My bed step mounts differently
Discussion in '3rd Gen Tundras (2022+)' started by ByeF150HelloTundra, Jan 10, 2023.
  1. Jan 10, 2023 at 8:48 AM
    ByeF150HelloTundra
    ByeF150HelloTundra [OP] New Member
    DFW
    2022 Tundra SR5
    I ordered a bed step for around $180 on eBay so thought I’d give it a shot. Looked like the OEM one in the pictures. When I received it, turns out it mounts differently than the OEM one I’ve seen all the videos of. For this one, the three bolts pictured below (that connect the hitch to the frame) have to be removed and you use those bolts to attach the mounting bracket, as well as the single threaded hole in the picture below. The kick-out part is the same as OEM. Just thought I’d share here since it didn’t come with instructions. Seems like good quality, and I didn’t have to loosen the bracket that you have to loosen with the OEM one. First picture is with prior to install. Second picture is the bracket after install. Sorry for the bad quality. Arm was shaking after getting everything tightened up lol. Will update with some better quality photos when I get the chance. 3D9C2E7A-1851-4929-B36D-1B27FA98B46E.jpg
    Welderdude80 and Gambolified like this.
  2. Jan 10, 2023 at 9:21 AM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    Glad you posted it . Can it handle 300lb ? How strong is it ?
  3. Jan 17, 2023 at 8:26 PM
    Welderdude80
    Welderdude80 New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
    Got a link for it I’m looking at getting one as well ?
  4. Jan 21, 2023 at 1:10 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
    Gambolified and Welderdude80 like this.
  5. Jan 22, 2023 at 1:16 PM
    Timmy23
    Timmy23 New Member
    OR
    None
    Mounted the new bed step from eBay and I am happy with it.
    I’m 230 lbs and it held me up no problem.
    Sits a good 1/2” below bumper, so no contact there.
    Doesn’t stick out on the side of the bumper much either.
    Pretty decent unit overall.
    Photos:
  6. Jan 22, 2023 at 1:16 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    What happens when you forget to leave it down and drag it over a stump
  7. Jan 22, 2023 at 1:19 PM
    Timmy23
    Timmy23 New Member
    OR
    None
    Lol,
    It will bend up like the exhaust pipe that is the same height from the ground! :)
  8. Jan 22, 2023 at 1:26 PM
    FO LO
    FO LO New Member
    Why is the exhaust pipe coming out of the driver side. I wouldn't want to be breathing that s*** in all the time
