2012 Camshaft Position Sensor Wiring Question
Discussion in 'Electrical' started by TexasTundraOwner, Jan 2, 2023.
  1. Jan 2, 2023 at 2:31 PM
    TexasTundraOwner
    TexasTundraOwner [OP] New Member
    I pulled the wires from my camshaft position sensor A bank 2 sensor by accident recently. The wires are red yellow and blue. I’ve bought an aftermarket connector with all black pigtails and have looked at the EWD for the 2012 tundra but do not see any camshaft position sensors with a blue wire. They all seem to be red, black, and yellow. Does anyone know which wire goes in which pin on the connector? Thanks
  2. Jan 3, 2023 at 1:57 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Sometimes the wire colors vary depending on year and which engine you have. What is your truck exactly?
  3. Jan 5, 2023 at 5:00 PM
    TexasTundraOwner
    I have the 2012 Tundra 4.6 L V8. After looking everywhere for a wiring diagram and finding one for the 2012 engine I have but which didn’t show any cam shaft sensors with a red, blue, yellow wire config, I went with the way the wires were left after being pulled out of the connector. That turned out to be correct as my check engine light is now off. Thanks for the reply!
    Jeff_5_7 likes this.
  4. Jan 13, 2023 at 2:33 PM
    1JZ
    1JZ There are no facts, only interpretations-Nietzsche
    2016 Tundra XP
    SRT-1 likes this.
