Does the dual zone climates suck or is it just me?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Durania, Jan 27, 2019.
  1. Jan 27, 2019 at 6:44 PM
    Durania
    Durania [OP] New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    2019 Limited CM. I have found that if the passenger side temperature is adjusted ~5 degrees colder than the driver side, it drops my side in temperature too. I'm cold natured and my wife is far from it so she burns up in my truck. Is this just how the dual zone climate control is in the Tundra?
  2. Jan 27, 2019 at 7:32 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    It's how it is is every dual zone vehicle I have ever been in. The actual cabin volume is so small it takes no time to "average" the temperature.
    I have a new limited crew max. On the first day I set my control on 70 and passenger on 65. In just a few minutes the temp was the same throughout the cab.
    What DOES work is one or two degree difference. If both are set at 72 for example, and my wife is a bit warm, she can set it to 70 and get a bit of relief without messing up my temp. Anything over that, the volume is just too small for it to work for long.
    If it gets too bad one of us just cracks the window.
    BTBAKER, Durania[OP] and Pudge like this.
  3. Jan 27, 2019 at 7:33 PM
    Durania
    Crossville, TN
    Thank you. I wasn't sure if something was wrong with it or not.
    1engineer likes this.
  4. Jan 27, 2019 at 7:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Yeah and you're sitting like a foot away from the passenger. you could make some kind of wall between yourself and the wife, soundproof would probably be ideal lol. I'm more disappointed with the rear heat and AC, those little vents are a joke, they could have made them much much better.
    mgrs, 15whtrd, T-Rex266 and 1 other person like this.
  5. Jan 27, 2019 at 7:38 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    This feature has always made no sense to me.
    Pudge likes this.
  6. Jan 27, 2019 at 7:44 PM
    Feature kind of sucks. I wish it was a true, independent feature.
  7. Jan 27, 2019 at 7:58 PM
    1engineer
    Appalachians
    Yeah but it's like putting two people in a closet, one with a heater and one with an air conditioner. They will just cancel each other out.
  8. Jan 27, 2019 at 8:12 PM
    Markman
    Markman New Member
    Mark
    Utah
    2019 limited cement cm
    Tint airbags daystar cradles Elka suspension bushwacker flares
    I do like the dual climate control in mine, wife turns hers on high, seat warmer on high I put mine on 63 and can feel some cool air. Makes long trips way better imo
    15whtrd and 1engineer like this.
  9. Dec 28, 2022 at 7:14 AM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    I know, old thread, but I hate how the auto heat setting temp is reached and the it starts blowing cold air at 2-3 on fan setting. What's with that? If it's going to recirculate can't it just blow air out the lower vents at lowest speed, not at you. to re-chill you? I have to shut it off so my passengers don't complain and I don't need cold air blowing on me.
  10. Dec 28, 2022 at 10:24 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I miss the old three-knob style of climate controls personally. Didn't have to look down to see what you were doing. The trend toward an array of buttons and modes that you can only identify via an LCD screen is counterproductive.
    Rocko9999 and rebmo like this.
  11. Dec 29, 2022 at 10:26 AM
    Rocko9999
    Rocko9999 New Member
    I miss the old slide lever. You could really fine tune the temps. [​IMG]
