General Supercharger Thread
  1. Dec 28, 2022 at 6:31 PM
    #4831
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I better get that pulley lol
  2. Dec 29, 2022 at 3:58 AM
    #4832
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    (I guesstimated the #'s from the graphs) fudge factor waiver.
    my takeaways:
    the Mag spins up FASTER*
    the power delta flattens per PSI in the middle.
    the better breathing (in and out) lets the power grow past 4500. my stock inlet chokes @ ~5k
    Both have FLAT TQ curves.
    Good stuff.
    *assuming that initial Mag TQ bump is not from starting the dyno run.
    M3Tundra-JK[QUOTED] likes this.
  3. Dec 29, 2022 at 4:34 AM
    #4833
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Under WOT my a/f is 11.6-12.2 on the street. Those numbers are impressive, great job.
    snivilous[OP] and HulkSmurf14 like this.
  4. Dec 29, 2022 at 4:36 AM
    #4834
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Those numbers I would imagine are in the “playing with fire” zone for a stock engine based on everything we have heard. Unless everything we have heard is bologna anyway.
  5. Dec 29, 2022 at 5:04 AM
    #4835
    Fastlane47
    Maryland
    2018 Platinum
    I see a big mix, some people say 600 at the crank is the sweet spot, other tuners say 650 plus with at the crank with a rich a/f is the sweet spot.
  6. Dec 29, 2022 at 7:33 AM
    #4836
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Wondering what altitude it was done at. That's pretty much the setup I'm going for, except I won't have headers for quite a while. Will probably be on bone stock exhaust during tuning....maybe a dirtydeeds setup
  7. Dec 29, 2022 at 7:35 AM
    #4837
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    190ft above sea level...optimal for marketing
  8. Dec 29, 2022 at 8:12 AM
    #4838
    snivilous
    SW UT
    300k+ Supercharged 2008
    Curious also, I target 10.5
  9. Dec 29, 2022 at 10:48 AM
    #4839
    M3Tundra-JK
    Scott
    2005 GX470
  10. Dec 29, 2022 at 10:53 AM
    #4840
    Silver17
    Eastern PA
    Solid! I’m surprised by the Boost pressure on what is likely a 2.30 pulley, especially running longtubes which should drop a psi or 2.
    M3Tundra-JK likes this.
  11. Dec 29, 2022 at 11:24 AM
    #4841
    Silver17
    Eastern PA
    HulkSmurf14 likes this.
  12. Dec 29, 2022 at 11:32 AM
    #4842
    Saltyhero13
    Saltyhero13 Throbbing Member
    Dunno. I've asked Harrop about a spacer, they said there isn't one on the market. Doesn't mean this couldn't work.
    Silver17[QUOTED] likes this.
  13. Dec 29, 2022 at 5:04 PM
    #4843
    M3Tundra-JK
    Scott
    2005 GX470
    Ya so that maf tube isn't gonna work with the stillen. I jumped the gun lol. I'll have to see.hownthe truck tunes with the stillen, and wait for that AFE to come out
  14. Dec 29, 2022 at 6:29 PM
    #4844
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea this would need some modification for sure I.e. cut that tube add the maf unit but you’re still dealing with a small tube connection as that looks tapered
  15. Dec 29, 2022 at 9:16 PM
    #4845
    Saltyhero13
    The MAF tube is what I am using with the Stillen but on the Harrop. Parts I used are a few pages back.
    M3Tundra-JK[QUOTED] and reywcms like this.
  16. Dec 30, 2022 at 3:41 PM
    #4846
    Silver17
    Eastern PA
    Looking at the magnuson intake lid, the inside diameter as previously mentioned is 3-7/8” or 3.875”. The wall thickness of the tube is a heavy 1/8”. I think it could easily be made an even 4” with a 3” drum sander on a drill and still have at least half of the wall thickness and be plenty strong. Would help eek out a little more volume and reduce that MAF voltage a bit more. I’ll have to think about doing it. Does anyone here have a magnuson with the 2.3 pulley at sea level and max out their MAF voltage on the magnuson box?
