2018 Sequoia LED Headlight Harness For 2nd Gen Tundras
Discussion in 'Deals & Group Buys' started by xrunnerdude67, Nov 25, 2017.
Thread Status:
Not open for further replies.
  1. Jul 3, 2022 at 3:51 PM
    #871
    Toyota_Sequoia
    Toyota_Sequoia New Member
    Hey! I went through the forum. Does not list parts for the fog lights assembly and the bezel. Let me know if you have those part #'s. Looking for platinum ones.
    Thanks
  2. Jul 3, 2022 at 9:21 PM
    #872
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What fog light assembly are you meaning? I didn't realize you were asking about them, I was just referring to the 18+ Sequoia LED headlamps and the fill panels that fit below them.
  3. Jul 4, 2022 at 6:43 AM
    #873
    nags
    nags New Member
    I looked everywhere and the best price I found was Sparks with the Tundras.com coupon code.
    Toyota_Sequoia and Wynnded like this.
  4. Jul 4, 2022 at 7:28 AM
    #874
    Toyota_Sequoia
    The Fog lamps assembly and Bezel for the fogs lol. I got a harness for the fogs as well. Just wanted to confirm the parts #'s. The ones i found are
    Platinum
    Left Assembly - 81220-0C030
    Left Bezel - 52040-0C020
    Right Assembly - 81210-0C030
    Bezel - 52030-0C020
    Just wanted to confirm them.
  5. Jul 4, 2022 at 7:31 AM
    #875
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Oh, I'm sorry. Someone else will need to verify that. I simply swapped out my stock fog lights for some aftermarket LED ones. Morimoto if memory serves.
  6. Jul 4, 2022 at 8:28 AM
    #876
    Toyota_Sequoia
    Hey No worries. BTW, do you have pictures for install. I am having a hard time finding the location for de-pining the grey and putting the harness grey wire. The instruction pics aren't very clear?
    This is what i understood from the info provided:
    1. The "add a circuit" will take both the fuse (The IGN and the new one that is provided) and will be installed in the IGN slot?
    2. The location of the grey wire seems on the bottom left side of the white connector. So we pull on the plastic tab on the left of the white connector, pull the connector down, turn 180, so the plastic pull tab comes on the right side and then determine the location?
    3. Location: Now its should be the third row from the bottom and 1st column from the right?
    4. For de-pin: where exactly (which hole) do we insert the paper clip to release the existing wire and put a new one in.
    Thanks
  7. Jul 4, 2022 at 9:40 AM
    #877
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sorry, I don't have any pictures of this. :oops:
  8. Jul 5, 2022 at 9:15 PM
    #878
    Toyota_Sequoia
    Does anyone has any info or pictures regarding de-pining and re-pining the harness grey wire location?
  9. Jul 6, 2022 at 7:21 AM
    #879
    Toyota_Sequoia
    Hey Guys,
    Was placing an order for the headlights, can anyone pls confirm the model numbers for headlights and bottom panels.?
    81150-0C150 Composite Assembly
    81110-0C190 Composite Assembly
    53932-0C904 Extension Panel
    53931-0C904 Extension Panel
    Thanks
  10. Jul 23, 2022 at 11:18 AM
    #880
    El_Chingon_Sequoia
    El_Chingon_Sequoia New Member
    2010 Sequoia
    Stock as a rock
    This will be for the Non-platinum headlights. The difference is the corner being black vs chrome in the corner of the light as seen in the one pic of the headlight.
  11. Jul 23, 2022 at 12:57 PM
    #881
    Toyota_Sequoia
    Hey!
    Thanks for sharing. I already bought the stuff. Just figuring out the install. Please do share wiring pics. Especially the location of the where the grey wire goes and the rest of the wiring. Someone should do an Install video.
  12. Jul 23, 2022 at 1:03 PM
    #882
    El_Chingon_Sequoia
    2010 Sequoia
    Stock as a rock
    Cool, I'm sure this will help people in the future as well. My harness is on order, once I get it in a few weeks I will try to do a video. It's tough right now since I live in AZ and it's hotter than Satan's ass crack and I'm not naturally a morning person, which 4am-7am is the only bearable time to be in the garage right now.
  13. Jul 24, 2022 at 6:34 AM
    #883
    Toyota_Sequoia
    Definitely a good idea. Lot of folks here aren’t very auto savvy. It’s been hot here since last month but no where near as hot as AZ.
