LCA Skid plate: RCI or Rago ... or else?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 400Lionel, Jan 5, 2023.
  1. Jan 5, 2023 at 10:01 AM
    400Lionel
    400Lionel [OP] New Member
    Lionel
    2019 Platinum - White
    currently stock
    Hello,
    In order to protect my beloved Tundra, I would like to fit Skid plates to protect also the LCA.
    As weight is the enemy and I am not doing crazy things, I opt for Aluminum ones.
    But I can't decide between RCI and Rago
    Which ones would you recommend or avoid and why?
    Maybe there are other brands offering well designed LCA Skid plates?
    Thanks in advance,
    Lionel
  2. Jan 5, 2023 at 10:27 AM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
  3. Jan 5, 2023 at 11:28 AM
    AZBoatHauler
    So.Arizona
    I’ve never understood LCA and rear diff skids.
    Sierradevil likes this.
  4. Jan 5, 2023 at 12:39 PM
    SAGE63
    San Diego County
    I got the RCI LCA skids to protect the alignment bolts and tabs after taking a hit there.
    joonbug likes this.
  5. Jan 5, 2023 at 12:44 PM
    king.cong.1119
    king.cong.1119 New Member
    i'd say if you put your tundra on rocks a lot, rear diff skid is a must, our tundras rear diff is so huge that it drags on every rock I drive over lol
    Wallygator likes this.
  6. Jan 5, 2023 at 1:01 PM
    400Lionel
    Lionel
    currently stock
    Thanks for the tips, also considering the rear shock guards are they are way lower and fragile than the rear diff
  7. Jan 5, 2023 at 1:01 PM
    HD59019
    HD59019 New Member
    Robert
    2017 Tundra SR5
    Very pleased with my Aluminum RCI front skid plate. I cannot recommend them enough. I had one on my FJ as well.
    I cannot speak to Ragu.
    Wallygator and RustyShackle323 like this.
  8. Jan 5, 2023 at 1:23 PM
    AZBoatHauler
    So.Arizona
    Kind of my point though - an inch less ground clearance sounds awful and I’d think could get you hung where you’d otherwise scrape by.
  9. Jan 5, 2023 at 1:28 PM
    400Lionel
    Lionel
    currently stock
    yes I ordered the RCI front, transfer case and fuel tank skid plates as well. Same goes for the RCI rock sliders to replace the running boards
    Wallygator and AZBoatHauler like this.
  10. Jan 5, 2023 at 1:35 PM
    AZBoatHauler
    So.Arizona
    I have the same setup but WKOR sliders instead - love all of them and I’ve put a good beating on them.
  11. Jan 5, 2023 at 3:02 PM
    king.cong.1119
    It won’t really hang but more of a glide, I’d probably trade damaged skids over damaged rear diff, as I have almost scraped off the entire drain port from my first hit in the rear diff lol
  12. Jan 5, 2023 at 3:07 PM
    AZBoatHauler
    So.Arizona
    I stopped counting after the third or fourth contact.
    :anonymous:
    EA3B0A2A-58A4-4EBC-9FCC-81962BB1F3F0.jpg 334F3630-C72C-4091-BBD4-877D8B141266.jpg
  13. Jan 5, 2023 at 3:32 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    The smaller diff bolts would get shredded without the skid. Would be a bitch replacing those bolts. The skid also protects the rear of the pumpkin from getting smashed in as well - if you were to back into rock or slide off of a rock.
    Wallygator, reywcms and joonbug like this.
  14. Jan 5, 2023 at 4:14 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No to the arm skids. Diff skid eh I would rather have the diff clearance. Unless you wheel like @Cruzer.
    AZBoatHauler likes this.
  15. Jan 5, 2023 at 4:17 PM
    SAGE63
    San Diego County
    well lets just say Smiley Rock with @Cruzer and others will change your mind... 3 trucks on 40s a couple lifted 35s and my 295s... It was fun and harrowing at times
    reywcms[QUOTED] likes this.
  16. Jan 5, 2023 at 4:51 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    LCA’s don’t need any protection. They’re just about indestructible. Lol. But if you’re on rocks enough, those skids really do help protect the LCA mounts.
    Mine were smashed bad enough I couldn’t get an alignment.
    Another one bent enough it was interfering with the LCA movement.
    Was barely able to get them straightened out enough to weld on gusseted cam tabs. EDFA36CE-6DE4-4FDC-B924-E94557B5FFD6.jpg
    Wallygator, reywcms and AZBoatHauler like this.
  17. Jan 6, 2023 at 11:13 AM
    400Lionel
    Lionel
    currently stock
    I had some doubts about the rear diff skid plate but from the pictures sent it seems to be quite needed, especially when factoring the time and price required to get some Tundra spare parts in Europe. Same goes for the LCA and rear shock skid plates.
    Thanks guys for your help :)
    SAGE63 and AZBoatHauler like this.
