2022 wiper blade replacement.
Discussion in '3rd Gen Tundras (2022+)' started by Weimer369, Jan 13, 2023.
  1. Jan 13, 2023 at 8:23 PM
    Weimer369
    Weimer369 [OP] New Member
    Rob
    2022 Tundra Limited TRD Offroad Army Green
    Has anyone swapped out the wiper blades on their 22+ yet ? I did a google search to find out that the wipers are apparently 24" Driver / 24" Passenger but when i went to remove the wipers from the truck they were a type i hadn't seen before. Is there a specific style that i need ?
  2. Jan 13, 2023 at 9:45 PM
    Mitch09
    Mitch09 New Member
    NC
    2022 SR5 TRD Off-road
    I recently replaced mine. I noticed online information was kinda scarce. I went to autozone and found Bosch makes a set that fits our connection and they snap right in. I do not know the specific name or style. They are different from the typical J hook. Your local auto parts store will have a set. I’ll see if I can find the receipt.
  3. Jan 13, 2023 at 9:53 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    Replaced mine with Trico Onyx. Perfect fit and function.
    -99
    Tundrastruck91 and Weimer369[OP] like this.
  4. Jan 13, 2023 at 11:35 PM
    Weimer369
    Rob
    I saw a post online somewhere that mentioned the BOSCH OE wipers...i wonder if those are the ones i need.
  5. Jan 14, 2023 at 5:24 AM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    If you’re near a dealer you should be able to buy the rubber inserts instead of replacing the entire blade, I find the OE rubber to work the best and last the longest here in Phoenix
    AND, Dfrink, glassJAW and 9 others like this.
  6. Jan 14, 2023 at 5:38 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    This holds true for me too, at least on wife’s RAV4- haven’t changed truck blades out yet though.
    Weimer369[OP] likes this.
  7. Jan 14, 2023 at 5:43 AM
    Weimer369
    Rob
    Wish i could say the same...maybe its the colder Canadian weather but mine are skipping and rubbing across the windshield whenever i turn them on :(
  8. Jan 14, 2023 at 7:36 AM
    Skidmarcx
    Glendale, AZ
    ‘22 SR5 CM
    Guess it’s hit and miss, seems like everything is getting cheap these days unfortunately
    Blufin, OnThaLake and Leo's first like this.
  9. Jan 14, 2023 at 7:40 AM
    moonrover
    moonrover New Member
    2022 Tundra SR5 TRD OR
    Bosch gets put on my vehicles, they seem to stay quiet and last the longest.
    pwpblue, ToyotaB and Skidmarcx like this.
  10. Jan 14, 2023 at 7:43 AM
    Skidmarcx
    Glendale, AZ
    ‘22 SR5 CM
    I’ve had good luck with Bosch on other vehicles
  11. Feb 25, 2023 at 8:13 PM
    OneFishDotNet
    OneFishDotNet New Member
    Tundrastruck91 likes this.
  12. Feb 26, 2023 at 1:01 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    My experiences with my 4Runner, living in Idaho, Georgia, Maine, and back to Idaho mimicked this. Everything else was expensive and inferior. New blades for the 4R were $6 or less, OEM.
    If anyone has anecdotes where x or y brand really outperformed the OEM rubber, please share, with costs of x or y brand vs OEM.
  13. Apr 2, 2023 at 9:14 AM
    nmmike
    nmmike New Member
    2022 Tundra CrewMax SR5 TRD
    Checked with my dealer and parts guy said Toyota had “moved away” from selling wiper blade refills. I had some 26” Aero cut to fit refills left over and was able to use them on the OEM blades. Bought the Aero 6 mm refills for $7 on Amazon. The Aeros worked great on my Titan and look very similar (look more substantial but almost exact same design) to the OEMs in the 2022 Tundra blade. The Aeros come without any fancy packaging helping the environment and also lowering the cost. Be careful with the OEM blades. They disassemble pretty easily but do not appear real high quality, so don’t force the plastic parts and U will be fine.
    ScottieBones and Gonefishingdave like this.
