  1. Jan 7, 2023 at 9:40 AM
    I feel like I should know this by now, but what are they and what size?
    mcharfauros[QUOTED] likes this.
  2. Jan 7, 2023 at 9:59 AM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    On that truck Falken’s at 265/70-16 the lighter AT3Ws
    txagg likes this.
  3. Jan 7, 2023 at 10:15 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I know it’s a different vehicle but I’m thoroughly impressed with the AT3Ws on the wrangler vs the Toyo Open country’s, K02s, and the Kenda Klevers currently on my truck.
  4. Jan 7, 2023 at 11:23 AM
    typhoon
    typhoon New Member
    2003 Tundra AC Limited
    I installed the swing case I got for Christmas today. I definitely going to need the other side now.
    bmf4069, w666, robabeatle and 9 others like this.
  5. Jan 7, 2023 at 12:05 PM
    What makes the AT3's perform better? Do they do well in snow?
  6. Jan 7, 2023 at 12:08 PM
    I had to adjust my headlights again today. I learned a lesson about using cheap housings. I have to adjust these every few months.
    artsr2002 and mcharfauros like this.
  7. Jan 7, 2023 at 12:10 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yes. Quieter road noise wise too
  8. Jan 7, 2023 at 1:37 PM
    mcharfauros
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    OE Assemblies?
  9. Jan 7, 2023 at 1:42 PM
    No. eBay special I think. Maybe Scamazon.
  10. Jan 7, 2023 at 2:10 PM
    Wow, only 4 hours too late and they’re sold out….
    E20D40F0-BF20-4640-BACD-6E578AC29D3B.jpg D0E18A75-089A-4809-9869-17C4B1149A71.jpg
    shifty` likes this.
  11. Jan 7, 2023 at 2:29 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Ah you’re kidding! Sorry man. That sucks
  12. Jan 7, 2023 at 5:03 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  13. Jan 7, 2023 at 5:14 PM
  14. Jan 7, 2023 at 5:32 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    This is only $50 more than what 'auto'zone wants.
  15. Jan 8, 2023 at 1:16 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I hope the barrel on the grill is full of whiskey. I remember hearing stories about early wars when there would be dogs carrying barrels of whiskey hanging from their collar that were used to help numb the injured soldiers. pretty irrelevant but whiskey='merica
    So.... I've been trying to set up a rear diff and am having a bitch of a time sourcing side bearing shims, without ordering an entire bearing or install kit. After spending way too many hours researching, I may have stumbled upon something. I believe the toyota 8.4" rear diff carrier side bearings/shims are compatible with those of a Dana 44. Can anyone confirm that this is correct or not?
    FWIW sourcing most parts for our rear diff isn't so simple. We do have the same diff that was used in the T100's and alot of the V6 tacos, but not all. There are several sites that listed my truck 'not compatible' or 'no search results'. I had more success searching for T100 parts. Do any 1st gen Tundras NOT have a 8.4", 30 spline rear diff? I know there is an 8" made by toyota, but it's incompatible with the 8.4"
    Mr.bee[QUOTED] likes this.
  16. Jan 8, 2023 at 3:31 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    The titan has a 'dana 44' copy, but everything looks so much beefier.
    isnt there a diff guru out there on the west coast? Might be worth a call to pick their brain.
    gasser tank was about the same price as the RA tank, but like 1.5 gallons, and would require a pump, regulator, and would probably only work visually with squatted trucks. And i forgot to remove the pic when i found the 'cheap' transfer tank.
    oscardog86 and RUSTYNUTS like this.
  17. Jan 8, 2023 at 6:05 AM
    You try calling ECGS? They seem to be up on Toyota diff stuff.
  18. Jan 8, 2023 at 11:40 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Zuk in AZ is the diff wizard out west, but he's been winding down his operations.
    Tons of info on his site: http://gearinstalls.com/
  19. Jan 8, 2023 at 12:10 PM
    Supposedly he only does drop offs now.
  20. Jan 8, 2023 at 12:15 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i bet its worth a phone call. Dude might have more info than we need, but future us needs it.
  21. Jan 8, 2023 at 12:49 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    The 8" is 27 spline pinion gear, same ring gear size. The 8.4" is a 30 spline pinion gear, same ring gear size.
    The difference is mostly the pinion flange and strength of the thicker pinion gear.
    They are interchangeable with the matching pinion flange or adapter flange iirc.
    The 8, 8.2 and 8.4 just denotes the slight stronger and higher spline count pinion gear.
    I'd just order shims from toyota once I've measured backlash. Or call west coast differentials (differentials.com), they probably have an aftermarket shim kit they can sell you.
  22. Jan 8, 2023 at 1:06 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well I’ve been going through all my shit I’ve collected over the years. I have all the bearings to for a 8.4” rear diff and a 7.5” front. So I guess I’ll start getting parts ready for a regear. 33” tires now. Might go 32” later (but years from now). Would y’all go 4.10 or 4.30?
    mcharfauros likes this.
  23. Jan 8, 2023 at 1:07 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    If you have 4.3's I'd go with them for 33's.
    4.10's are fine too since you have the 5sp.
  24. Jan 8, 2023 at 1:21 PM
    empty_lord
    05 rollover special
    I’ve got a few 4.10 sets laying around. I’ve never really hurt for gearing when towing. But I’m sitting at like 2500rpm doing 85. Seems a bit low. 4.10 might be the better answer if I decide to down size to 32s later.
  25. Jan 8, 2023 at 2:20 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    If absolutely no chance of bigger than 33's then 4.10's.
  26. Jan 8, 2023 at 2:46 PM
    empty_lord
    05 rollover special
    Yea no this trucks use case Is limited to country roads and stuff with towing it’s main goal. 3 years ago the story was different. But I’m swimming in Tacomas now.
    FrenchToasty and NUDRAT like this.
  27. Jan 8, 2023 at 3:05 PM
    Johnnyroberts
    Johnnyroberts New Member
    Jon
    2003 Grey limited
    I don't know why it didn't load the first time. 9AA529A6-D49C-4B18-8828-59FFF8BDD230.jpg
  28. Jan 8, 2023 at 3:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Crack-tivities!
    dbittle likes this.
  29. Jan 8, 2023 at 4:25 PM
    snoope
    snoope The Old Man
    Dam good weekend for the Tundy :cool:
    Tailgate handle replaced with ease :D and Thank you @tripleconpanna for the "help" on finding one :thumbsup:
    Even had time to R&R the rain guards this afternoon after having to "get at the passenger side" with serious elbow grease ..
    Con's "Artistic" eye helps when doing straight lines & bodywork.. and then put the poor thing to work..:muscleflexing::muscleflexing:
    The bed has a Christmas tree and misc. lawn shrubs filling it.... transfer station run in the AM..:cool:
  30. Jan 8, 2023 at 4:27 PM
    daveeasa
    I don’t really regret 4.56 but I do feel compelled to go a bit bigger on tires. I don’t go 85 in the Tundra much other than that long drive to Oregon.
    oscardog86 and lsaami like this.
