Limited TRD Off Road Tires Falken AT trail
Discussion in '3rd Gen Tundras (2022+)' started by WingedHussar, Feb 6, 2022.
  1. May 30, 2022 at 4:12 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Anyone know the weight of the factory trd 20’s?
  2. Aug 1, 2022 at 7:17 AM
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    @Falken QA I am installing the Wildpeaks in a 295/60/20 on my SR5 but with the limited wheels this week :) Can't wait to ditch the stock Bridgestone 265/70/18's on my SR5 wheels.
    Falken QA[QUOTED] likes this.
  3. Aug 1, 2022 at 1:32 PM
    StrikeZone
    StrikeZone New Member
    Ontario
    2022 Tundra Limited i-Force MAX
    @Falken QA can you recommend Front and Rear tire pressure for Falken AT3W (load rating E) 285/65/R18 For a 2022 Tundra CM Limited 5.5 (0n 18x18.5 BBS forged wheels). Thanks
  4. Aug 1, 2022 at 2:48 PM
    Falken QA
    Falken QA New Member
    Hello,
    Looks like you had the stock 265/70R18 (116 load rating) tire size at 35 PSI? If so, the OE tire supported 2696 lbs.
    To get this same capacity on the LT285/65R18, you'll inflate to 53 PSI. Keep in mind this is based on the OE tire, which is based on a full cab of people, full tank of fuel and fluids, and to support the truck's payload and towing claims.
    Tundrastruck91 likes this.
  5. Aug 1, 2022 at 2:52 PM
    Falken QA
    if you have any issues, let us know. If not, rotate every 4000-6000k miles (cross rotate is possible due to symmetrical tread design).
    Your air pressure should be 49 PSI for the LT295/60R20s. this will match the same load capacity of 2696lbs of the OE tires.
    Sincerely,
    Roctane84 likes this.
  6. Aug 1, 2022 at 3:07 PM
    StrikeZone
    Ontario
    Thanks @Falken QA The stock tires are Yokohama Geolander X-CV 265/60R20 (112H) at 35PSI. Does this change the recommended PSI for the above LT rated tires (285/65R18)?
  7. Aug 1, 2022 at 3:51 PM
    Falken QA
    I see. With that in mind, yes, the pressure will change. The 112s load rated /265/60R20 tires would support 2418 lbs at 35 PSI.
    The adjusted pressure for the LT285/65R18 would be 45 PSI.
  8. Aug 1, 2022 at 4:24 PM
    benca1
    benca1 New Member
    Wow you serious? I have never had a Toyota with that much psi. Wouldn’t that cause the tpms light to come on being to much pressure? Or is there a way to recalibrate the psi of the tpms?
  9. Aug 3, 2022 at 4:09 PM
    Falken QA
    This is to match the OE tire's load capacity & to avoid any underinflated scenarios. Those air pressures are based on a full cab of people, full tank of fuel, and vehicle topped off of fluids. However, there are times when the vehicle doesn't have a full cab of passengers and/or fluids. It is up to the owner to adjust for comfort when not fully loaded.
    Coming from a P/non LT size to an LT size will almost always require a higher air pressure to match OE tire load capacity.
  10. Jan 12, 2023 at 12:05 PM
    Bneff89
    Bneff89 New Member
    2023 SR5 TRD Sport Blueprint
    @Falken QA I see here on Tirerack.com that the A/TW3 in a 285/65R18 116T SL weigh 41 lbs? Can you confirm the weight of these please?
    Falken QA likes this.
  11. Jan 18, 2023 at 5:31 PM
    Falken QA
    This is correct. Keep in mind that the SL/non-LT size 285/65R18 is the OE/OEM tire that comes on the new Tundra, so be wary that it will not have the higher tread depth that you typically see on our non-OE/off the shelf Wildpeak AT3w's.
    OE version (part# 59000770) starts at 9/32nds, whereas our non-OE/off the shelf Wildpeak AT3w hover around 13-14/32nds of starting depth.
    We do offer a LT285/65R18 E/10 load (part# 28030827) Wildpeak AT3w that has even more tread depth than OE and our non-LT size tires.
    MGA2242 likes this.
  12. Jan 18, 2023 at 7:06 PM
    Bneff89
    Bneff89 New Member
    Great thank you!
