Should I use a weight distributing hitch?
Discussion in '3rd Gen Tundras (2022+)' started by AWDDude, Dec 30, 2022.
  1. Dec 30, 2022 at 11:41 AM
    AWDDude
    AWDDude [OP] New Member
    2023 Tundra Limited - Crew Max TRD Off Road 4x4
    I have a 3600lb travel trailer. When we first purchased it I towed it around with my Tacoma using a weight distributing hitch. Now that I have the Tundra, should I still use the WDH? Are there any negatives to using the WDH, even if the truck can handle it with a normal hitch?
    Here are the specifications of my trailer:
    2020 Sunset Trail SS-186BH
    Dry Weight: 3618
    Exterior Length: 22' 6"
    Carrying Capacity: 1080
    Hitch Weight: 390
  2. Dec 30, 2022 at 11:46 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Not because of the weight, but because it's a giant wind sail, it'll never hurt you to have it. Particularly if your WDH has anti-sway to it. I looked hard at Andersen for the simplicity of setup and the creative chain usage as well as being anti-sway.
  3. Dec 30, 2022 at 11:57 AM
    Breathing Borla
    AZ
    doesnt the manual say anything over 3500 lbs needs it? or is it 5000 now?
  4. Dec 30, 2022 at 12:16 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Use a WDH it is good insurance, if you have to think about it just use it.
  5. Dec 30, 2022 at 12:49 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Pretty sure it is 5000 now.
    Just use the WDH, especially if you already have it. It will handle better with it.
    BravoDeltaRomeo and JCBerb like this.
  6. Dec 30, 2022 at 2:21 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It's 5000 on my 2.5 gen.
  7. Dec 30, 2022 at 3:00 PM
    catalac
    catalac New Member
    3600 lbs plus 700-1000lbs in gear, water, etc ya I’d probably get a weight distribution hitch. My wife pulls a 2500lb horse trailer plus two horses making it around 4500lbs and it squats her 2022 CC SB 1794 quite a bit with a normal receiver.
  8. Dec 30, 2022 at 3:03 PM
    mass-hole
    mass-hole New Member
    The manual and/or hitch on the truck likely says >500lbs tongue/5000 trailer needs WDH
    Even though the trailer is 3600 lbs i wouldnt be surprised if the tongue is up near 500 lbs. I would just do it.
    Cpl_Punishment likes this.
  9. Dec 30, 2022 at 3:31 PM
    Taikowaza
    Taikowaza New Member
    WDH and sway bar is the way. Perfect with my 4.7L Sequoia, just a lovely with my Tundra. Even if you have a more powerful truck, don’t stop using a WDH and sway bar: they keep the trailer from swaying or drifting, and tracking straight
  10. Dec 30, 2022 at 4:25 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    You may not need it but using one will just make things better and help reduce the squat. Mine squatted over 2 inches with the trailer on and no WDH bars attached. My truck sits level with the WDH turned up and dialled in. Also, reducing the sway just makes for a more comfortable ride with less to worry about. My trailer weighs about 4,100 lbs and has a tongue weight of 500 lbs. The truck has no trouble pulling this trailer but the TRD Offroad suspension appears to be a bit soft to maintain level without help from the WDH.
    It sits pretty level here.
    raylo, slowpokepete and in_the_mud like this.
  11. Dec 30, 2022 at 5:02 PM
    hBaz
    hBaz New Member
    middle of nowhere south of OK City
    2021 black 1794 Edition with TRD package
    Like others have noted, I agree it's needed ... I think for all but little light utility trailers. In big scheme of trailer and truck costs, WDH with sway control is a fairly cheap insurance setup. I plan to setup for two horse trailer behind new2me 21 tundra 1794.
    I will admit that will miss just dropping gooseneck onto ball in bed, connect chains and electrical, and go.
    Raven67 likes this.
  12. Dec 30, 2022 at 5:06 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have a similar sized single axle camper. I find that it rides like crap without the WDH bars. The WDH is not necessary for load balance, but the ride is way smoother
  13. Dec 30, 2022 at 11:09 PM
    AWDDude
    Thanks for all the replies, I will stick with the wdh.
    JCBerb and Hbjeff like this.
  14. Dec 31, 2022 at 11:26 PM
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Recommended WDH for a TRD Pro frequently hauling a 4000lb 6x10 trailer?
  15. Nov 15, 2024 at 9:27 AM
    Foolishfrog
    Foolishfrog New Member
    Mitch
    2024 6.5 Pearl Platinum for towing camper
    I use an Anderson WDH with my 2024 Platinum 6.5 and a 6000 trailer. Pulls like a dream and would not change a thing.
    Breathing Borla likes this.
  16. Nov 15, 2024 at 8:54 PM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    I tried an Anderson with my 8k trailer - it was lacking. You realize 6k is only half what the Tundra is rated at, right? So far airbags and the factory anti-sway system works well, but I'm wondering if the factory system will wear out the brakes quickly?
  17. Nov 16, 2024 at 9:26 AM
    Balzac
    Balzac New Member
    L
    2023 Tundra Limited CrewCab, TRD OR
    Tonneau cover, added layer of ice, mud or dust
    When Anderson was asked whether their red polymer springs can withstand very cold temps, they refused to answer. We chose another WDH.:canada:
