2020 U-joint lube/driveshaft tranny leak?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Texan_Tundra, Dec 31, 2022.
  1. Dec 31, 2022 at 1:11 PM
    Texan_Tundra
    Texan_Tundra [OP] New Member
    I have a used 2020 tundra crewmax 2wd. Had 51k miles when i got it.
    It makes a small clunk sound when I begin moving forward after start up. Doesn't repeat as long as the truck is on. Only after startups.
    I wanted to lube the U-joints but I don't see a port to connect the greasegun.
    Additionally I found what appears to be a leak where the driveshaft meets the transmission. What could cause this and could it be the source of the noise. I plan to tow a lot with this truck. 5000lbs on the highway, 8000 around parking lots (pressure washing water tank).
  2. Dec 31, 2022 at 1:13 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    My 2011 has grease zerts on every
    u joint. as far as the small leak looks life rear out put shaft seal. Could be leaking.
  3. Dec 31, 2022 at 1:16 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    The newer u-joints are sealed and do not have zerks to grease them.
    Wallygator likes this.
  4. Dec 31, 2022 at 1:17 PM
    Vince
    Vince New Member
    Vincent
    Damn...
  5. Dec 31, 2022 at 1:18 PM
    Texan_Tundra
    Planned obsolescence. Greedy mfers
    Johnmatrix likes this.
  6. Dec 31, 2022 at 2:40 PM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    The clunk is the abs test nothing to worry about there
    Spyker, Steve0624, TXBrit and 5 others like this.
  7. Dec 31, 2022 at 2:42 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Tundras have been zerkless since, I believe, the 2018 model year.
  8. Jan 1, 2023 at 10:26 AM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    Looks like an transmission output shaft seal is weeping.
    Oolypoolay likes this.
  9. Jan 3, 2023 at 5:04 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Mid 2017 is my understanding. Mine does not have any.
  10. Jan 3, 2023 at 6:49 AM
    This is the answer
    TXBrit, MadMaxCanon and Jaypown like this.
  11. Jan 3, 2023 at 10:15 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    My 2017 driveshaft to the rear diff is zerkless on my 2017, but the shaft going to the front does have zerks…. And they are a pain to lube.
  12. Jan 3, 2023 at 11:17 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    My 2017 SR5 4x4 (10/2016 built date) have zerks on all the drive shafts. Looks like you have a leak, should be under warranty and is easy to replace.
  13. Jan 3, 2023 at 1:16 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    my 2021 4wd has no zerks at all which I am ok with. supposedly the zerkless ones last longer because they are better sealed. Also, it would be a nightmare to grease them regularly when you have cat shields on.
    Also, the noise you are hearing is the ABS check. To test it, drive a ways at 5 mph, then as soon as you hit 6mph you will hear it.
    drew.c.114 likes this.
  14. Jan 3, 2023 at 4:46 PM
    Rocko9999
    Rocko9999 New Member
    That leak is just a weep. I would clean it off and monitor. Some weeps stay that way for hundreds of thousands of miles.
  15. May 2, 2024 at 9:15 PM
    drew.c.114
    drew.c.114 New Member
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    Does it only do it once after start up or continuously?
  16. May 3, 2024 at 4:25 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    After starting the engine and reaching some speed. All ABS-equipped cars do it, I think. I never saw one not doing that.
  17. May 3, 2024 at 8:09 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    My wife's accord doesn't do it. At least if it does, it's not near as noticeable as the Tundra. Toyota has been causing mini panic attacks on Tundra owners for years now :rofl:
  18. May 3, 2024 at 11:36 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes, my Volvo (ATE brake system) is also quieter. Wife's newer ex-Volvo was almost unnoticeable.
    Jaypown[QUOTED] likes this.
  19. May 3, 2024 at 4:43 PM
    MadMaxCanon
    Once after startup. Each time you turn on truck, count on hearing it.