  17. Dec 30, 2022 at 4:28 PM
    #4847
    snivilous
    SW UT
    You are one cheap bastard, holy shit :D even if you opened it up to a full 4" that's only a 6% increase in airflow, and I suspect you're more likely to lose performance/make no difference to the MAF from hacking up the walls. But let us know how it goes!
  18. Dec 30, 2022 at 4:52 PM
    #4848
    Silver17
    Eastern PA
    :rofl: Hey I’m not cheap I’m ingenuitive. And it’s not hacking it’s carefully boring out in a uniform manner to a near perfect 4” diameter. Just like boring out a cylinder.
    reywcms, Saltyhero13 and M3Tundra-JK like this.
  19. Dec 30, 2022 at 4:56 PM
    #4849
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    EFD81A23-4B04-4236-BB91-87D31CEF8BDB.jpg A70E975C-A48F-4716-A3FB-3E64FF7041C7.jpg
    You could fiberglass the outside also. I made this that I’m contemplating fabricating to the box, if I move the the bigger throttle body~ if I build the motor.A70E975C-A48F-4716-A3FB-3E64FF7041C7.jpg
    I used this container that I got that had a bunch of zip ties in it. It’s a little larger than 4” ID
  20. Dec 30, 2022 at 5:03 PM
    #4850
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  21. Dec 30, 2022 at 5:46 PM
    #4851
    Silver17
    Eastern PA
    Perfect. 4” diameter 80 grit. Rig that onto a drill and stuff it in the slightly smaller tube and boom it will be a perfectly symmetrical 4” inside diameter in no time.
    HonorNotInner likes this.
  22. Dec 30, 2022 at 5:47 PM
    #4852
    snivilous
    SW UT
    Fuckin A :rofl:
  23. Dec 30, 2022 at 6:03 PM
    #4853
    Silver17
    Eastern PA
    Even if it is only 6% increase in volume…6% of 5 volts is .3 volts. If you’re hitting 4.97 or whatever at the moment, this could bring you down to 4.67. It can quite literally be the make or break difference.
    :monocle:
  24. Dec 30, 2022 at 6:05 PM
    #4854
    snivilous
    SW UT
    Cool, let me know how it works for you and then I'll decide if you should send me the flappy wheel :rofl:
  25. Dec 30, 2022 at 6:22 PM
    #4855
    Silver17
    Eastern PA
    Hey now who’s the cheap bastard! Lol JK.
    I’m not sure if I’m gonna or not, it may not be necessary with my 80mm pulley. But if data logging reveals I’m still exceeding 5v, I certainly would try it. Just doing some math, if I went to a 75mm pulley that’s a 13.7% increase in flow over my 80mm. To think just boring the tube out 1/8” would take care of nearly half of the increase in MAF voltage that would result from switching pulleys. Not much to lose. Worst case I just have to buy a new lid if I F*** it up, but I think that would be hard to do if careful.
  26. Dec 30, 2022 at 6:57 PM
    #4856
    M3Tundra-JK
    Scott
    2005 GX470
    Steady hands
  27. Dec 31, 2022 at 10:18 AM
    #4857
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Re:Radium Catch can
    I see the connection that needs to get interrupted.
    How in the Sam-hell do you reach the side that's on the top of the engine?
    I'm considering just disconnecting the connection on the bottom of the blower (Harrop) and jury rigging the connection to that hose.
    Saltyhero13 likes this.
  28. Dec 31, 2022 at 10:39 AM
    #4858
    Silver17
    Eastern PA
    That’s kind of what I did. It’s a real joy if you want to get to the PCV valve connection.
  29. Dec 31, 2022 at 10:50 AM
    #4859
    nobodyintexas
    nobodyintexas What?
    South of Houston
    you sir, are my hero.
    Saltyhero13 and Silver17[QUOTED] like this.
  30. Dec 31, 2022 at 2:54 PM
    #4860
    M3Tundra-JK
    Scott
    2005 GX470
    Maf tube is nice! Will figure it out
    Saltyhero13 and reywcms like this.
