Adding a second Reverse Camera?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jego, Apr 4, 2021.
  1. Apr 4, 2021 at 8:32 PM
    Jego
    Jego [OP] New Member
    Orlando
    PR
    2018 Tundra 1794
    When the tailgate is open, the reverse camera view is basically useless. I decided to install a second reverse camera so that I can see what's in the back of my truck when the tail gate is open.
    I think this is a very common scenario, not only for Tundra owners, for any truck having the reverse camera in the tailgate.
    I haven't seen may people talking about this. What you think?
    This is how it looks:
    biebs96, panicman, saybng and 2 others like this.
  2. Apr 4, 2021 at 8:36 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I kinda like it! Do you have it on a switch to just take over the factory camera or a separate screen or aftermarket head unit?
    saybng and 15whtrd like this.
  3. Apr 4, 2021 at 8:44 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    That's a great idea! :thumbsup:
    Jego[OP] likes this.
  4. Apr 4, 2021 at 8:54 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Initially I wanted to use a switch similar to the Anytime Backup Camera system. But I ended by making it automatically using magnetic switch to change the video signal when the tailgate is open. This magnetic switch is the same switch you normally see on home alarm systems to detect when doors or windows are open. I temporarily used a plastic one with NC/NO terminals. I ordered a replacement made of alloy with embedded wires and sealed, for better look and durability. The new camera takes over the factory camera view automatically when the tailgate is open.
  5. Apr 4, 2021 at 9:05 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I installed this and I like it a lot, I can also change the angle and see my bed which helps when hauling loose stuff. In the third pic you can see the camera perched up on my third brake light.
    Paulskie, saybng and Jego[OP] like this.
  6. Apr 4, 2021 at 9:12 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Looks great!
  7. May 9, 2021 at 11:04 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    For those interested I uploaded the first part of the DIY video for the second backup camera.
    I will upload the second part soon.
  8. May 11, 2021 at 3:42 AM
    Fishin1981
    Fishin1981 New Member
    2015 tundra limited crewmax
    Pop and lock, esp storage, access lorado, front tints
    That’s awesome. How long did it take for you to install completely?
  9. May 11, 2021 at 2:35 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Hello! It took me around 2 hrs. approx.. I will upload the second part next week that has all the details for the wiring setup. It still working as expected without issues. :)
  10. May 11, 2021 at 3:12 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    This is how it looks.
    BlancaLaGordita likes this.
  11. Apr 10, 2022 at 4:54 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    burtlively likes this.
  12. Apr 12, 2022 at 3:36 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    really cool idea and execution!
  13. Apr 16, 2022 at 10:54 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
  14. Apr 16, 2022 at 10:55 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    1UP[QUOTED] likes this.
  15. Apr 18, 2022 at 4:17 PM
    APalmTree
    Brandon
    SW Washington
    Total workaround solution, BUT, Evil Manufacturing makes a 3rd break light replacement, AND, they make a separate dual-camera module that sits where one of the lights would sit. :notsure: it would work :notsure:
    https://www.evilmanufacturing.com/lights/dirt-kartel-2007-toyota-tundra-3rd-brake-light-mount
    https://www.evilmanufacturing.com/lights/evil-offroad-3rd-brake-light-dual-camera-system
  16. Apr 18, 2022 at 4:23 PM
    1UP
    1UP Truck Gang
    That's slick cause it's 2 cameras and I can get reverse recording.
    But does it fit a Tundra?
  17. Apr 18, 2022 at 4:33 PM
    APalmTree
    Brandon
    SW Washington
    texasrho83 likes this.
  18. Apr 18, 2022 at 5:02 PM
    WV_Warrior
    WV_Warrior New Member
    Cody
    West Virginia
    2021 CM TRD Sport
    Wonder how that would/wouldn’t be affected by my tonneau cover when the gate is closed (most of the time). Neat idea.
  19. Apr 18, 2022 at 5:08 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here's the thread I posted on it
  20. Apr 18, 2022 at 5:18 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    I did this with a separate 2nd back camera that I can switch on combined with a Front/ rear camera. I used a automatic master slaver that switches from OEM back camera to my own back camera when I activate it. Still need to get the proper switch but the foglight one I had has to do it for now
    1UP and texasrho83 like this.
  21. May 9, 2022 at 12:12 PM
    burtlively
    burtlively New Member
    2017 Tundra 4x4 CrewMax Platinum
    As usual my skills show that I can’t seem to get things centered and straight, but here is the outcome regardless:
    TucsonTundra1794 likes this.
  22. Dec 29, 2022 at 1:11 PM
    102dalz
    102dalz New Member
    Andy
    2017 Tundra CrewMax White
    None
    I have a license plate camera that works with the gate down. I wired mine via a FRAC switch through a PYLE AV switch. I also have a front cam in the grill that's switched independently via the FRAC. The switch is wired into the glove box & can be set to a few different modes. I have to switch between the 2 rear cams manually, but the switch holds settings, and will allow display of up to 4 cams if I need another in the future.
    My wife prefers the standard tailgate camera most of the time & this makes accessing either one pretty easy (though not automatic).
