Found a easy way to change the starter on our 2010 4x4 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by WrongwayUp, Dec 19, 2022.
  1. Dec 19, 2022 at 11:43 AM
    WrongwayUp
    WrongwayUp [OP] New Member
    Andrei
    working on them.
    2010 4x4 5.7 starter quit at 210K and replaced with OEM... after spending 3 days trying to disassemble half the engine... i came up with a different way of taking the starter out of the car and saving lots of time with minimal disassembly.
    https://youtu.be/kV65l43lMTg
  2. Dec 19, 2022 at 6:42 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    That was realty crafty of those guys!
  3. Dec 19, 2022 at 7:05 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Didn't watch...
    Is this regarding removal of the voltage regulator before extracting the main bulk of the starter??
  4. Dec 19, 2022 at 7:14 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Wow this is incredible. Mind sharing how many total hours to do this job with your approach?
    I used your video to wrap my steering wheel. Thank you for the help!
    WrongwayUp[OP] likes this.
  5. Dec 20, 2022 at 8:43 PM
    WrongwayUp
    Andrei
    working on them.
    well it took almost 3 days cos i took apart the whole bottom end... i did not include it in the video... i took the cooler lines off and that was a goat rope... it just could not snake it or position it , to to get it out. the exhaust was in the way and i started down that road but quickly realized i was going to add more to the project and stopped. .as a last ditch effort i took the the starter solenoid off to get it out just like in the video. and had it back together in 45min.
    I think if i had to do it again my way i could do it in 2h. but since most people are in it for the first time a realistic 4h is more probable. :thumbsup:
  6. Dec 31, 2022 at 11:08 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I think the average life cycle of these starters are aboit 210k.. Average mileage Sequoias and Tundras replace them... I pulled the whole unit out of the front, but did have to undo the wire harness brackets, 2 black tabs on the rail.
