3rd Gen Front Air Dam
Discussion in '3rd Gen Tundras (2022+)' started by Rwaters, Mar 13, 2022.
  1. Mar 13, 2022 at 10:09 AM
    Rwaters
    Rwaters [OP] New Member
    2022 Tundra TRD SR5 Crewmax
    Does anyone know if there is a fixed front air dam on one of the models? Not the automatic one. I know the TRD’s don’t
  2. Mar 13, 2022 at 10:48 AM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    I believe the TRD Offroad package has an air dam delete in the options list. At least in Canada anyway.
  3. Mar 13, 2022 at 11:32 AM
    Rwaters
    If there is a fixed one, I'm thinking about adding it for the aerodynamics. I have an SR5 TRD so I don’t have one at all, fixed or electric
  4. Mar 13, 2022 at 12:16 PM
    Drobc
    Drobc New Member
    makes no sense that the Canadian TRD models have them removed, but American TRD version retain the active air dam
  5. Mar 13, 2022 at 12:54 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    What are the differences between CEPA and EPA? US could have more strict standards which would increase the benefit of the air dam. CEPA would be more lenient, therefore putting more $ in Toyotas pocket saving on parts/part allocation.
  6. Mar 13, 2022 at 12:55 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Keep in mind use, Mr. Toyota Truck (Sweers) even said himself that during their testing it negatively affected aero/MPG while towing, so Toyota stores it up when trailering.
    Rwaters[QUOTED][OP] likes this.
  7. Mar 13, 2022 at 1:12 PM
    Drobc
    Drobc New Member
    what?! It’s not effective/active when towing? That’s when I want it most. is there a link to this info please ?
  8. Mar 13, 2022 at 1:17 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Give me a few
  9. Mar 13, 2022 at 1:24 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    DaveR4x4 likes this.
  10. Mar 13, 2022 at 1:32 PM
    Drobc
    Drobc New Member
  11. Mar 13, 2022 at 1:39 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    At 5%, (being a direct correlation 1:1 between aero and MPG)...
    15k miles / 20 MPG x $5 gal = 3750
    15k miles / (20 x1.05) x $5 gal = $3571
    Keep in mind, this is 15k miles at speeds where the air dam is deployed.
    Drobc[QUOTED] likes this.
  12. Jul 8, 2022 at 12:48 PM
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    If removed does it throw a code?
  13. Jul 8, 2022 at 12:58 PM
    t300
    t300 New Member
    Manitoba
    22tundra
    also no sense why us canadians get crap rims on TRD packages, why we can't pick any options, why there is zero visibility/tracking available to us, and to all - why there is no auto-4wd system on Tundras. On the plus side we get (aka forced) block heater packages standard lol. ps tow-hooks.
    Serge752 and Outbound like this.
  14. Jul 8, 2022 at 12:59 PM
    j.b.
    j.b. New Member
    Jake
    2022 Platinum MGM
    According to these folks, it will throw codes.
    edit: 6:38 on that vid. The embedded timestamp didn't work
  15. Jul 8, 2022 at 1:38 PM
    benca1
    benca1 New Member
    Damn it :(
  16. Jul 10, 2022 at 10:23 AM
    Tumbler
    Tumbler New Member
    Just leave the actuator in place and connected and remove the actual dam parts. Truck will think its there when it's not. Easy peasy!
    benca1 likes this.
  17. Jul 10, 2022 at 11:17 AM
    montera.built
    montera.built New Member
    Jordan
    2022 AG Toyota Tundra TRD Offroad
    Just for reference, I did this with my bumper and it's still throwing codes for some reason.
  18. Jul 10, 2022 at 6:13 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    The motor probably needs to recognize end points, so taking the HW off and leaving the motor connected IMO wont work. You'll need to create a little end point contraption on the motor itself. Dealing with something similar on a different platform.
    montera.built[QUOTED] likes this.
  19. Jul 10, 2022 at 7:54 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Got lucky, my 1794 OR doesn’t have one thankfully
  20. Jul 11, 2022 at 4:53 AM
    nodak67
    nodak67 New Member
    JR
    was thinking you could just insert a trailer adapter harness on the back and it wont ever deploy per the manual :)
    14burrito and montera.built like this.
  21. Jul 28, 2022 at 2:46 PM
    benca1
    benca1 New Member
    I thought about something this morning. Mike Sweers said that when you plug in a 7 pin harness it automatically keeps the air dam up and cancels any use of it as well as the 7 pin connector also stops the truck from slamming on brakes when backing up with a trailer. So is the 7 pin connector the secret answer for all of this?
  22. Jul 28, 2022 at 8:31 PM
    DexterL
    DexterL New Member
    Setting up trailer in app- how long is it? 2inches, that’s what she said
  23. Dec 31, 2022 at 2:03 PM
    MateoAirborne
    MateoAirborne New Member
    Mateo
    2023 iForce Max 1794 TRD Off Road Package
    I just installed some aFe tow hooks on the same truck that you have, and the first step is to deploy the air dam, but mine doesn’t have it either.
    DexterL[QUOTED] likes this.
