Transmission filter change/No Reverse or neutral
Discussion in '2nd Gen Tundras (2007-2013)' started by Amenaman, Nov 21, 2022.
  1. Nov 21, 2022 at 4:44 PM
    Amenaman
    Amenaman [OP] New Member
    2007 Tundra Limited crewmax
    Hello I’m new to the community. I had just gotten a 2007 Tundra limited with the ab60f transmission. I did a fluid change in my transmission along with the filter and a bad solenoid s2. Now I put everything back the way it was and now there is no reverse. Also, there is no neutral. It drives in neutral.
    I am wondering if anyone has a suggestion on how to resolve the issue?
    thank!!
  2. Nov 21, 2022 at 4:49 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    This is exactly what happened to my 2010 but about 5000 miles after a full drain fill and filter. I got a low mike junkyard transmission after the best transmission shop in town said the transmission was toast.
    good luck.
    Amenaman[OP] likes this.
  3. Nov 21, 2022 at 6:26 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I had the same thing on a Chevy transmission, and it was seized up/welded clutch packs and rings from being low on fluid. I would check the fluid level again. Unless the solenoid is somehow causing that, I suspect you need a new trans or rebuild that one.
    baraynavab and Amenaman[OP] like this.
  4. Nov 21, 2022 at 7:34 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    If it worked before you tore into it then it’s either low on fluid, bad solenoid or you pinched some wires.
  5. Nov 21, 2022 at 7:36 PM
    Someone on here recently changed their trans filter and the new one didn’t have the same orifices lining up where the old one did. Essentially blocking some of the fluid channels in the trans. Would double check the trans filter is the correct one. The solenoid was the correct one and correctly installed and the fluid level is correct.
    Amenaman[OP] and Filthyphil like this.
  6. Nov 23, 2022 at 7:09 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    So you know these trucks have a specific way to check for the transmission fluid right? The fluid has to be checked at a specific temperature using the fluid check nut. Did you check it using the specific method? if not please check the fluid level properly.
  7. Nov 24, 2022 at 4:33 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I would guess that the wrong filter was installed or the solenoid is bad.
    No need to look for a new transmission yet.
  8. Jan 9, 2023 at 6:03 AM
    alainaube90
    alainaube90 New Member
    20230108_210320.jpg 20230108_210312.jpg 20230108_220331.jpg Had same issue with my parts truck a 2008 5.7 ab60f transmission stuck forward no park ,neutral or reverse was C1 clutch was burnt welded together my driving trulck has the same issue will check if its the same C1 clutch that is burn't or either C2 or C4 will confirm after removal hope this helps others there is not much about this specific problem online and i had to have 2 lucky me lol...
    vtl likes this.
  9. Jan 11, 2023 at 8:23 AM
    alainaube90
    Here are the results of my 2007 Tundra AB60F TransmissionNo codes stuck forward in P,N,D and no Reverse. Burn't C1 Forward clutch.20230110_191152.jpg 20230110_191345.jpg
  10. Jan 16, 2023 at 8:57 AM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    Hello. I'm about to do a drain and fill on my 2010. Wondering if you dropped the pan and replaced the filter on yours? What exactly was the cause of your transmission failing? Thanks.