  14. Apr 2, 2023 at 9:24 PM
    Hella Krusty
    Hella Krusty New Member
    My old Tundra I went with aftermarket (Trico etc )....replace them every year. Wifes Lexus, sons Lexus, daughters Venza get the rubber inserts from toyota every 3-4 years at abou t the 1/8th of the cost...and we live in Canada
  15. Apr 2, 2023 at 9:49 PM
    4ToyotaTrucks
    4ToyotaTrucks New Member
  16. Apr 3, 2023 at 5:38 AM
    gmcguire7220
    Ontario Canada
    I wonder if @ryanwgregg could chime in and confirm here? Do the 22 + tundras have wipers with replaceable rubber inserts? Is there a part # for them? or is it true toyota is moving away from using these? I haven't looked at replacements yet, but will be this fall. I use the rubber inserts for my wifes rav4 and they work great & cheaper than replacing the full blade.
  17. Apr 3, 2023 at 1:18 PM
    nodak67
    nodak67 New Member
    JR
    yeah i would replace with silicone wipers, they last longer than the rubber ones (at least for our winter/summers up here)
  18. Feb 3, 2024 at 5:56 PM
    Bourbonator
    North ID
    '23 LE CM 6.5
    I tried some rain-x latitudes but the lockup with the supplied attachment is horrendous - tons of play. I ended up removing the end clip on the OEM arm, rain-x arm, and swapping the blades out. Long story short, yes you can swap just blades. I don't know if Toyota sells just blades, but maybe that's another part @ryanwgregg can find for us. I'm still waiting to hear about the matte black window trim, though ;)
    Any possibility Toyota's making a new bottom piece that fits better with the rear trim piece?
  19. Feb 3, 2024 at 6:57 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Sure hope Toyota still sells refills. Found over 10 yrs ago that Toyota refills outlast all the aftermarket blades I tried more than twice as long. Cheaper too if ordered online for pickup at the parts counter.
    Soupbean77, Tundrastruck91 and Tom like this.
  20. Feb 3, 2024 at 7:14 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Toyota still does refills. I did wipers couple months ago. Part# 85213-0C010. Same size both side. It was about $10 ea from my dealer.
  21. Dec 9, 2024 at 1:54 PM
    Spiderman1983
    Spiderman1983 New Member
    2022 Blue Tundra Limited TRD 4x4
    None Yet.
    I just replaced my 22 Tundra Limited 24” Blades with Michelin Guardians.
    They have exact fitting for the new and unique wiper Tundra wiper blades.
    The upper blade in the photo below is the OEM off of the Tundra, the bottom is the Michelin Guardian with the fitting attached.
    Hope this helps everyone
  22. Dec 9, 2024 at 6:27 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
  23. Dec 9, 2024 at 8:26 PM
    CrayCray
    CrayCray New Member
    WA State
    2024 Platinum 6.5
    Mine have been smudging ever since I bought the vehicle. Only have 3700 miles. Live in the Seattle area so good wipers are essential. Wondering if I can get a new set under warranty.
  24. Dec 9, 2024 at 8:33 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Mine still work great but this will be my 1st option when needing replacement ... get it done at an oil change !
  25. Dec 10, 2024 at 12:10 AM
    23 Platinum
    23 Platinum 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    Thanks for posting this. I just ordered new refills as a result from my dealers' website. $19.44 including tax. I just have to drop buy and pick them up.
  26. Dec 10, 2024 at 8:27 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    100% Stock
    Anyone bought Bosch Icons yet?
  27. Dec 10, 2024 at 8:55 AM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    Just put a set on a couple of days ago, so no time to analyze, yet. 24OE size for both sides.
    eddiefromcali[QUOTED] likes this.
  28. Dec 10, 2024 at 9:11 AM
    DRP
    DRP Old Member
    Dave
    Not on the Tundra but have used them in the past. Definitely would buy again but they ain't cheap.
    Spiderman1983 likes this.
  29. Dec 10, 2024 at 9:15 AM
    eddiefromcali
    Eddie
    100% Stock
    same...I use them on all our vehicles and they last a long time. Been 2 years on oem blades and theyre starting to streak.
  30. Dec 10, 2024 at 9:19 AM
    DRP
    DRP Old Member
    Dave
    My originals still work well after 15 months. If the Toyota replacements are the same as the originals, I think I would give them a try for $20.
