“WhAt SIzE tIrE wIThoUt liFt?”
Discussion in 'Wheels & Tires' started by Gyoaz, Jan 11, 2023.
  1. Jan 11, 2023 at 12:40 PM
    Gyoaz
    Gyoaz [OP] New Member
    Gary
    So AZ
    Cement SR5 4x Crewmax
    Invisible tundra
    my OME lift is on the way and I just blew a tire. Now my timeframe for new wheels and tires has been moved up to “immediately”. I’d wanted to do a 285/70/18. Will this size work temporarily until the I get the lift in?
  2. Jan 11, 2023 at 12:42 PM
    I don't think so.
  3. Jan 11, 2023 at 12:53 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    285/65/18 is the largest "no issues" tire for no lift on a gen 2.5 with stock wheels.
  4. Jan 11, 2023 at 1:02 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    you ok not making turns?
    :duh:
    WVI and Saltyhero13 like this.
  5. Jan 11, 2023 at 1:11 PM
    Gyoaz
    Gary
    So AZ
    Invisible tundra
    I figured I can avoid them for a couple of days.
  6. Jan 11, 2023 at 1:19 PM
    Gyoaz
    Gary
    So AZ
    Invisible tundra
    I’m installing the lift this week, unfortunately one the stock tires decided that was too long a wait and I’ve gotta replace it asap. I’m hoping I can run an oversized tire for a week or so without much more than some minor rubbing until I install the lift.
  7. Jan 11, 2023 at 1:28 PM
    ColoradoTJ and Gyoaz[QUOTED][OP] like this.
  8. Jan 11, 2023 at 1:46 PM
    mountainpete
    Exactly which wheel and tire combo are you planning? The problem isn't the height, it's the width.
  9. Jan 11, 2023 at 3:45 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just put 2 larger tires on the rear and leave stock in front. Stay in 2wd.
    Sunnier and Mr.bee like this.
  10. Jan 11, 2023 at 3:48 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    That's what she said...
    hagrid likes this.
  11. Jan 11, 2023 at 4:58 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  12. Jan 11, 2023 at 6:38 PM
    mountainpete
    This actually isn’t a bad idea. For a few days.
    joonbug[QUOTED] likes this.
  13. Jan 12, 2023 at 7:44 AM
    WaterTrash
    WaterTrash New Member
    Why not just run with the spare on until you get the lift installed?
    Bbgunasassin and Sierradevil like this.
  14. Jan 12, 2023 at 7:59 AM
    mountainpete
    Another smart idea.
  15. Jan 14, 2023 at 2:33 PM
    You should be tagging @Gyoaz
  16. Jan 14, 2023 at 3:41 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    With stock wheels (60mm) and stock suspension 285/70r18 should be fine outside of removing the front inner liner/mini mud flap. (Example: I did 315/70r17 with a 50mm offset on stock suspension). Contrary to popular opinion lifting the truck alone won’t increase tire size as the tire still needs to fit during up travel unless it’s a mall crawler that will not articulate. Have the tire place do a test fitting with one tire (may want to remove the mud flaps/inner front fender beforehand, can add them back easily later).
