  1. Jan 5, 2023 at 11:10 AM
    Since these keys don't have chips I've heard the dealerships don't charge a lot. I'll probably go by there.
    CodyP[QUOTED] likes this.
  2. Jan 5, 2023 at 11:13 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I think the dealer here charged me like $12.
  3. Jan 5, 2023 at 11:49 AM
    I wouldn't worry about that. The locksmith can always come out to your truck and test it or you can do it yourself while you're there. I think the only thing you lose is that plastic head to the key by hitting up a locksmith.
  4. Jan 5, 2023 at 12:25 PM
    It depends on who you ask, everyone has their perspective. From my perspective, it depends on how the key is cut.
    Theoretically, the little barrels (keyway pins) inside the lock cylinder - the things the notches on your key engages - are different lengths. There's only a few sizes possible, but I don't remember if the steps are, like, half millimeter steps between pins, full millimeter steps, fractional, or what.
    Anyway ... say your key steps from a 1 pin, to a 2 pin, then 5, 4, 1, 2. If the person cutting your key is cutting based on the step sizes, you'll get a fresh, crisp key like what came cut from the factory. If you're using one of those shitty key cutter machines at your local hardware that just traces across your existing key, using it as a guide for the grinder on the other side to cuts an exact replica into a generic key blank, you're going to get a duplicate with X# years wear on it right off the bat.
    Bonus perk to the dealership - and I have yet to see anyone saying they got charged more than $20 for blank and cutting - is you get an OEM key blank to go with it.
    Basically, those pins being standardized lengths is how a locksmith can come to your house and rekey every lock barrel at your house to the exact same key. They just check the barrel length and order on the key or lock cylinder, and replace the pins with correct length/order to make them all the same. You can buy keyway pin assortments to do it yourself if you're brave enough (I'm not)
  5. Jan 5, 2023 at 2:06 PM
    Dealer cut for the win
    alb1k and shifty`[QUOTED] like this.
  6. Jan 5, 2023 at 2:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    Our Lowes used to have a couple of old dudes that knew everything about locksmithing, plumbing and electrical. The used to cut keys for free if you had the blank. They would also rekey cylinders for nothing. The manual key machine got replaced with a kiosk that takes credit cards and the old dudes got replaced with diverse females that don’t know anything about hardware. Unfortunately they already put the mom and pop stores out of business. Ugh.
    txagg, FirstGenVol and Mr.bee like this.
  7. Jan 5, 2023 at 4:53 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    MEK is some nasty shit! An organic vapor respirator is a must.
    "Breathing Methyl Ethyl Ketone can irritate the nose and throat causing coughing and wheezing. Exposure can cause dizziness, lightheadedness, headache, nausea, blurred vision, and may cause you to pass out. Repeated high exposure can damage the nervous system and may affect the brain."
    Oh, and it will kill you too.
    CodyP, daveeasa and shifty`[QUOTED] like this.
  8. Jan 5, 2023 at 5:00 PM
    Yup. Not as bad as inhaling paint w/isocyanates, like Spray2k Max. But pretty gnarly stuff.
  9. Jan 5, 2023 at 5:36 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    @shity' - where is your normal disclaimer? MEK is 95+ respirator all day.
  10. Jan 5, 2023 at 5:37 PM
    alb1k
    Left Coast
    It's good
    I was late here. But the kids are doing well....
    Sunnier and des2mtn like this.
  11. Jan 5, 2023 at 5:59 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    @empty_lord was thinking of a Tundra convertible build. All the rage in the late '80's.
  12. Jan 5, 2023 at 6:03 PM
    Not sure what you mean, boss. I like to put a little bit of it in a paper bag and hyperventilate until things get colorful. :cookiemonster::cookiemonster::cookiemonster::cookiemonster::cookiemonster::cookiemonster:
    bmf4069 and CodyP like this.
  13. Jan 5, 2023 at 6:08 PM
    alb1k
    Left Coast
    It's good
    Crazy, I do the same thing, I was just looking for my MEK whip-it.
  14. Jan 5, 2023 at 6:22 PM
    NUDRAT
    SW CT
    The only thing you are ignoring is that the lock cylinder is old & worn down too.
    If you have multiple Tundri like @Tundra2 old worn lock cylinders & keys can sometimes mean 1 key works both trucks. :) BTDT
    bmf4069, txagg and shifty` like this.
  15. Jan 5, 2023 at 6:28 PM
    This reminds me.
    Neighbor near me has an issue with his 1GT. When the truck is running and the key is in the ON position, you can pull it out. When he does, the cylinder gets locked and won't turn forward, backward or anything until he gets a key from another Tundra with a different key pattern, insert it and pull it out again, and suddenly it starts working again.
