Wires but no switch in the dash?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Naut18, Dec 28, 2022.
  1. Dec 28, 2022 at 6:16 AM
    Naut18
    Naut18 [OP] New Member
    2016 Tundra TSS
    Any ideas what the 2nd from left wires control? There is no switch on the outer facing portion of the dash.
  2. Dec 28, 2022 at 6:23 AM
    Taco-Spike
    Two Trucks
    I think there is a sensor on some models
  3. Dec 28, 2022 at 6:25 AM
    These trucks are prewired for different trim levels. There are quite a few unused connectors that you will find.
  4. Dec 28, 2022 at 6:43 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    That’s for the glass break sensor I believe
  5. Dec 28, 2022 at 7:08 AM
    pursuit2550
    pursuit2550 New Member
    One is the glass break sensor for sure. I used it when I did the alarm.
  6. Dec 28, 2022 at 7:21 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My 2010 SR5 had all the wires for all the missing options. I added 80% of them. (auto headlights, heated seats, auto HVAC) etc.
    HulkSmurf14 likes this.
  7. Jan 2, 2023 at 8:55 PM
    Soap_Doc
    Soap_Doc New Member
    2010 Tundra 5.7
    So… what a re the rest? And can I just sub them out from something else like light switches for my overhead and rear LEDs…
  8. Jan 2, 2023 at 10:45 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    One is for the glass break sensor and the other is the parking sonar switch.
    You can tuck them out of the way and out anything you want in those blanks. But you can really use those connectors for anything but their intended switches/sensors
  9. Jan 3, 2023 at 8:00 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    In order left to right
    Left power port
    Glass Break Sensor (only actually installed on higher trim trucks)
    USB/AUX in to radio
    Right Power port
    FYI on 2014+ sonar button should be on the dash between steering wheel and radio. Next to tow haul button and traction control button.
    matictundra and texasrho83 like this.
