New member... Longtime observer, with an Alcohol problem
Discussion in 'New Member Introductions' started by 53027_RW, Jan 14, 2023.
  1. Jan 14, 2023 at 8:57 PM
    53027_RW
    53027_RW [OP] New Member
    Andy
    Wisconsin
    '13 Magnetic Grey Rock Warrior
    4" lift, 35s on 20s, Afe cold air, Dirty Deeds side exhaust, Rigid fog lights, LED headlights, tow mirrors, color match door handles, removed black vinyl between front and rear doors, tinted front windows.
    Well, after nearly 9 years of owning my Tundra I've finally decided to join the group.
    I can say that my truck has been pretty good to me over the years. I had to deal with the leaky cam tower, the only "issue" I've really had, my dealership covered it under warranty... 5 TIMES!! Other than that it's just been routine maintenance.
    The past couple months I've been dealing with the alcohol density getting out of wack. Rough, extended crank, no starts, throwing codes. I'm trying really hard to not go back to the dealership since it's a '13 and at 119k miles.
    My question and main reason for joining is, where are you guys getting your Techstream from? I've spent hours today researching and trying multiple options, but kept striking out. I bought a Tactrix openport 2.0 cable. I'd like to splice in a new pump and reset Screenshot_20230114-223835_Photos.jpg Screenshot_20230105-152411_BlueDriver.jpg the alcohol density on my own.
    Any recommendations or suggestions would be greatly appreciated.
    **UPDATE**
    I gave up on pirated Techstream and went the legit route and bought a two day subscription for $65.
    Flashed the ECU with the latest software, reset the alcohol density, and disabled the seatbelt chime. I'm glad to say I'm a happy Tundra owner again!
    I plan to do the same pump mod as Sumo91 and fytedapowr have done and posted here.
    -Andy
  2. Jan 14, 2023 at 9:46 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! I am sure somebody with knowledge about your question and issue will chime in.
    53027_RW[OP] likes this.
  3. Jan 14, 2023 at 10:02 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Welcome from NorCal with different alcohol problems :cheers:
  4. Jan 15, 2023 at 5:29 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Jan 15, 2023 at 5:44 AM
    Welcome from NY.
  6. Jan 15, 2023 at 6:45 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    You can only increase alcohol density by consuming more alcohol.
    Unless you boof it.
    Welcome.
  7. Jan 15, 2023 at 7:16 AM
    Welcome
    hagrid and 53027_RW[OP] like this.
  8. Jan 16, 2023 at 5:40 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  9. Jan 16, 2023 at 5:44 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    John Dunsworth was legendary.