    I told him he may just need to spray some dry lube in there and work a key in and out to lube the tumblers, but ... I was just surprised he could even pull the key out while in any position other than OFF. Later model DC, maybe '04-'06? Never did hear back whether spray lube worked. I told him to order a blank to keep in the glovebox in case it happens again, gave him the part number.
    NUDRAT[QUOTED][OP] likes this.
  16. Jan 5, 2023 at 6:29 PM
    daveeasa
    I owe a bumper photo. But I got sidetracked by tree removal. Now I have parking spaces for my trifecta of pickup trucks. I can die happy.
    bmf4069, Sunnier, txagg and 4 others like this.
  17. Jan 5, 2023 at 10:29 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yeah man! Trees are overrated. Especially the pine variety! :mad:
    NUDRAT[OP] likes this.
  18. Jan 6, 2023 at 4:05 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Currently sitting here with our oldest (7yr old) who may have appendicitis :(. Hoping her symptoms settle because I really don’t wanna take her to the ER. Also, I’m getting very hungry!
    All you sleeping saps make me jealous.
    Ok I’m done.
  19. Jan 6, 2023 at 4:35 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Get her some beet juice. It might not help, but when grandma would make me drink home remedies like that, it made me 2nd guess complaining about ailments. Hope she's ok.
    polo go me up at 2 so he could run around and chase deer. I've been dozing off between laundry loads, trying to decide if i'm gonna tackle the integration relay today.
    daveeasa, CodyP and FrenchToasty like this.
  20. Jan 6, 2023 at 4:52 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    How long has she had symptoms? Is she super miserable, and has it been pretty constant? Keep us updated
  21. Jan 6, 2023 at 5:04 AM
    My dad had an 84 toyota pickup back in the day that would do the same thing.
    shifty`[QUOTED] likes this.
  22. Jan 6, 2023 at 5:21 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Haha I like it.
    She’s typically not one to complain. Fever yesterday and didn’t eat anything after 2pm. Then at 3am this morning she woke us up crying that her stomach hurt. Vomited basically nothing but then still complained about lower right abd pain. Still has a fever. Just now getting settle but the pain isn’t worse which is good. Gonna take her into the office when it opens to check her white count and go from there.
  23. Jan 6, 2023 at 5:22 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Oof hope she's feeling better soon.
    I went in for that a few years ago fortunately they were able to load me up with antibiotics and it avoided me having to have surgery.
  24. Jan 6, 2023 at 5:24 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Really? I always thought that if it was swollen and an issue they just laparoscopically take er out.
    txagg likes this.
  25. Jan 6, 2023 at 5:50 AM
    daveeasa
    Yeah I’d have that extra part removed myself.
    shifty` and CodyP like this.
  26. Jan 6, 2023 at 5:51 AM
    daveeasa
    Honestly it shouldn’t take more than 90 minutes with a decent set of 1/4” sockets.
    bmf4069 and Mr.bee[QUOTED] like this.
  27. Jan 6, 2023 at 6:01 AM
    Were the only country that does that. Most other countries just give you Rocephin and let it encapsulate itself. Surgery pays better though.
  28. Jan 6, 2023 at 6:03 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    All about those bennys
  29. Jan 6, 2023 at 6:47 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Recentish deal. Something like 70% respond to antibiotics and 50% are still good after 4 years.
    CodyP[QUOTED] and KNABORES like this.
  30. Jan 6, 2023 at 6:54 AM
    That's the one thing I don't miss much from FL. I had to park under one, and went through hand sanitizer like it was beef jerky (easy sap removal).
    Good papa. You know the symptoms, that sounds like a dead ringer, but you never know. Lower right, appendix, lower left, usually constipation. Better safe than sorry.
    Keep us posted. Nobody wants their little one to go under knife. We had our fair share of major procedures with both kids before age 8. It's no fun!
    One of my team members from Brazil, I flew him up here in 2018 to help with an office reloc. Flew in, got to the hotel, "stomach ache", he thought the plane food got him. Got HR on the horn to figure out how benefits/medical would work for him as a BR citizen. He went to a walk-in clinic, took some films, told him "ah, it's indigestion" and they sent him back with laxatives. He was miserable the next 3 days, flew home.
    Next day he doesn't show up for work. No clue where he is. Ended up calling over the weekend, "Surgery went well, but I'll be out for the next 2 weeks... landed in Sao Paulo, went straight to the ER, 25 minutes later I was being rushed to the OR. Appendix burst!"
    Great example of how dicked up our healthcare system is. Overpaying for underservice.
