Steering wheel shimmy
Discussion in '2nd Gen Tundras (2007-2013)' started by Henhouse1, Jan 11, 2023.
  1. Jan 11, 2023 at 1:52 PM
    Henhouse1
    Henhouse1 [OP] New Member
    New to me 2010 DC 4.6 4x4 with 152k miles. Just had tires balanced but have a mild shimmy in the steering wheel. Tires were out of balance but are rolling smoothly now. Anyone had this on these trucks? Possible tie rod? Ball joints? Tires seem to be round. No pulsation in the brake pedal.3DD73C98-99EC-4791-A285-0A5A760932C3.jpg
  2. Jan 11, 2023 at 8:26 PM
    biggsy
    biggsy New Member
    Warren
    2010 Tundra DC Rock Warrior
    Having the same issues. 2010 160k miles. New rotors and wheels balanced. Hmmm.. alignment maybe? Or shocks?
  3. Jan 11, 2023 at 8:37 PM
    Henhouse1
    No other symptoms. Handling is nice and crisp. Ride is smooth. I’m sure it is a worn component. I’m just not up on t-shooting front end parts. I do feel/hear a single click/pop when turning the wheel from a dead stop. Got the Wifey to turn the wheel while I observed underneath but couldn’t visually confirm excess movement in ball joints and tie Rod ends. Stumped! Probably need to jack it up and pry on things.
  4. Jan 13, 2023 at 12:38 PM
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    I have the same issue at 50-60. I know for sure ive narrowed it down to warn out lower ball joint, uca ball joint and the tie rod being out. Im at 183K miles lifted on OEM orginal joints so i know shes had it.
    Henhouse1[OP] likes this.
  5. Jan 14, 2023 at 8:50 AM
    Henhouse1
    I’m at 152000 and mine disappears at about 50. Most noticeable 25-45.
  6. Jan 14, 2023 at 1:08 PM
    2007TundraCM
    2007TundraCM New Member
    Venice Florida
    2007 Tundra Limited TRD CrewMax
    TRD rear sway bar
    Could be a lot of things but don't rule out one of the front wheel bearings. At 155k mile I developed a slight shimmy at 55-60 mph and got the tires balanced twice with no luck.
    Ended up being the front right wheel bearing.
    juanpsi likes this.
  7. Jan 14, 2023 at 1:27 PM
    Henhouse1
    Would definitely have a very noticeable noise with a bearing loose enough to cause a shimmy.
  8. Jan 14, 2023 at 1:38 PM
    2007TundraCM
    Venice Florida
    TRD rear sway bar
    slight shimmy and no noise at early stage of bearing wear, at least for me.
    My right rear bearing went at 125K and it had a low pitch noise at highway speed that I did nothing it about until 130K
    at which point it was much louder.
  9. Jan 14, 2023 at 1:40 PM
    Henhouse1
    HAHA! I've got that one too! waiting for parts for left rear axle bearing!
  10. Jan 14, 2023 at 1:51 PM
    2007TundraCM
    Venice Florida
    TRD rear sway bar
    For the rear bearing I ended up buying the complete assembly from rockAuto which came with the axle shaft, new backing plate and bearing all assembled, plug and play.
    My backing plate was rusted out and I didn't want to deal with getting the bearing on and off. I replaced both sides.
    2007 TOYOTA TUNDRA 5.7L V8
    DORMAN
    926145 (926-145)
    Axle Shaft $ 384.99
    Just checked their website for picture
  11. Jan 15, 2023 at 4:32 AM
    Henhouse1
    Wow! How much was shipping?
    My truck is a Texas/Ga truck so no rust. Bought oem bearing assy. I should have done what you did. Atlanta Driveline will install the bearing.
  12. Jan 15, 2023 at 5:47 AM
    2007TundraCM
    Venice Florida
    TRD rear sway bar
    $35 fedex ground shipping
