csuviper's Rock Warrior Build (VENOM) - TRADED IN
Discussion in '2nd Gen Builds (2007-2013)' started by csuviper, Jan 6, 2014.
  1. Jun 2, 2015 at 10:12 AM
    #361
    keithg1331
    keithg1331 New Member
    Keith
    2011 Toyota Tundra RW
    3/2" Body/Level Lift
    Hey guys, real quick, I know the answer is in here somewhere, but I can't find it! The wheels I am about to order are a "0" offset, going with 35" tires on a three inch lift, will I still be rubbing the plastic or will I be hitting the body? Plastic is easy and I'm not too worried, but don't want to be rubbing on anything important! Thanks guys!!
  2. Jun 21, 2015 at 8:18 PM
    #362
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Did a little work today in the garage. Installed Eagle Eyes front headlights with HID's
    Thank you @Sean266 for your generous donation to my mod addiction.
  3. Jun 21, 2015 at 8:21 PM
    #363
    Looks good on your truck.
  4. Jun 21, 2015 at 8:46 PM
    #364
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    They look beautiful! Any plans to change the bottom rounds to led?
  5. Jun 21, 2015 at 9:22 PM
    #365
    csuviper
    Broomfield, CO
    You talking about the halos? They are CCFL and i don't plan to change them unless they go out.
  6. Jun 21, 2015 at 9:34 PM
    #366
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    Beautiful=headlights. Was referring to rounds in bumper... LED someday?
  7. Jun 21, 2015 at 9:37 PM
    #367
    csuviper
    Broomfield, CO
    Ah fog lights. I am planning to either change them to led or HID. If the LED are direct plug in without the ballast then i will go that route if they aren't too expensive.
    tat2ude39 likes this.
  8. Jun 22, 2015 at 8:23 AM
    #368
    csuviper
    Broomfield, CO
    Updated original post and 2nd post with pics
  9. Jun 22, 2015 at 5:57 PM
    #369
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Damn those look good!!!
  10. Jun 24, 2015 at 6:38 PM
    #370
    csuviper
    Broomfield, CO
    Again thank you Sean for your generous gift. They look good. I found and fixed the loose wire on the one halo and fixed a broken tab using super glue and a metal angle bracket.
    Figured out the wiring for the HIDs. You were missing the ballasts but luckily I had a set planned for the motorcycle that I used. At first I was just plugging them in wrong.
    You have to switch the polarity from standard.
    The halos are so bright you can't really get a good night pic.
    Only halos
    Halos lights and fogs
  11. Jun 24, 2015 at 9:12 PM
    #371
    csuviper
    Broomfield, CO
  12. Jun 26, 2015 at 9:06 AM
    #372
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    i didnt know toyota had power fold? it folds when you lock door? price? any extra wiring required?
    Power fold Limited side mirror
  13. Jun 26, 2015 at 10:07 AM
    #373
    csuviper
    Broomfield, CO
    Yes the limited Tundras have a power fold. The mirrors are very expensive new, like $600 for a pair. I got this one for $60 on craigslist.
    It requires a switch and extra wiring to get it to work. Only the turn signal works in addition to the powered mirror adjustment.
    The switch for the limited has a button to fold them in. If you don't have that you need to find one or add a separate switch somewhere for that feature.
    8793-iq-jdm-power-folding-mirrors-jdm-pr_6be47a6e064f7427349e5221b909e493d846bbc4.jpg
    TruckyTruck likes this.
  14. Jun 26, 2015 at 10:11 AM
    #374
    csuviper
    Broomfield, CO
    Here is a DIY for the power fold mirror swap -
  15. Jun 26, 2015 at 12:18 PM
    #375
    TruckyTruck
    Gary
    Brian, did Sean do those lightsame or have them done? I really want to try doing it, but want to make sure I don't get condensation. Your truck has a lot of great mods, but those lights are my favorite. Changes the look of the truck.
  16. Jun 26, 2015 at 12:49 PM
    #376
    csuviper
    Broomfield, CO
    Thank you. The headlights are EagleEyes - Link
    They come with the projectors and halos already sealed inside. Sean added some extra silicon and i added more before i installed them on my truck. Haven't had them long enough to get condensation yet. Hoping that i don't. There was a paper in the box that described what condensation is and how it occurs and why it is normal.
  17. Jun 26, 2015 at 12:51 PM
    #377
    csuviper
    Broomfield, CO
    Before
    After
  18. Jun 26, 2015 at 3:56 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    headlights are sick
  19. Jun 28, 2015 at 5:18 PM
    #379
    csuviper
    Broomfield, CO
    Went camping and did a little mudding
  20. Jun 28, 2015 at 5:44 PM
    #380
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    Now that looks like a good time!
  21. Jun 28, 2015 at 7:07 PM
    #381
    That mud looks pretty damn deep!
  22. Jun 28, 2015 at 9:24 PM
    #382
    csuviper
    Broomfield, CO
    Very deep in spots. One hole was probably the depth of the tire. These pics were from early in the trip. I should have got some pics of the last run after we spent a day romping through it with a quad.
  23. Jun 28, 2015 at 9:31 PM
    #383
    csuviper
    Broomfield, CO
  24. Jun 30, 2015 at 7:33 PM
    #384
    TxTundraGuy89
    TxTundraGuy89 New Member
    Korwin
    Definitely sub'd to this!! How does the truck handle the mud? I know when it's engaged its crazy happy just waiting to get mine muddy.
  25. Jun 30, 2015 at 7:36 PM
    #385
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    Did anyone get stuck? You in 4WD or 2?
  26. Jun 30, 2015 at 7:54 PM
    #386
    csuviper
    Broomfield, CO
    Almost forgot. Stupid ford. Hooked up front to front and i pulled him out in reverse with ease.
    I'm 4x4 and think the other trucks were 4x4 too.
  27. Jun 30, 2015 at 7:55 PM
    #387
    TxTundraGuy89
    Korwin
    Hahaha that's awesome!!
    T-Rex266 likes this.
  28. Jun 30, 2015 at 7:59 PM
    #388
    csuviper
    Broomfield, CO
    Handled amazingly. 4 high at first and blasted through. Later i went in 4 low and slow. Crawled right through the mud. The duratracs were perfect.
    TruckyTruck and tat2ude39 like this.
  29. Jun 30, 2015 at 8:00 PM
    #389
    TxTundraGuy89
    Korwin
    Awesome good to know!! I have some bf goodrich at on mine just curious how the 4x4 handles the mud.
  30. Jun 30, 2015 at 8:06 PM
    #390
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    Great news, I'll be looking for some mud soon. Next monsoon...
