Master cylinder screen
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Ajkkane, Feb 17, 2019.
mastercylinder screen removal
  1. Any
    0 vote(s)
    0.0%
  2. Any
    0 vote(s)
    0.0%
  1. Feb 17, 2019 at 7:29 AM
    Ajkkane
    Ajkkane [OP] Old fart.
    Nj
    2014 CM SR5
    Exhaust Dirty Deeds 8”SS, some led lights, Osram headlights, Pro Stop brakes, Pop Lock, AFE dry air filter with charcoal delete.
    On a 2014 tundra has anybody removed the fine screen inside the master cylinder reservoir? It appears as though it will not pull out by hand or by gently pulling on it with needle nose pliers. Has anybody remove the screen from the master cylinder? Better to ask and find out then not to ask and break it.
  2. Feb 17, 2019 at 7:55 AM
    15whtrd
    15whtrd Mr. Blonde
    Interested. Thought the same thing myself. I like to use a turkey baster to suck out the fluid before I bleed the brakes. Just figured I would have to deal with it when the time came.
    1Tundra5 likes this.
  3. Sep 14, 2019 at 11:48 AM
    Jds685
    Jds685 2nd Tundra
    CT
    2024 Tundra i-Force Max 1794
    Update?
  4. Sep 14, 2019 at 4:23 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I had to remove the screen from the MC on my camry and in order for it to come out it had to be turned counter clockwise some then it lifted straight out.
    15whtrd likes this.
  5. Sep 14, 2019 at 4:27 PM
    15whtrd
    15whtrd Mr. Blonde
    Good to know! I was fiddling with it one day but didn’t want to snap it. Before I ever do a brake bleed I like to put some fresh stuff in the master cylinder so I don’t have to bleed that crap all the way through the system.
    coldcanuk likes this.
  6. Sep 14, 2019 at 5:16 PM
    Jds685
    Jds685 2nd Tundra
    CT
    Same. I played with that thing for 15 minutes. Spinning the mesh filter around and around. I cant find any way of removing it. Granted I didn't use blunt force, but I tried lightly prying with a screwdriver, a needle nose pliers, and just trying to finesse it out by hand. I'm not a pro by any means, but I've been working on cars for 15 years. This has me stumped! Lol. Freaking mesh screen.
    coldcanuk and 15whtrd like this.
  7. Sep 14, 2019 at 7:18 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Same reason I was taking the screen out of the Camry’s MC. ;)
    15whtrd[QUOTED] likes this.
  8. Apr 13, 2020 at 6:58 PM
    Juanpablo
    Juanpablo New Member
    JUan
    2000 sr5 8 cyl.
    It is not that difficult. I did it using these pick n hooks.[​IMG]You have to pry from the outer side of the filter and push in a bit toward the center, not down, so that it clears the groove where it sits under then pull up slowly. Just be careful not to damage the mesh with the pick.
    Dr.K likes this.
  9. Jan 3, 2023 at 1:33 PM
    Dr.K
    Dr.K New Member
    I just did what Juan suggested. I used 2 pick tools from opposite sides (after wedging in the tip of the tools between the outside rim of the screen cap and the reservoir) and gently pushed towards the middle and it popped out pretty easy. When you put it back in, keep pressing down until you hear some audible clicks.
    FYI, my dealership quoted $165 for the break fluid flush.
