  1. Jan 6, 2023 at 6:56 AM
    daveeasa
    Oh hand sanitizer? That’s a good tip. Thanks. Shifty knows all. I have some sap and bird dung to remove still.
    CodyP likes this.
  2. Jan 6, 2023 at 6:59 AM
    daveeasa
    Ok, bumper photos. Should I just leave as is? Not nearly as big a deal as I remembered from dropoff.
    driver side corner
    passenger corner
    probably not too visible but the truck does have a bit of a lift with the J66 pack so I won’t really know till it’s on.
    Wait and see?
  3. Jan 6, 2023 at 7:00 AM
    Hand sanitizer won't do anything for birdshit. But it's basically alcohol jelly, it works wonders for dissolving tree sap. Put a blob on the sap, rub in a circle, alcohol dissolves the sap, wipe away with clean cloth. Little alcohol wipe or alcohol on a cottonball for final cleanup if needed. The real winner is having it as a gel. With wipes/cottonball, alcohol evaps before finishing the job.
    NUDRAT[OP] and CodyP like this.
  4. Jan 6, 2023 at 7:01 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yeah I’d hate to downplay it if it really is her appendix. Wife is an NP and I’m an EMT so we know a bit but the wife is always gun hoe (is that the right spelling) with things sometimes.
    Just cause you hear hoofs outside doesn’t mean you’re gonna see a zebra, ya know?
    txagg and shifty`[QUOTED] like this.
  5. Jan 6, 2023 at 7:02 AM
    I'd wait and see. But the rust I'm seeing, you'll want to deal with it. I'd just naval jelly per bottle instructions, then hit it with some satin rustoleum.
  6. Jan 6, 2023 at 7:16 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Ok, whats the trick with this? Got the bottom screw out, but cant get it to unhook from the vent. I can move it to the side enough to get the nut off the i relay. Feels like theres a screw on top.
    Gonna have to go get some of that non sticky 'sealing' foam tape.
  7. Jan 6, 2023 at 7:20 AM
    Paging @daveeasa ...
  8. Jan 6, 2023 at 7:28 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Touch it up with a small paintbrush? Cold blue?
  9. Jan 6, 2023 at 7:39 AM
    daveeasa
    I moved it enough to get the nut off. It’s plastic so it bends without breaking.
    ETA: this complication is part of the reason why I pinched the scangauge cable. Not making excuses for myself but it’s tight up in that spot without the vent out of the way. If there is some straightforward way to get the vent disconnected without removing the dash, please do let me know. Otherwise just use your hands to ensure no wire pinching. The OEM harnesses are bundled nicely. It’s just any extras which could get caught.
  10. Jan 6, 2023 at 7:41 AM
    daveeasa
    Spray or touch up brush?
  11. Jan 6, 2023 at 8:15 AM
    I always go for spray. Multiple light, non-covering coats within the can's listed recoat window.
  12. Jan 6, 2023 at 9:23 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Decided to water plants and play 'catch' (retrieve, and i'll fight you for it.).
    i was cussing the lineage of some engineer, but im convinced this is extra difficult on purpose. Vent tube corner should have come off, and everything would be hunky dorry. I could even replace the foam seals.
    was it sunnier that had pics of the innards of the dash, and perhaps expierience behind the scenes?
    i can get it out by force, just worried about getting it back in.
    Sunnier likes this.
  13. Jan 6, 2023 at 10:10 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    No rush. Better safe than sorry.
    the orange duct is in the way of the relay coming off the blue stud. Pic actually looks like alot more room than it feels. I'm not ready to throw the retard strength at it yet. The bottom is loose, but theres a brace in the way, and the top of the duct isnt releasing. I've cobbled a windshield wiper spring into a hook, i'll see if i can unlatch any lip that might be up top.
    The bottom is all open. Gotta get creative with a 10mm hex drive (with the magnet removed for depth), hex drive extension, and long reach hex drive screwdriver to reach around the duct.
  14. Jan 6, 2023 at 10:46 AM
    daveeasa
    Yeah, I needed both my extensions. The 1/4 drive extensions are skinny so there was enough play with the vent to mash it to the side. Did that twice. It's not a significant problem and once you break tension you can remove the extension and grab the socket then turn it by hand with your fingers. Just need to crack it to get it off (and smack it tight to get it on).
    Very short term bendage to the vent.
    You want photos of my socket set? 3/8 would be too much meat, 1/4 is the way to go.
  15. Jan 6, 2023 at 10:48 AM
    daveeasa
    "The bottom is loose, but theres a brace in the way, and the top of the duct isnt releasing"
    ^^ Exactly, removing the screw holding the bottom to the trim gave me enough play. I never got the top to release. I think it's snapped in via clips at the back of the vent and you'd have to remove the entire dash to get to that safely with a flathead screwdriver. Break that stuff and it might rattle/sit loose and you'd be bummed or have to replace significant plastic.
    I deforms OK at the point where you need it to.
    I can't remember if I went in through the switch panel hole or from below though, if I took mine apart again I could remind myself but this aspect makes me want to say f that :)
  16. Jan 6, 2023 at 10:49 AM
    daveeasa
    Also, get that center vent coupler out of there, it 'll come out the other side easy, set it on the passenger seat for now, more room.
  17. Jan 6, 2023 at 10:54 AM
    daveeasa
    It's making me feel better that this is a problem for you too, I assumed I just suck at wrenching. But I was in a costco parking lot at the time and had only a few hours to get it done or I'd have to hotwire the headlights or camp out overnight.
    shifty` and Mr.bee like this.
  18. Jan 6, 2023 at 11:00 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    im comfy. Had to wear my dog out so hes napping instead of up my ass.
  19. Jan 6, 2023 at 11:02 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i'm jelly. I have no excuse. Some jackass made things jiggle resistant. But i've still got 3 days before my oil cooler hoses show up.
  20. Jan 6, 2023 at 11:10 AM
    daveeasa
    You don't need much play to get it on the nut. Just push and set the socket, crack it, remove, release. Then hand-spin.
    Mr.bee[QUOTED] likes this.
  21. Jan 6, 2023 at 12:34 PM
    Looks like you got everything ironed out, bro. Now go have a beer! :rofl:
  22. Jan 6, 2023 at 12:42 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Dat a thigh master I see there?
    Jack McCarthy and Mr.bee[QUOTED] like this.
  23. Jan 6, 2023 at 12:44 PM
    I actually have that exact same bucket for zip ties sitting next to it.
    CodyP[QUOTED] likes this.
  24. Jan 6, 2023 at 12:52 PM
  25. Jan 6, 2023 at 2:44 PM
    daveeasa
    Make sure you’re not pressed for time.
    bmf4069, txagg, Mr.bee and 2 others like this.
  26. Jan 7, 2023 at 5:21 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
  27. Jan 7, 2023 at 5:53 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Its a might D light. Pretty handy, and i can usually wedge it anywhere it needs to be. I got 2 of em like 5 years ago, and they're troopers.
  28. Jan 7, 2023 at 7:35 AM
    robabeatle[QUOTED] likes this.
  29. Jan 7, 2023 at 7:43 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    False
    Festerw and daveeasa like this.
  30. Jan 7, 2023 at 7:48 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    bmf4069, txagg, RUSTYNUTS and 3 others like this.
