  1. Jan 7, 2023 at 12:10 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    :bowdown:
    Ace96 and RainMan_PNW[QUOTED] like this.
  2. Jan 7, 2023 at 1:15 PM
    Monkeyballs
    Monkeyballs New Member
    Kelly
    2014 black platinum
    Lifted
    Bought a toy hauler and put trailer brakes on it. Still got to get a stabilizer hitch to get her leveled out
  3. Jan 7, 2023 at 1:20 PM
    centex
    centex New Member
    Played with the tune in the engine.
    bulldog93 likes this.
  4. Jan 7, 2023 at 1:22 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    cartage1 and bulldog93 like this.
  5. Jan 7, 2023 at 1:24 PM
    centex
    centex New Member
    Been posting in there already on one of the other threads. Haven’t had a chance to log yet cause of weather so for now it’s just minor things.
    reywcms and 1UP like this.
  6. Jan 7, 2023 at 2:18 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Scored new 1” lift blocks and u bolts for $20 locally
  7. Jan 7, 2023 at 2:25 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    [​IMG][/QUOTE]
    Those side panels are very functional, had my doubts at first, but now after having my set for a while I am convinced they were a good buy.
  8. Jan 7, 2023 at 2:29 PM
    PlaysARobin
    PlaysARobin New Member
    Thomas
    East Houston - Texas
    2021 TRD Pro Super White
    (2021 TRD Pro) AMP Steps, Ceramic Tint 5/20/70 windshield, Kilmat floor, doors and rear with Audiofrog/Arc audio/JL speaker upgrades and factory HU. AJT blackout. Ironmax4x4 Raid bumper with 10w amber work lights and 32" light bar. Rago dash setup with Bulletproof phone mounts. VLEDs interior kit with front and rear footwell lighting. X2Power AMG 27F.
    Super tempted to add this to my to-do list. Holster + easy knife, flashlight, multi-tool spot would be a very nice to have feature.
    catus[QUOTED] likes this.
  9. Jan 7, 2023 at 2:41 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
  10. Jan 7, 2023 at 2:50 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Those look great! Nice color too! ;):cool:
  11. Jan 7, 2023 at 3:02 PM
    Changed my oil and rotated my tires. Also changed the rear diff fluid. Any idea what these little disc shaped metal things are?? They were stuck to the magnetic drain plug.
    341B5794-344A-440D-9F6A-3331471BE515.jpg 73C0B02A-E080-43AE-8A01-10081B97F91E.jpg
  12. Jan 7, 2023 at 3:30 PM
    CaptRussia253
    Ruslan
    I’ve never seen that before. Maybe something accidentally left behind during manufacturing? Don’t look like anything that would come off the gearing.
  13. Jan 7, 2023 at 3:32 PM
    CaptRussia253
    Ruslan
    Just picked up new factory bed tie downs locally for $30. Going to mount my spare inside the canopy in preparation for my high clearance rear bumper, when I actually order it haha.
    bulldog93, RustyShackle323 and JCBerb like this.
  14. Jan 7, 2023 at 4:34 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    TRD Pro is based off the Limited trim starting with the 2019 model, but does not have BSM or parking assist (sonar) as an option.
    I added BSM to mine and knew sonar was a possibility. I had someone reach out and ask to pay me to add them both to his TRD Pro - he wasn’t comfortable with tackling it himself. I did the install in September, but the sonar system wasn’t functioning at all. Since then, I added it to my truck to troubleshoot the full install and function, and then came back down to TX finish the installation on the other truck to fulfill my commitment to get it working.
  15. Jan 7, 2023 at 4:40 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I keep going back and forth between those and Hot Tails
  16. Jan 7, 2023 at 4:42 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Couldn't find a decent plastic trim removal tool last minute, but a small plastic putty knife did the trick (didn't want a slotted screwdriver marring things up):
    It seems someone got Armor All or something on the clear plastic:
    This gauge cluster plastic has been bothering me for my month of ownership. I'll probably try wet-sanding it, but I'm open to suggestions. Something like $70 seems a bit steep for a new replacement.
    The real reason for all of this is that I want to make sure it's all fully cleaned out inside the dash and air vents from mice, then I'll be installing mesh screen to keep them out. I'm going to see if I can sandwich is between the body sheet metal and the plastic intake vent. I'll be painting the silver and chrome trim. Then there's this noise that comes sometimes on startup and about a minute after shut down (possibly blender door actuator):
    https://youtube.com/shorts/FyaFmZV8LS8
  17. Jan 7, 2023 at 4:48 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Also not mine, but ripped apart another truck today.
    Boost power fold tow mirrors to factory folding switch
    Light bar in the Victory stealth bumper
    Auxbeam switch controller and connection of light bar and mirror reverse lights to it
    I’ll let the owner post the finished pix.
    GAknight, cartage1, Patch999 and 9 others like this.
  18. Jan 7, 2023 at 4:50 PM
    Hottails!!
  19. Jan 7, 2023 at 4:54 PM
    Here you go...index #2....the cluster lens is $35.00
    https://www.sparksparts.com/v-2014-...ition--5-7l-v8-gas/body--cluster-and-switches
    bulldog93 and the red[QUOTED] like this.
  20. Jan 7, 2023 at 4:55 PM
    the red
  21. Jan 7, 2023 at 5:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    You can look sideways at that lens cover and it will scratch. I’d probably just buy the replacement…
  22. Jan 7, 2023 at 5:06 PM
    RainMan_PNW
    Casey
    Clark County, WA
    the red[QUOTED] and Tundra234 like this.
  23. Jan 7, 2023 at 5:09 PM
    Yep. I bought the Screen******** kit for mine. Well worth the money.
    Tundrastruck91 and the red like this.
  24. Jan 7, 2023 at 5:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Was that auto-redacted?
  25. Jan 7, 2023 at 5:15 PM
    the red
    What kit is this?
    I may end up ordering a new lens, that’ll be easy to change out later. Also, I may upgrade to a later model gauge cluster too, so we’ll see.
    Tundrastruck91 likes this.
  26. Jan 7, 2023 at 5:16 PM
    No, I just did that because I think I listed the site once before and it ended up like that. :notsure: I'll PM you.
  27. Jan 7, 2023 at 5:16 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    I’m still liking mine. They are just convenient not having to reach around to grab handle.
  28. Jan 7, 2023 at 5:19 PM
    Droptarotter
    Droptarotter New Member
    2020 Tundra TRD Off Road, Double Cab
    Try Barez Auto Parts in Calgary, they had a 2013 Platinum that I just bought some parts from.....403-604-4175
    Most times that is too expensive if shipped into Canada.......we get raped on duties and brokerage fees. The only way a US supplied shipment works for us is if we ship to a USA address then go pick it up.
    Cheers
  29. Jan 7, 2023 at 5:21 PM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Pulled my steering wheel to knock out this leather wrap I bought over 6 months ago :anonymous:
    Gonna throw on a movie and get my stitch on
  30. Jan 7, 2023 at 5:27 PM
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    I did the hot tails because I like the natural OEM look best. The hot tails are insanely bright, and I love the amber switchbacks instead of the brake light as the turn signal. Reverse is like the sun being beamed behind you. Highly recommend it.
