Boost mirror power lock/unlock
Discussion in '2.5 Gen Tundras (2014-2021)' started by ScenicRoute, Jan 3, 2023.
  1. Jan 3, 2023 at 5:02 PM
    ScenicRoute
    ScenicRoute [OP] New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Good evening.
    On my Ford when I lock the truck the mirrors power fold and when I unlock they unfold. I can also push a button to force a power fold/unfold at anytime.
    I was wondering if anyone had success wiring the boost power fold tow mirrors in such a way on a vehicle that did not come from the factory with power fold mirrors!
  2. Jan 3, 2023 at 5:16 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Haha, yup! @RainMan_PNW has an excellent write up on it. Worked like gangbusters for me and on my buddy's truck.
  3. Jan 4, 2023 at 5:55 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I’m in process of refining it a little, but yes. It’s not on lock /unlock, but rather on power on/off of the truck. I’m working on cleaning up the wiring to use a vampire harness to avoid any wire taps, and adding a switch to enable/disable the function as well.
    Squatting Pigeon and texasrho83 like this.
  4. Jan 4, 2023 at 6:04 AM
    ScenicRoute
    You’re definitely right. The more I think about it the programming on Ford is more specific. As the truck also locks and unlocks in and out of park…and the mirrors don’t move on those commands.
    So yes, power on and power off would be more desireable.
    I’ll search for your write up! Thanks for doing the legwork on this project!!
    texasrho83 likes this.
  5. Jan 4, 2023 at 6:06 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I also thought about adding a switch so I can freeze them in extended mode for washing the truck vs having to turn IGN on to do that.
  6. Jan 4, 2023 at 6:08 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    It would definitely be good to have a switch backup, that way in freezing temperatures you can turn the auto fold off. Don’t want to break any gears if they’re all frozen solid.
    My $0.02 :homer:
    RainMan_PNW and texasrho83 like this.
  7. Jan 4, 2023 at 8:47 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Working on it between having to fly to TX to work on other people’s trucks and having a day job…
    The design of these mirrors have a spring loaded “key” that engages in a notch in the housing to actually drive the fold. If it encounters enough resistance, the key pops out of the notch and allows the motor to still move without the mirror going with it (or when something forcibly folds the mirror without the motor doing it).
    It can still do damage if it happens often enough, but it’s less of an issue than a fully gear-driven system
  8. Jan 4, 2023 at 9:14 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Where in TX? :popcorn:
  9. Jan 6, 2023 at 4:59 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Going to be in Ft Worth and Austin over the course of the next week.
  10. Jan 6, 2023 at 5:03 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Kickass. Must be a helluva job to do on a truck...
    Taco-Spike likes this.
  11. Jan 6, 2023 at 5:07 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Most of the trip is for my day job - have a conference in Austin.
    The truck is just trying to fix something that isn’t working right from an install last fall.
  12. Jan 6, 2023 at 5:13 AM
    coTony
    Tony
    Montrose, CO
    This is what I have been wanting for my Tundra. I looked for the thread and I did not find it. I will keep looking
  13. Jan 6, 2023 at 6:08 AM
    RobertD
    Robert
    DFW, Texas
    WillTunBlack20 likes this.
  14. Jan 8, 2023 at 4:53 AM
    coTony
    Tony
    Montrose, CO
  15. Jan 8, 2023 at 6:46 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
