Radar Detector - MirrorTap and BlendMount on Digital Rearview Mirror Instructions
Discussion in '3rd Gen Tundras (2022+)' started by G19OD, Jan 4, 2023.
  1. Jan 4, 2023 at 12:44 PM
    G19OD
    G19OD [OP] Mall Crawler
    Pacific Northwest
    For those of you that run a radar detector and want to have a sleek look, I just successfully tapped the digital rearview mirror on my 2022 TRD Pro with the MirrorTap MTX series from BlendMount. I wasn't able to find any posts anywhere about someone figuring out the digital rearview mirror tap, so figured I would post here in case anyone else was looking for instructions.
    I slid the cover off the mirror/windshield, which exposed two sets of molex plugs that run to the digital rearview mirror. The one we are interested in is the one on the right side. I got out my voltmeter and found the ground tap from the continuity setting and then found the switched power from the DC setting. It was putting out between 14 - 15 volts when the vehicle was on and 0 when off (i.e. switched power). Then just completed by inserting the power (red) tap to the light blue lead and the ground (black) tap to the white lead. Hooked up the V1G2, put the cover back on, and good to go.
    Pics here:
    Bulldog6, CappyKD, Bryantbjb and 13 others like this.
  2. Jan 4, 2023 at 1:32 PM
    jazzyj
    jazzyj New Member
    NE Arkansas
    2023 WCP Platinum Hybrid
    Very Nice
    G19OD[OP] likes this.
  3. Jan 4, 2023 at 10:10 PM
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    What model blend mount did you get?
  4. Jan 5, 2023 at 6:49 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Thank you
  5. Jan 5, 2023 at 11:30 AM
    G19OD
    Pacific Northwest
    I got the BV1-2001R, which is on Amazon for $99. Also got the MTX series taps from BlendMount on Amazon.
  6. Jan 5, 2023 at 11:34 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Looks nice..
    I didn't realize radar detectors were still a 'thing'.:confused::cool:
    Gray Hawk, gj953, ArticTundra and 5 others like this.
  7. Jan 5, 2023 at 3:12 PM
    DaxM
    DaxM New Member
    Temple, TX
    2023 Wind Chill Pearl Capstone
    Nice install! Looking to do this for my Capstone soon. Curious, did you get the 10" MTX wire or the 15"? Looks like a 10" from the pics. Thanks!
    Dax
  8. Jan 5, 2023 at 3:38 PM
    G19OD
    Pacific Northwest
    I went with the 15" since I didn't know what I was going to be working with until I opened up the cover and tried to figure it all out. I think you could get by with a 10" for sure, I had to stuff a fair amount of the wire back up into the cover/housing (plenty of space in there).
  9. Jan 6, 2023 at 11:39 AM
    Yelzelity
    Yelzelity New Member
    Would you please post a pic of the back side of the mirror where the mount attaches to the mirror stem. I tried to attach a blend mount but was worried about pinching wires.
  10. Jan 8, 2023 at 7:28 AM
    G19OD
    Pacific Northwest
    Just don't severely overtighten. I probably did, but no issues yet! You could always wrap it in electrical tape or some other semi-protector prior to installing I suppose.
  11. Jan 8, 2023 at 11:45 AM
    SecrITSociety
    SecrITSociety New Member
    Orlando, FL
    2023 Platinum Tundra / Blueprint / 4x4
    You can remove the clip at the top of the mirror that just holds the cables to the stem, then squeeze the mount behind the cables and secure it.
    I haven't finished running wires yet, but the clip might be a bit difficult to get back on as they are pulled away from the stem a bit, I'll likely go with a small zip tie anyway as two additional cables will be going along the same path...
    btbeeper, Welderdude80 and G19OD[OP] like this.
  12. Jan 8, 2023 at 11:49 AM
    G19OD
    Pacific Northwest
    Definitely the safer way, nicely done.
  13. Jan 9, 2023 at 1:50 AM
    Yelzelity
    Thank you for the pics
  14. Jan 19, 2023 at 8:56 AM
    John_in_NC
    John_in_NC New Member
    North Carolina
    2022 Black Toyota Platinum
    Side Steps
    Nice, glad someone figured this out. When I looked on the Blendmount site they showed that 'arm' as one they did not support (yet?).
