2016 factory hitch removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by CentralNick, Dec 14, 2022.
  1. Dec 14, 2022 at 11:31 AM
    CentralNick
    CentralNick [OP] New Member
    2016 tundra 1794
    I want to remove the factory hitch to clean up the rust. Probably get it cleaned and powder coated. Any thing to watch out for? I have installed and removed a few aftermarket hitches so I have some ability. Thanks
    MedCityMoto likes this.
  2. Dec 14, 2022 at 11:35 AM
    2mchfun
    Welcome from OKC! It's a heavy one, be careful!
  3. Dec 14, 2022 at 11:41 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    The hitch is an integral part of the frame and bumper.
    Enjoy...:cool::thumbsup:
    Screenshot_2021-08-21_131926_08f19de85bd11b0ffb2d10fb6fab27b0054df1c4.jpgnuzz428i_3a80e705e4c773d38b871a23fd713f9c61f657ad.jpgg0l6sjgn_3c0915b9a44ecfde95e11d1e9452e3d8bd25ec5a.jpg
  4. Dec 14, 2022 at 11:51 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Have a 2016 here as well, and some surface rust on mine too.
    My plan is to remove the plastic bumper top thing, tape off some plastic all around it, and use a wire brush on a drill attachment to remove existing rust and paint. Then, POR-15 via brush application. Finally, gloss black Rustoleum. Let dry a day, replace plastic cover. Seems easier than removing it, and changes little/nothing about the steps to take. Only downside is the need to use paint vs a powdercoat.
  5. Dec 14, 2022 at 12:07 PM
    YouFallWeHaul
    YouFallWeHaul New Member
    2010 Marine Blue DC 4x4
    Another option would be to spray it with an oil undercoating product, which should prevent rust, protect the components, and keep bolts from freezing. And its tendency to creep into small gaps would eliminate the need to disassemble anything.
  6. Dec 15, 2022 at 3:44 PM
    CentralNick
    2016 tundra 1794
    Well, I got the hitch off. That's not a project for the faint-of-heart. Only broke one non-critical bolt but was able to remove it later. Didn't have a way to weight it but it seems like a hundred pounds. I'm going to get it powder coated.
    17inferno, MedCityMoto and 1lowlife like this.
  7. Dec 15, 2022 at 3:52 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I admire your dedication to getting what you want...:cool:
    Well done Sir..:thumbsup:
    Post a pic when you're done..
  8. Dec 15, 2022 at 6:03 PM
    MedCityMoto
    Definitely reassuring my decision to paint it in place, here!
  9. Dec 15, 2022 at 6:11 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The rust on that doesn't seem bad enough to warrant removal imo.
  10. Jan 12, 2023 at 9:03 AM
    CentralNick
    2016 tundra 1794
    Got my hitch done at Performance Powder Coating Columbus Ohio
    I intend to use a spray on rust inhibitor on the frame as I reassemble.
    I have used POR15 before, but I don’t think I could clean the frame properly for that.
  11. Jan 12, 2023 at 11:38 AM
    MedCityMoto
    Mind if I ask what that ran you?
  12. Jan 12, 2023 at 12:38 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    That's purdy..:D
    It's going to look better than it did new..:thumbsup:
  13. Jan 12, 2023 at 2:15 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Make sure the hitch still fits in the receiver before re-installing.
  14. Jan 12, 2023 at 2:21 PM
    I'm not sure that thing looks like it was properly prepped for powdercoating. Should have been sandblasted down to bare metal and all the rust that didn't blast away ground down to bare metal to have a virgin surface to coat. That being said, grinding material away from a structural component would give me as much pause as it being very rusty. I see rough or bubbly spots in the same places the rust was visible in the prior pictures.
  15. Jan 12, 2023 at 2:23 PM
    Maybe it's just so glossy it's reflecting something else in the room?
  16. Jan 12, 2023 at 3:08 PM
    CentralNick
    2016 tundra 1794
    KNABORES, Why do you think it wasn't done properly?
  17. Jan 12, 2023 at 3:13 PM
    First image shows all of the rusty scale buildup:
    second post coating image shows what looks like bubbly areas in the same areas on the back side of the hitch:
    How does it look close up? I’ve had a powdercoating disaster before, zero prep by the shop, all started peeling off.
  18. Jan 12, 2023 at 4:03 PM
    CentralNick
    2016 tundra 1794
    I'll certainly keep an eye on it.
  19. Jan 16, 2023 at 4:14 PM
    CentralNick
    2016 tundra 1794
    Got my hitch and bumper back together, I even put all the bolts back! I'm happy with it.
  20. Jan 16, 2023 at 5:09 PM
    Labrayota
    Labrayota New Member
    Central Illinois
    2017 Crewmax TRD Off Road MGM
    Great job, looks like new!
