Fuel Tank Capacity on 2022 Tundra Limited, TRD Off Road
Discussion in '3rd Gen Tundras (2022+)' started by Kiwi Canuck, Jan 2, 2023.
  1. Jan 6, 2023 at 9:06 PM
    T315
    T315 New Member
    2022 Tundra Crewmax TRD Offroad
    I have the same trim and get around 400miles
  2. Jan 7, 2023 at 4:40 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I'm pretty sure all limited and above trim model comes with big tank, just like the previous gen. Only SR5 and SR trim comes with smaller 22.5 gal tank. But SR5 can get bigger tank based on package option.
    I have a SR5 TRD sport premium with advance tech package that adds the 32.2 gal tank.
    Today I drove my truck till DTE says Refuel and about another 10 miles until I got to my preferred gas station. Put in 30.7 gal. The most I ever filled up. Most time I fill up around 27-28 gal, but that's before the light turns on.
    When I got to pump:
    Filled up.
  3. Mar 16, 2024 at 7:29 AM
    LayK
    LayK New Member
    Layton
    Baton Rouge
    2022 Silver Tundra TRD 4x4 Limited Hybrid
    So my dealer (Louisiana) sold me my truck advertising a 22 gallon tank, which I am now curious because the other day I filled up after the dash told me I had 18 miles to E and I filled up 27 gallons. I am averaging about 18 MPG, so I was assuming I had a 28 gallon tank.
    Does that count as my reserves, or does that mean I actually bought a 29 gallon tank, and still have 6 more gallons roughly in reserve? Any help is appreciated.
  4. Mar 16, 2024 at 7:52 AM
    DRP
    DRP Old Member
    Dave
    I'm guessing you have the 32 gallon tank. 6 gallon reserve is pretty common on the 32 gallon tank. If you crawl under the truck and see a gas tank that is longer than any tank you've seen in your life, its 32 gallon.:thumbsup:
    LayK[QUOTED], pwpblue and Mattedfred like this.
  5. Mar 16, 2024 at 12:47 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    My platinum I ran it util it just read refuel and almost got 28 gallons in it.20240313_133054.jpg
    Tundrastruck91 likes this.
  6. Jun 14, 2025 at 5:56 AM
    22Tuns
    22Tuns New Member
    Dave
    2022 Tundra SR5 Crewmax 5.5
    Thanks to all that posted. I have the larger tank in my new to me 22 TRD Crewmax. I also noticed how much “safety factor” the gauge has. I don’t like to run it really low, but sometimes it happens due to construction zones and heavy loads on the interstate. Yesterday I saw the low fuel light for the first time. Filled up with 28.5 gallons.
  7. Jun 15, 2025 at 7:13 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    My 32 gallon tank low fuel light also comes on with ~6 gallon reserve which is where I usually refuel + or - a gallon or so on road trips. But I have never seen that "refuel" message. Guess I haven't really gotten low enough.
  8. Jun 15, 2025 at 8:22 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    On our recent roadtrip from Colorado to Florida, I notice the computer appears to use the most recent fuel mileage to calculate the DTE. But it only uses around 27-28 gallons for that calculation.
    I have the 32 gallon tank. Here in Colorado I rarely have to use the AC. My mileage is usually around 19 mpg. After a fill up, the DTE is usually around 520 miles. When we were in Florida, and using the AC a lot, my mileage was around 17 mpg. After a fill up, the DTE was around 475. Those numbers seem to support my theory about how DTE is calculated.
    That said, I rarely get below 100 miles DTE. I have no interest in running the tank dry just to see it's full range.
