Headlight restore using Meguiar's on 2010 Tundra
Discussion in 'Detailing' started by Yakisoba, Oct 24, 2020.
  1. Oct 24, 2020 at 3:25 PM
    Yakisoba
    Yakisoba [OP] New Member
    Queen city/Hornests Nest, NC
    2010 Dbl Cab SR5 4.6
    Here's my experience using Meguiar's Heavy Duty Headlight Restoration Kit (G2980) that I got at WalMart. It took about 2 hrs to complete both headlights & fog lights.
    https://www.meguiars.com/automotive/products/meguiars-heavy-duty-headlight-restoration-kit-g2980-kit
    Hardest part was applying the UV sealant at the end. Hard to make sure I had enough but not too much that it runs. Now to see if I make it a year with clear headlights
    Before pics don't show how badly fogged and pitted the lights are.
    After hand sanding with 1000 grit. This step took the longest. Drying off the headlight helped me find the spots that still needed work. You can see the left side of the headlight still had some original film.
    After hand sanding with 3000 grit. Looking better!
    After polishing.
  2. Oct 24, 2020 at 3:39 PM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    Very timely post. I'm looking at this for my wife's car.
    All of this was done with just the kit?
  3. Oct 24, 2020 at 3:58 PM
    Yakisoba
    West Texas Tundra, Mcoop and Piney like this.
  4. Oct 24, 2020 at 3:59 PM
    Piney
    Piney New Member
    2020 MGM TRD Pro
  5. Oct 24, 2020 at 6:15 PM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    Wow! That is a huge difference. Nice job. I'd be interested to see how long they stay clear.
  6. Oct 24, 2020 at 6:56 PM
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    wonder if you reapplied the polish every couple of months if that would work to keep the fog away?? Would definitely be easier than redoing the whole process
  7. Oct 24, 2020 at 7:04 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I'm impressed with it. My 2012 is just starting to get hazy headlights. Might have to look into this. Thanks for the post.
  8. Oct 25, 2020 at 12:34 PM
    Yakisoba
    @Triton19X2 - I hope to "maintain" the clarity. It will be an experiment at first to see how well the UV sealant keeps the shine.
    @Tipsovr - If your headlights are at the "fog only" stage you may only need a kit with polish and UV sealant. Not sure who makes that kit, maybe someone on the forum knows?
  9. Oct 27, 2020 at 12:41 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Ive used that product and it worked like a charm.
    Yakisoba[OP] likes this.
  10. Oct 27, 2020 at 12:52 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Can also take to a paint shop, they'll do their magic to restore it and then apply clear coat so it lasts for years, just a though....
  11. Oct 27, 2020 at 8:12 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Great post. I have had great luck with this product on my 07.
    Not the products fault but the headlights needed another restore again about a year later. I waxed them a few times as well.
    I hope yours last longer.
  12. Oct 28, 2020 at 4:17 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Looks good!!!! I used the Sylvania kit a little over a year ago and was please with the results. You ain't kidding about the sealant. Too little or too much and you're redoing the process all over again. I think I'll go to a pro next time around and pay the extra but these kits do work. Good job!
  13. Nov 1, 2020 at 5:36 AM
    Johnsonman
    Austin
    Sequoia
  14. Nov 1, 2020 at 7:08 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I tried a clear coat (meguiars) with a very high rating on my wife's Lexus. More orange peel than I wanted. Use aerospace 303 after every wash or two weeks. Decent results.
  15. Jan 2, 2023 at 6:07 PM
    Yakisoba
    Took 2 years, but made it back with an update. The headlights did start fogging again, but definitely not as bad.
    Pulled out my kit and did a touch up. I started with just the polish, but found using the 3000 grit pad was a quicker/easier way to remove the remaining UV sealant. Then back to polish and finally applied UV sealant.
    Spent about 10 to 15 minutes per headlight. Interestingly I got the UV sealant perfect this time. I think it was me being in a hurry, spread a generous amount on, and didn’t try to touch it up.
    Before:
    After:
    Jay08, NUDRAT, georgiey22 and 2 others like this.