  15. Jan 19, 2023 at 5:47 PM
    Fxclm5
    Fxclm5 New Member
  16. Jan 19, 2023 at 6:35 PM
    kkajvr6
    kkajvr6 New Member
    NE Alabama
    Well not sure what happened, but I installed my mirror tap for my Valentine 1 as described and now my dash is lite up like a Christmas tree. It is showing a CEL for the SRS Air Bag, Forward Collision Prevention system, and my fancy TV screen mirror is dead.
  17. Jan 19, 2023 at 7:02 PM
    G19OD
    Pacific Northwest
    Can you post pictures of where you wire tapped? Did you do it while the truck was on?
  18. Jan 19, 2023 at 7:23 PM
    kkajvr6
    kkajvr6 New Member
    NE Alabama
    I used your example, truck was off. I blew the SRS air bag 10A fuse. I replaced it with the spare from the fuse box by the battery. All CELs are gone and mirror works again. I’ll break out the multi meter tomorrow and do some investigation.
  19. Mar 3, 2023 at 4:41 AM
    chelseafan
    chelseafan New Member
    I was able to tap the mirror on my Pro. Works great except the whole radar moves with the movement of the mirror. I wonder if there is any way to keep radar pointing straight while adjusting the mirror. The radar seems to be "looking" in the same direction as the back of the mirror. Thanks
  20. May 23, 2023 at 12:35 PM
    jlamberth
    jlamberth New Member
    Works perfectly using an Escort detector and their patch.
  21. Nov 19, 2023 at 10:55 AM
    seth.yes
    seth.yes New Member
    Seth
    2022 Tundra Capstone
    Thanks for posting this! I used this info and the same hardware to install my radar detector last July.
    I wanted to add a dashcam using the same tap method, however the radar detector MirrorTap and the dashcam mirror-tap proved to be too much hardware to fit in the power/ground of the harness. I then stripped part of the radar detector MirrorTap to expose power/ground coming from the harness and tapped into that with my dashcam leads. End result looks pretty clean, I'll update this thread if I end up blowing a fuse for the rear view mirror :)
  22. Jan 29, 2024 at 5:49 PM
    ShutterFlare
    ShutterFlare New Member
    2024 Tundra 1794
    Followed the above pictures for the mirror tap, worked like a charm. I decided to go a different route on the radar mount, though. I found this mount on Etsy. It works great! It’s more discreet since the radar detector is in the very top of the windshield. However, I cannot open my sun visor all the way. I also had to add a strip of electrical tape on the mount because the metal is just a little thinner than the radar detector opening. This caused some shaking and rattling as I drove. Wrapping electrical tape once around the back half of the mount solved the issue though.
  23. Apr 24, 2024 at 11:25 PM
    tquadeer
    tquadeer New Member
    how did you remove the panel to get to the wiring harness? is it just a clip that I pull downwards, or right ?
  24. Apr 25, 2024 at 3:44 AM
    ShutterFlare
    2024 Tundra 1794
    It’s mostly a downward motion along the plane of the glass. There are clips on both sides holding it together. Mine was very tight on one side, and when it unclips, it does so very quickly. I opened the cover twice and cut my finger twice.
  25. Apr 25, 2024 at 9:09 AM
    lapoolboy
    lapoolboy New Member
  26. Apr 29, 2024 at 1:44 PM
    V6Raider
    V6Raider New Member
    2022 Tundra DC SR5
    details on the mount please?
  27. Aug 20, 2024 at 6:44 AM
    chinolatte_420
    chinolatte_420 New Member
    Does anyone have tips for tapping in the mirrortaps? I've had my mirrortap for several cars, but on the Tundra I can't seem to insert even the smallest pins. One of them actually broke off.
  28. Oct 26, 2024 at 4:35 PM
    rotech707
    rotech707 New Member
    This was super helpful. I applied this to my 23 Sequoia Limited that has the Power Mirror and Rear Camera option. The cable is a different color but it the same type. Make sure to get a long cable because there is enough slack to tuck it inside the cover plate.
  29. Nov 12, 2024 at 10:49 AM
    Tolley
    Tolley New Member
    Have you noticed any alert degradation mounting directly behind the windshield frit? That would be where I mount mine as well.
  30. Dec 22, 2024 at 2:52 PM
    Tolley
    Tolley New Member
    Does anyone know what the part number is for the mirror cover? I ended up snapping a clip when I removed it.
