, TX
    2018 SR5 CM MGM
    Here's more pics of the other bolt holes. Really hard to get good pics at night so not sure they will help any.
  8. Jan 15, 2023 at 6:32 PM
    HTXtundra4x4
    Katy, TX
    2018 SR5 CM MGM
    I'm probably SOL on that one since I didn't buy directly from him, but I don't know for certain. So worth a try I guess.
    That may be what needs to be done in my case. I think I've read every thread on header installs and nobody has mentioned it. Maybe i missed it.
    M3Tundra-JK[QUOTED] likes this.
  9. Jan 15, 2023 at 7:09 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I didn't buy from him either. He provides support for the products he makes. I've had to replace the H pipe and he did it no questions asked.
  10. Jan 15, 2023 at 7:32 PM
    HTXtundra4x4
    Katy, TX
    2018 SR5 CM MGM
    Here is what I am seeing on my obd app for my tundra. When I look at my wife's '18 4 runner, the fuel trims are very similar regarding B1 and B2.
      File size:
      9.5 MB
      96
  11. Jan 15, 2023 at 8:45 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Sounds like there’s a leak at the collector.
  12. Jan 15, 2023 at 9:17 PM
    HTXtundra4x4
    Katy, TX
    2018 SR5 CM MGM
    The collectors were leaking after the initial install. They are sealed now though after I applied some red rtv.
  13. Jan 15, 2023 at 9:32 PM
    dirtydeeds
    Keith
    USA
    And it still surges
  14. Jan 15, 2023 at 9:35 PM
    dirtydeeds
    Keith
    USA
    If the bolt holes are bigger than the stud just make some centering dowels for the two outside studs.
    if you’re using stock gaskets it’s likely leaking at the header flange. The stock gaskets seal really well on stock manifolds. Headers need a more compliant gasket.
    if the rpm is surging you have a leak and the o2 sensor is seeing this air and the ecu compensates worth more fuel. This causes idle time drop. So the ecu raises idle snd over compensates.
    Ponderosa_Pine and Fernan6892 like this.
  15. Jun 13, 2023 at 12:39 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Did you ever get this resolved? Did you use new stock gaskets? About to do this same setup and was curious! I wonder if this was error in the header build or what happened.
  16. Jun 13, 2023 at 12:41 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Do you have a recommendation for what gaskets to buy with the ARH? (Which gaskets does ARH send with the headers usually?)
  17. Jun 14, 2023 at 7:58 AM
    HTXtundra4x4
    Katy, TX
    2018 SR5 CM MGM
    Yes, it has been resolved. I didn't have the time anymore to pull the headers and reinstall so I kept thinking of other things that may be causing the idle surge. I ended up doing a relearn all values via techstream and that seemed to fix it. Hasn't had any surge since. Not really sure what the deal was. I used OEM gaskets from toyota.
  18. Jun 14, 2023 at 6:56 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
