2001 Tundra Brake controller factory wiring
Discussion in '1st Gen Tundras (2000-2006)' started by Hilandr452, Dec 28, 2022.
  1. Dec 28, 2022 at 12:09 AM
    Hilandr452
    Hilandr452 [OP] New Member
    Daniel
    2001 2wd Tundra, V8
    I just bought a 2001 Tundra 2wd and need to do some towing. Purchased a new hitch, added the wiring for the 7 pin in the back using an after market kit that plugs into the factory plug, but I cannot find a kit that plugs into factory wiring for the brake controller. It seems to start at 2002 and I haven't been able to find any instructional videos showing how to hook up the 2001. It sure would be nice to just plug and play instead of jumping into existing wires. Any ideas? Was there no factory wiring for trailer brake controllers in 2001? Please help!
    Respectfully,
  2. Dec 28, 2022 at 12:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    As far as I know, there is not a plug, and play harness for the 2002, and older trucks. You'll have to splice. Make sure you use posi-taps, or one of our members here will getcha!
    Scotch-locks fail, and cause issues. Even on the inside of the vehicle.
    Here's a link for you to read on the posi-taps.
    shifty` likes this.
  3. Dec 28, 2022 at 1:21 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My 01 has a trailer brake controller in it. Unsure of how it is wired but it doesn't seem to do anything and I've never had a use for it. Just let it sit there in case I ever have a reason to need it hooked up. My 7 pin connector works though. 4 pin doesn't. Just use a 7pin to 4 pin on mine.
  4. Dec 28, 2022 at 5:35 AM
    BubbaW and shifty` like this.
  5. Dec 28, 2022 at 4:31 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Yep, no plug n play unfortunately. I installed one 22 years ago in my 2001, along with a battery isolater (sp?). Still all good and I think I used scotch locks on the brake switch wire.:( I bet an RV service bay would probably wire one up for you if you don't have the time to do it yourself.
  6. Jan 5, 2023 at 4:44 PM
    Les
    Les New Member
    LC
    01 tundra
    I had to wire mine in, I got the controller from ETrailer , they were helpful. I also used the harness linked above.
  7. Jan 6, 2023 at 3:10 PM
    NorthOf40
    NorthOf40 New Member
    There are a handful of videos on youtube if you search for 2000 tundra
