  1. Jan 9, 2023 at 3:48 PM
    daveeasa
    I considered myself to be lucky in that I stumbled into a fantastic tile guy. I kept making up project for him. Spent a lot but super happy. I’m legitimately considering asking if he would fly up here and work on this new house.
    shifty`, FirstGenVol and KNABORES like this.
  2. Jan 9, 2023 at 3:52 PM
    Sunnier
    Sunny
    San Diego, CA
    Hey, I’m still here in SD. Can you please shoot me his contact info in a PM?
    NUDRAT[OP] and FrenchToasty like this.
  3. Jan 9, 2023 at 4:15 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I think i want a tankuzzi.
    I think i could make it work with a firepit and a radiator.
  4. Jan 9, 2023 at 4:33 PM
    I say dual fire pit, for ambiance of course
    bmf4069, Sunnier and Mr.bee[QUOTED] like this.
  5. Jan 9, 2023 at 4:36 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  6. Jan 9, 2023 at 5:35 PM
    We have a cabinet guy for that. He's down in south FL, we flew him up when overhauling the kitchen. Dad and I did all the drywall, electric, plumbing, windows, lighting, flew up the cabinet guy, and hired a FL transplant to weave in some matching flooring.
    daveeasa[QUOTED] likes this.
  7. Jan 9, 2023 at 5:37 PM
    PS - @FirstGenVol here's the UI for the smartphone app. If you connect the device to wifi, it regularly uploads and will alert you if anything exceeds their set threshold. I'm hoping they eventually let you set your desired alert threshold, but so far it's not too spammy. This is the default home dashboard. If you tap on any of the items, you can see a linear graph at various intervals: last 48hr, last week, last month, last year (or similar). Very user friendly, good UI/UX.
    FirstGenVol likes this.
  8. Jan 9, 2023 at 7:02 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    @FirstGenVol I thought you were retiling the entire shower. A tile floor is so much nicer, but more $$ for sure. If you reuse that pan, do yourself a favor and do something to deaden the hollow sound. Then cover the walls with your choice of stucco paper. Then sheet with hardibacker. Some type of seam tape is always a good idea. Then generously coat with redguard or the likes. The reason you don't want drywall behind the hardibacker, is because it would push the tile out another 1/2", requiring oversized schluter, and it's completely unnecessary. No room for a bench, but niches are nice to have, and those get framed in before the paper covers the walls.
  9. Jan 9, 2023 at 7:32 PM
    It's controversial, but Loctite foam is what I used with ours. It's minimal expanding, but you need to keep solid weight on it while it's rising, and the floor should be leveled.
  10. Jan 9, 2023 at 7:46 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    completely unrelated to the tundras. but research i've been doing seems to point at the 2gr-fse block should bolt up to FE heads..
    the 95 tacoma is the one i keep considering engine swapping (im talking later down the line.) the 2gr with the tune the mr2 has makes ~300hp and 280 ft lbs of torque. should be an easier fit than a UZ.... am i crazy for wanting to attempt this swap in the next few years?
    lsaami, txagg and Mr.bee like this.
  11. Jan 9, 2023 at 7:50 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Wait, so fse heads could fit the 4.0?
  12. Jan 9, 2023 at 7:56 PM
    empty_lord
    05 rollover special
    a dual VVTI 4.0 likely. but i wouldnt want FSE heads.. the dual VVTI 4.0 has the largest intake ports of all the GR engines.
    the single VVTI 4.0 is a totally different setup.. nothing really interchanges. the reason to run FE heads instead of FSE heads its because the tunes are far more mature, the FE is making more power than the FSE anyway at this point, and parts like cams exist for it.
    Mr.bee[QUOTED] likes this.
  13. Jan 9, 2023 at 7:57 PM
    If you have the resources and known-how to blaze new trails so others can explore, go for it. That is truly the American spirit.
  14. Jan 10, 2023 at 5:38 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    The ditra is the waterproof membrane. Use it anywhere you want sealed from water penetration. In commercial installs, we used it on shower floor and walls, and not on the bathroom floor (unless it had a floor drain).
    it’ll be fine, especially if you’re using Schluter ditra. That goes right overtop anyways. We used green board and normal drywall with schluter ditra.
    usually cement board is used in a conventional shower.
    shifty` and FirstGenVol[QUOTED] like this.
  15. Jan 10, 2023 at 3:55 PM
    I got a new truck today.
  16. Jan 10, 2023 at 3:56 PM
    GODZILLA, NUDRAT[OP], lsaami and 9 others like this.
  17. Jan 10, 2023 at 4:04 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    GODZILLA and bmf4069[QUOTED] like this.
  18. Jan 10, 2023 at 4:05 PM
    Tell us about your 5.7. Please.
    GODZILLA, txagg, CodyP and 5 others like this.
  19. Jan 10, 2023 at 4:07 PM
    No f’ing way. Polish those headlights!
    I like the plate (FFS - for fucks sake)
  20. Jan 10, 2023 at 4:09 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Make sure you've got tow hooks and a trans cooler, and what is it? 0w-20?
    txagg and bmf4069 like this.
  21. Jan 10, 2023 at 4:14 PM
    Sadly, it's a 4.6, so I won't get to tell yall about my 5.7.
    I think these are beyond polishing.
    No hooks, I don't know about a trans cooler, and it says 0w20 on the damn oil cap, so I don't see what the big deal is.
    So whatever the "auto LSD" is, my light came on for it on the way home.
    GODZILLA, shifty` and Sunnier like this.
  22. Jan 10, 2023 at 4:15 PM
    What year is it?
  23. Jan 10, 2023 at 4:15 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Work truck? Or replacement? If it has a hitch, bring that trailer down here. We need more pics. We like pics.
    GODZILLA and bmf4069 like this.
  24. Jan 10, 2023 at 4:24 PM
    Outbound
    Aaron
    Northern Alberta
    You fucking traitor.
  25. Jan 10, 2023 at 4:24 PM
    You’re one to talk. :D
    GODZILLA, RUSTYNUTS, bmf4069 and 4 others like this.
  26. Jan 10, 2023 at 4:25 PM
    Outbound
    Aaron
    Northern Alberta
    I have no idea what you're talking about. :anonymous:
  27. Jan 10, 2023 at 4:27 PM
    Me either :rolleyes:
    bmf4069, Outbound, shifty` and 2 others like this.
  28. Jan 10, 2023 at 4:32 PM
    Don't feel too bad. That's still considered average.
  29. Jan 10, 2023 at 4:36 PM
    Among the Pygmy African tribes maybe.
  30. Jan 10, 2023 at 4:40 PM
    Just the smallest displacement V8 ever offered in a Tundra.
    GODZILLA, txagg and shifty` like this.
