  1. Jan 12, 2023 at 4:26 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Okay Ill check it out. Brake fluid is one job I hate doing…
    Also cleaned the MAF sensor and changed the air filter.
    new and old:
  2. Jan 12, 2023 at 4:38 PM
    Yeah, I don’t know how it could get that dark for anyone. Hopefully it’s not purple since that would indicate they mixed dot 5 with you dot 3/4 brake fluid. Maybe if you have any earlier engine bay pics of the reservoir it would let you know if it was just getting that way with time.
    robabeatle[QUOTED] likes this.
  3. Jan 12, 2023 at 4:44 PM
    Usually turns a dark greenish color over time with fluid absorption, and can definitely stain the reservoir. Never heard that about mixing Dot 5 with Dot 3/4 turning it purple. I’ll be sure not to do that! Although then it would match my diff fluids….
    oscardog86 and shifty` like this.
  4. Jan 12, 2023 at 4:48 PM
    robabeatle
    AZ
    The shop that did the drums has a really good reputation in town. Is it possible to just bleed the rears and not the front? I put on icetech rotors and new pads a little prior to that and adjustedthe front rear bias as I spent a good deal of time descending mtn roads. I dont want to be losing braking power due to bad fluid. Might just change it…
    Jack McCarthy likes this.
  5. Jan 12, 2023 at 4:49 PM
    Even if you just 'ranger method' (turkey baster) to refresh what's in the MC res you're probably doing yourself a favor. It's not like it's going to circulate fresh fluid to the caliper or anything, but it'll at least mix fresh fluid with some older. You can extend time between flushes with ranger, but it's no supplement to a proper bleed. I'm with everyone else, If it's that black, I'm skeptical, unless something's wrong causing your fluid to cook.
    Found the RP user! :rofl:
  6. Jan 12, 2023 at 4:50 PM
    Dot 5 is actually purple to differentiate it from dot 3/4 since it’s silicone based. Mixing it might make it a little darker. I’m not sure how it would impact the brake system if it was designed for a glycol based fluid like dot 3/4.
  7. Jan 12, 2023 at 4:54 PM
    Yeah I would change out the fluid in the reservoir and just do the rears if you don’t want to mess with the front brakes. Just verify they didn’t mix fluid first. I imagine dipping a piece of white paper to check the color would help.
    edit: I was just reading that if they were mixed, it would gel so chances are that it’s just really dirty or they replaced all the fluid with dot 5. I’m thinking it’s just dirty.
    There’s a small strainer in there you need to pull out with a small screwdriver or tweezers first to fill the whole reservoir.
    oscardog86 and robabeatle like this.
  8. Jan 12, 2023 at 5:07 PM
    robabeatle
    AZ
    Does this give any indication?
    46DE5F38-2133-4CA4-9097-EC735E872486.jpg A5301143-5E90-4C89-B215-20678AB6DB7F.jpg
  9. Jan 12, 2023 at 5:09 PM
    Oh yeah, that’s the green grease from the seals of the master cylinder contaminating the fluid. Time for a change!
  10. Jan 12, 2023 at 5:16 PM
    I’ve got a speedy bleeder if you want to borrow it, makes life much easier
  11. Jan 12, 2023 at 5:21 PM
    WTF, I've never seen green brake fluid before.
    Never heard of this either. :notsure:
  12. Jan 12, 2023 at 5:33 PM
    robabeatle
    AZ
    Thatd be great, much appreciated . Im not sure when Ill get to this but Ill let you know.
  13. Jan 12, 2023 at 5:34 PM
    robabeatle
    AZ
    haha I guess I got Slimer brake fluid
  14. Jan 12, 2023 at 5:41 PM
    You have not seen my MC in the past. I brought this up to a Toyota tech who told me about the green grease thing. :D
  15. Jan 12, 2023 at 6:04 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Do it the easy way, 2 screws & a $40 tool.
    DEPSTECH 5.0MP Endoscope, 8.5mm Type-C USB Borescope,Waterproof Inspection Camera with 16.5ft Cable and 6 Adjustable LED Snake Camera for Android, Windows/MacBook OS: Amazon.com: Industrial & Scientific
  16. Jan 12, 2023 at 6:14 PM
  17. Jan 12, 2023 at 6:26 PM
    Never heard of the green grease thing. Think it’s due to water absorption and the metal brake lines. Creates a tarnish like when copper turns green.
  18. Jan 12, 2023 at 6:28 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    No, no - I was replying to you attempting to see the timing belt. I think that's what you were saying you were trying to do.
  19. Jan 12, 2023 at 6:29 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    180k was due mileage for a new timing belt. :(
  20. Jan 12, 2023 at 6:33 PM
    Ahh, got it. That camera looks interesting though.
  21. Jan 12, 2023 at 6:35 PM
    Is there copper though? I thought all our lines were steel only with that plastic/vinyl wrap protector to keep it from rusting.
  22. Jan 12, 2023 at 6:41 PM
    Yeah, that's pretty bad, I think your rotors are infected. I think you need to sell me the truck now. I'll compensate you handsomely, $1,507.
  23. Jan 12, 2023 at 6:44 PM
    Most brake lines are an alloy. They’ll have copper/nickel in them and be coated with steel. Easier to work with than pure stainless. Not sure what the tundra brake lines are made of, but look just like all the other hard brake lines I’ve worked with.
  24. Jan 12, 2023 at 7:24 PM
    robabeatle
    AZ
    Did mine at 160K :thumbsup:
    NUDRAT[QUOTED] likes this.
  25. Jan 12, 2023 at 7:24 PM
    robabeatle
    AZ
  26. Jan 12, 2023 at 8:37 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Just fedcba, lol. But that’s a trick, they want you to admit you can’t do it sober. I was around .18 at the end and the officers were split on if I was legal.
  27. Jan 12, 2023 at 8:38 PM
    alb1k
    Left Coast
    It's good
    Yes it does…
  28. Jan 13, 2023 at 5:32 PM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Thanks to @FrenchToasty, i did the ECGS needle bearing delete, new front diff seals, and 930 inner boots from Kartek on remaned Yota axles today. I stretched the outer boots as well to eliminate the bellows rubbing. Pretty happy with how it turned out. Rebooting the axles is something I’ve avoided for years but was actually really easy.
    C8925944-4A71-45BB-AA30-CF6F3DED3620.jpg7CAC0229-FE15-4A5E-B55E-337DD878DCC3.jpgE69AA8B4-AE76-42F9-A012-B12D8E2022CB.jpgDE29749D-0977-4DDB-AB09-1570311D4691.jpgFD74A1CE-13D3-4DC2-81E4-C8CF2CC1C485.jpg105B7299-C0AE-4404-BA05-137027D41AA4.jpg1A444E2A-1421-4225-8037-24AF20E167D5.jpgE0070C4C-2F79-46C7-B6D2-D2A051D3ACAF.jpg
    KNABORES, speedtre, NUDRAT and 8 others like this.
  29. Jan 13, 2023 at 6:03 PM
    Is that a signature thing? I remember seeing a middle finger send off in a prior post.
    Either that or Deja Vu.
    Tundra2 likes this.
  30. Jan 13, 2023 at 6:30 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    It's a celebration of victory. Final gesture to the defeated
