Fog lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hadenj, Jan 10, 2023.
  1. Jan 10, 2023 at 3:12 AM
    Hadenj
    Hadenj [OP] New Member
    Haden
    2017 1794 crewmax 4x4
    None
    What could be a cause for the fog lights, amber driving lights and the top bulb in the tail lights not to be working? I have checked fuses but may have missed one. Anyone have any suggestions?
  2. Jan 10, 2023 at 4:49 AM
    2mchfun
    Check fuses again and don't forget the trailer plug fuse. Could you have rodent damage to the wire harness? This is a big problem with soy based wire insulation.
  3. Jan 10, 2023 at 4:51 AM
    2mchfun
    Also there is a small fuse panel way up under driver's side dash, about 1.75" wide x 4" long with a black plastic cover. Way up in there.