  14. Sep 1, 2022 at 6:21 PM
    #884
    Toyota_Sequoia
    Hey guys,
    installed my lights today. I choose option 1 with white outer Lights running as DRL so I need to re pin the grey wire under the steering wheel. Where? The 2 bolts I found were 8mm and the OBD sensor was hanging off those bolts. It’s right behind the SRS airbag. Didn’t seems right. Can someone please guide as to where those bolts are under the steering wheel?? Or share some pictures?
    Thanks
  15. Sep 5, 2022 at 12:47 PM
    #885
    El_Chingon_Sequoia
    2010 Sequoia
    Stock as a rock
    There's one in the bottom corner toward the center console. There's another behind the kick panel trim piece. Just pry it out a little bit and use a socket to remove it
  16. Oct 4, 2022 at 8:55 PM
    #886
    Showtz
    Showtz New Member
    Under the drivers side dash It's the gray wire that was between the white with black stripe and the green
  17. Oct 4, 2022 at 9:08 PM
    #887
    El_Chingon_Sequoia
    2010 Sequoia
    Stock as a rock
  18. Oct 5, 2022 at 1:39 AM
    #888
    Toyota_Sequoia
    Thanks for sharing. I didnt get a chance to hook it up yet. Rest is done though. Just was having a hard time finding the location of the 2 bolts. With the back pain I just wanted to make sure before opening it all up.
    Cheers!
  19. Oct 5, 2022 at 1:46 AM
    #889
    Toyota_Sequoia
    That’s a slick upgrade. Seems like a lot of guys are going full out. I still have to hook up the grey wire and your pics will def help. Thanks to Mike for coming up with the harness. Made headlights upgrade a breeze. I wish they had options for rear taillights. Thanks for sharing though!
  20. Oct 5, 2022 at 2:34 AM
    #890
    Toyota_Sequoia
    BTW has anyone looked into XPEL film for the headlights ? Or a similar DIY?
  21. Oct 14, 2022 at 3:06 PM
    #891
    chuckdizzle
    chuckdizzle New Member
    chuckd
    2008 sequoia platinum
    black mirrors and handles, platidip the emblems
    hi, i have a 2008 sequoia platinum with the new 2018 LED lights, the way i have them hooked up the inner amber DRL is on with the white surround DRLS.
    i want to confirm cutting the gray wire as described above disconnects just the inner AMBER DRL?
    when the grey wire is cut does that inner amber DRL then shine white like the surround (2018 factory look)
    OR does it turn the inner drl off completely?
    thanks
  22. Oct 16, 2022 at 12:13 PM
    #892
    chuckdizzle
    chuckd
    so what wire needs to be cut or de pinned? and what is the location of the wire? thanks
  23. Jan 1, 2023 at 9:30 AM
    #893
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
  24. Jan 5, 2023 at 7:12 AM
    #894
    chuckdizzle
    chuckd
    Hello, xrunnerdude, i didnt get a PM regarding the wiring, can you please resend? thanks
  25. Jan 5, 2023 at 3:42 PM
    #895
    ZenkiS14
    ZenkiS14 New Member
    2012 Tundra TRD Rock Warrior
  26. Jan 5, 2023 at 4:00 PM
    #896
    BrandonL812
    Brandon
    Anyone know if the OP is on vacation?
  27. Jan 5, 2023 at 4:39 PM
    #897
    ZenkiS14
    ZenkiS14 New Member
    I know he is hit or miss sometimes on logging on here, but my harness came in days after ordered, and I dont think he's ever left anyone hanging after 3 years now.
  28. Jan 5, 2023 at 4:41 PM
    #898
    BrandonL812
    Brandon
    right. But i would think the forum would send an notification to his email notifying him of messages and post. Unless he doesn’t check his email often?
  29. Jan 27, 2023 at 9:54 AM
    #899
    BrandonL812
    Brandon
    He is. He is slow on responding but will eventually. The payment info is on the first page. You send him paypal ad family and friends. He makes it. He is about 3wks out on the harness. That’s the last reply I had with him. So do expect 3-4wks wait once you pay.
  30. Jan 30, 2023 at 7:50 AM
    #900
    chuckdizzle
    chuckd
    Hi, he is always helpful and very knowledgeable on the lights...
    Here is my conversion, What does everyone prefer the all white DRL, or the Amber in the middle DRL?
    I cant decide..
    Schmidt_l likes this.
Thread Status:
