  1. Dec 31, 2022 at 7:31 AM
    #9991
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    I've started a new criteria for buying items, I don't by an appliance from a cell phone manufacturer and I don't by a cell phone from an appliance manufacturer.
    We had a NICE LG Fridge but the compressor kept failing, had it replaced once and the warranty ended and that was it. Sporting a Frigidaire now.
  2. Jan 1, 2023 at 2:03 PM
    #9992
    hBaz
    hBaz New Member
    middle of nowhere south of OK City
    2021 black 1794 Edition with TRD package
    Floor tiling over the moved toilet drain. I suck at precise work like this. Wife says no toe catchers is good enough.
    TaquitoBandito and Fotnot like this.
  3. Jan 1, 2023 at 2:10 PM
    #9993
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  4. Jan 1, 2023 at 3:52 PM
    #9994
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    I have similar cabinet doors. Going to sandblast prime and repaint. First time didnt know what I was doing (almost 20 years ago) lots of paint chipping away. Any suggestions or types of primer paint, maybe clear coat/hardener?
    Did put in led under cabinet lighting kit. $20 works nicely
  5. Jan 1, 2023 at 3:54 PM
    #9995
    ACDC2ZZTop
    Travis
    Oregon
    Further work done on rolling workbench. Must have measured right, it fits under main workbench lol.
    Fitted the tools in. Setting up vacuum ports next.
  6. Jan 1, 2023 at 5:01 PM
    #9996
    hBaz
    hBaz New Member
    Yea, probably better than my mark 1 eyeball, 4 ft level and 2 ft square ... ah well, it's done ... another entry in my list of not perfect but good enough ;)
    RainMan_PNW and TaquitoBandito like this.
  7. Jan 1, 2023 at 5:02 PM
    #9997
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Nice! Dig the LEDs. Our company uses a lacquer based primer and finish coat. We only clear coat if we’re staining. It’s sprayed with a lacquer sprayer, but can be sprayed with a cup gun. My cabinets I did myself, but stayed relatively inexpensive because I’m a renter. I used Behr Ultra paint, and went with Swiss Coffee to match the doors, trim, and ceiling.
  8. Jan 1, 2023 at 5:06 PM
    #9998
    Woke up to no power on furnace
    Troubleshot all I could and gave up.
    Phoned an HVAC friend / neighbor who came by.
    Found a wire came loose from a wirenut in the furnace and burnt several wires. Stripped wires, new wire nuts and added electrical tape
    Lesson being- use electrical tape after securing them. Wirenut is not good enough. House could have caught fire
  9. Jan 1, 2023 at 5:31 PM
    #9999
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
  10. Jan 1, 2023 at 5:38 PM
    Squatting Pigeon
    Holden
    North Texas
    Sometimes close is close enough!
  11. Jan 1, 2023 at 5:38 PM
    Squatting Pigeon
    Holden
    North Texas
    They’re badass. I’ve used them many times and they make things easy
  12. Jan 1, 2023 at 5:41 PM
    Tripleconpanna
    Definitely on my list for next tiling project!!! :hattip:
    Is there any equivalent for vertical projects?
    TaquitoBandito likes this.
  13. Jan 1, 2023 at 5:51 PM
    Squatting Pigeon
    Holden
    North Texas
    You can use them on walls too!
  14. Jan 1, 2023 at 6:00 PM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    ‘24 Platinum MGM
    Nothing major but we moved from a custom home with oversized 2.5 car garage to a home built in 1994 so needles to say we needed some storage. Built some shelves over the last few days (forgive the mess as I still need to clean and organize better).
  15. Jan 1, 2023 at 6:03 PM
    Tripleconpanna
    :bananadead:
  16. Jan 1, 2023 at 6:09 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Cleaned gutters and took down Christmas lights.
  17. Jan 1, 2023 at 6:23 PM
    TaquitoBandito
    Joel (AKA Bif)
    We have one and it's so quiet you don't know it's on (it has a red light it shines on the floor to let you know it's running). Things come out of it spotless.
  18. Jan 1, 2023 at 6:41 PM
    TaquitoBandito
    Joel (AKA Bif)
    Been seeing some mold pop up in our master bathroom. Really dusty in there too. I never could figure out the dust. The bathroom exhaust fan vents to an unfinished part of our attic (built in 1895). I found a steal on a bathroom fan at Lowes and thought about switching it out with the existing fan. I went up into the attic yesterday to see what size vent it had. Turns out it had no vent. Whomever installed it, basically cut a hole in the ceiling, attached the fan, and called it a day. The exhaust port was blowing into insulation.
    I'm going to replace the entire unit and run the exhaust hose to a vent I'm going to cut into the soffit. Tonight though, I put a hose on it and ran it out of the insulation - it's running better than ever.
    I also found a dead rat. Today was a good day. :)
  19. Jan 1, 2023 at 6:45 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Small lil changes. Had a full motion mount that we didn't really use anymore to its full effect. So flat on the wall with slight tilt. Also put slightly higher to be able to put picture frames on the mantle and all. (Outlet will be covered/hidden). @Outbound pointed out what I already knew on the last mount, and that the TV was crooked:(....so this pushed me to straighten it out.
    We also picked up a small 32" TV and new organizers by our area. The TV will be setup to display our shared calendars for us and the kids. We use timetree on our phone now. But it's not compatible so we'll be switching to Google calendar. With 4 kids and both of us working busy/demanding jobs, organization is important. This will help I'm sure for all of us as a family.
    Prostar 190, saybng, ATV25 and 12 others like this.
  20. Jan 1, 2023 at 6:56 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    saybng, ATV25, B.Ross and 2 others like this.
  21. Jan 1, 2023 at 6:59 PM
    NWPirate
    Zach
    WA
    Save that hide, you could fashion up the wife a custom makeup pouch.
  22. Jan 1, 2023 at 7:02 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    FYI for you guys looking at new dishwashers. Be mindful the schemes they use. When it lists the db level that rating is a reading of the AVERAGE db over a cycle, which is probably the quick or half load cycle. Just an fyi.
    WAtundra4x4 and Fotnot like this.
  23. Jan 1, 2023 at 8:30 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That bastard’s been dead for a while… :eek2:
  24. Jan 1, 2023 at 8:32 PM
    TaquitoBandito
    Joel (AKA Bif)
    Noted - I’ll go retrieve it off of the neighbors windshield. :)
    T-Rex266, CodyP, WAtundra4x4 and 2 others like this.
  25. Jan 1, 2023 at 8:35 PM
    TaquitoBandito
    Joel (AKA Bif)
    Yeah, I guess it was leftover from when I had a rat infestation in 2020 or 21. They never breached the living area, fortunately. This one was behind the air handler. Thought there was a funk in the air in there…
    T-Rex266, ATV25, WAtundra4x4 and 3 others like this.
  26. Jan 2, 2023 at 6:00 PM
    NWPirate
    Zach
    WA
    Looking for high quality universal door latch internals.
    Apparently my kids like to swing from the door handles and deform the mild steel.
    Existing hardware is Baldwin.
    TIA :hattip:
  27. Jan 2, 2023 at 6:02 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Good to know my kids are not the only ones that do this!
  28. Jan 2, 2023 at 6:05 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm glad to see kids are doing the same dumb stuff I used to do
  29. Jan 2, 2023 at 6:25 PM
    hBaz
    hBaz New Member
    Cleaned up the tile job, set the toilet flange and installed new toilet in master bath. Its a corner style, makes better use of space in long skinny master bath.
    Still have drywall to do, ran out of days off. Not ideal to jump ahead but wanted to get back to functional crapper for nightime visits.
  30. Jan 2, 2023 at 6:38 PM
    1/2 bath is functional again! Just needs trim. Oh, and a round mirror, wifey is on the lookout for one, the rectangle won’t do she says.
    From this:
    To this:
